Continuing the discussion from Fresh install freezing constantly:
So I am having a boot issue where the system will freeze randomly at different points. This computer has been running with no issues for quite a while. It has been connected to the internet by Ethernet. Now unfortunately my living situation has changed and I am having to use Wifi. I believe I am having the issue mentioned in the previous forum with the same driver.
I wish I could say I have tried several things, but so far all I have tried is a different kernel. I have two currently installed 5.10 lts, and 5.14 respectively from the kde kernel manager. Both will work at times, but nether seems any more consistent when it comes to overcoming this problem. I don’t know what else to do. Is there a way to see the process while Manjaro boots so I can see where it is getting hung up?
Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=532a2a90-7d4c-4de6-9edb-f10b70a99eea ro quiet apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1
dm: GDM 40.1, SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASRock model: X570 Phantom Gaming 4 serial:
UEFI: American Megatrends v: P3.90 date: 01/26/2021
RAM: total: 15.55 GiB used: 1.83 GiB (11.8%)
Info: 8-Core model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3
family: 19 (25) model-id: 21 (33) stepping: 0 microcode: A201009 cache:
L2: 4 MiB bogomips: 121417
Speed: 2868 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz):
1: 2868 2: 2869 3: 4259 4: 3213 5: 2874 6: 2871 7: 2873 8: 2921 9: 3590
10: 2869 11: 2870 12: 2865 13: 2867 14: 2269 15: 3582 16: 2327
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rapl rdpid
rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep
ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall
tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vaes vgif
vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: always-on, RSB filling
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: Micro-Star MSI
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 09:00.0
chip-ID: 10de:2484 class-ID: 0300
Device-2: Sunplus Innovation Webcam type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-6:4 chip-ID: 1bcf:2cb4 class-ID: 0102 serial:
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.0x10.7")
s-diag: 554mm (21.8")
Monitor-1: HDMI-0 res: 1920x1080 hz: 75 dpi: 102
size: 476x268mm (18.7x10.6") diag: 546mm (21.5")
OpenGL: renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 09:00.1 chip-ID: 10de:228b
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Sunplus Innovation Webcam type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: no
Device-1: Realtek RTL8812AE 802.11ac PCIe Wireless Network Adapter
driver: rtl8821ae v: kernel port: e000 bus-ID: 04:00.0 chip-ID: 10ec:8812
class-ID: 0280
IF: wlp4s0 state: up mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: dynamic noprefixroute scope: global
IP v6: type: noprefixroute scope: link
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
port: d000 bus-ID: 05:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp5s0 state: down mac:
WAN IP:
Device-1: ASUSTek ASUS USB-BT500 type: USB driver: btusb v: 0.8
bus-ID: 3-1:2 chip-ID: 0b05:190e class-ID: e001 serial:
Local Storage: total: 931.51 GiB used: 596.14 GiB (64.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate
model: FireCuda 520 SSD ZP1000GM30002 size: 931.51 GiB block-size:
physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD
serial: rev: STNSC014 temp: 34.9 C scheme: GPT
ID-1: / raw-size: 453.91 GiB size: 445.78 GiB (98.21%)
used: 200.92 GiB (45.1%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
label: N/A uuid: 532a2a90-7d4c-4de6-9edb-f10b70a99eea
used: 27.6 MiB (28.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM uuid: 36AB-309B
ID-3: /run/media/justin/Windows raw-size: 476.61 GiB
size: 476.61 GiB (100.00%) used: 395.19 GiB (82.9%) fs: ntfs
dev: /dev/nvme0n1p3 maj-min: 259:3 label: Windows uuid: EE14AC8914AC567D
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs:
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p5 maj-min: 259:5 size: 900 MiB fs: ntfs label: Recovery
uuid: AE86ACDD86ACA6F5
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 1-1:2 info: China Resource Semico USB Keyboard
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 500mA chip-ID: 1a2c:4c5e class-ID: 0301
Device-2: 1-2:3 info: [Maxxter] Optical gaming mouse type: Mouse,Keyboard
power: 100mA chip-ID: 18f8:0f99 class-ID: 0300
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 3-1:2 info: ASUSTek ASUS USB-BT500 type: Bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA chip-ID: 0b05:190e
Device-2: 3-5:3 info: Cyber Power System PR1500LCDRT2U UPS type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 2mA
chip-ID: 0764:0601 class-ID: 0300 serial:
Device-3: 3-6:4 info: Sunplus Innovation Webcam type: Video,Audio
power: 500mA chip-ID: 1bcf:2cb4 class-ID: 0102 serial:
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 37.9 C mobo: N/A gpu: nvidia temp: 37 C
Processes: 275 Uptime: 14m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1468 pacman: 1461 lib: 425 flatpak: 0
snap: 7 Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.08
Sometimes it will freeze at this screen.
Here is what I think the problem is: having to do with wifi and the current driver. I don’t think I will be able to connect to the internet by Ethernet here if I wanted to. I cannot disable the wireless connection and run the commands mentioned. Any suggestions?
@Yochanan Thank you for the info, I did not understand the html part at the end.
