When did the ability to add ‘delete’ plugin to right button menu disappear from Desktop Settings? Can this somehow be added otherwise?
Is it not showing here?:
… Note I haven’t updated yet. Will see if it disappears when I do.
Also note it’s usual practice to include current system details on Support topics:
inxi -zv8
Note that the output produced by this command is privacy-filtered.
Please also remember to use proper code formatting as this makes it much easier to read on the Forum:
[Mini How-To] format code or command output
Select and copy all the text in the Terminal window (minus the prompt, if you are using zsh).
Then paste the output in between two lines containing three backticks
or three tildes
Or:
Copy & paste, then highlight the pasted text and click the </> button at the top of the reply window (easier for smaller outputs).
Cheers! ![]()
I’ve updated and can confirm it’s still there.
I thought it would be. It’s not unheard of that settings can get changed during updates; it’s happened to me before. Simple case of going through and putting the settings back how you want them. ![]()
Just rebooted and there it is. Baffled!
As a side note, what use would ‘inxi -zv8’ have been?
It lets us know for example what Desktop Environment you are using, which is important for a Topic like this. Not everyone keeps their profile “card” up to date. ![]()
Also:
Would that be the first reboot since a System Update, by any chance?
