Hello, I have recently had develop a non-serious but annoying issue. On starting the system loads as usual and my mouse is working etc. The problem is when I click on (say) the desktop Firefox icon it doesn’t respond (neither does Thunar or Thunderbird). When I say they don’t respond none of the desktop icons react at all. I can access all the programs via the Whisker menu so no probs but strangely about 10-15mins later those icons I clicked on will work ie Firefox opens, Thunderbird will open. Any suggestions? It seemed to have followed a quite major update recently but other than that nothing has changed. System info follows:
Kernel: 5.12.9-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=197ff4af-5810-46b0-92bc-b267cfd0b27f rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm4 vt: 7
Type: Desktop System: ASUS product: N/A v: N/A serial: <filter>
Mobo: ASUSTeK model: TUF GAMING B550-PLUS v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 1202 date: 10/22/2020
RAM: total: 31.3 GiB used: 2.1 GiB (6.7%)
Info: 12-Core model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache:
L2: 6 MiB bogomips: 182142
Speed: 2196 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz):
1: 2196 2: 2113 3: 2194 4: 2196 5: 2866 6: 2049 7: 2172 8: 2052 9: 3593
10: 2052 11: 2194 12: 2196 13: 2054 14: 2194 15: 2196 16: 2193 17: 2196
18: 2052 19: 3593 20: 2053 21: 2196 22: 2192 23: 2193 24: 2195
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload
vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
xsaveopt xsaves
conditional, RSB filling
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] driver: nvidia v: 465.31
alternate: nouveau,nvidia_drm bus-ID: 0a:00.0 chip-ID: 10de:1c82
class-ID: 0300
Display: x11 server: X.Org 1.20.11 driver: loaded: nvidia display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 1680x1050 s-dpi: 96 s-size: 445x278mm (17.5x10.9")
s-diag: 525mm (20.7")
Monitor-1: DVI-D-0 res: 1680x1050 hz: 60 dpi: 90
size: 474x296mm (18.7x11.7") diag: 559mm (22")
OpenGL: renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 465.31 direct render: Yes
Device-1: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 0a:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0c:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: Creative USB Sound Blaster HD type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-2.4:3 chip-ID: 041e:30d7
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.12.9-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
port: f000 bus-ID: 09:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Permissions: Unable to run lvs. Root privileges required.
Local Storage: total: 5.02 TiB used: 662.59 GiB (12.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate
model: FireCuda 520 SSD ZP1000GM30002 size: 931.51 GiB block-size:
physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 rotation: SSD
serial: <filter> rev: STNSC014 scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD20EZRX-22D8PB0
rotation: 5400 rpm serial: <filter> rev: 0A80 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD5000AAKS-00V1A0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s serial: <filter> rev: 1D05 scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Western Digital
model: WD20EARX-00PASB0 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B serial: <filter> rev: 2021 scheme: MBR
ID-5: /dev/sdh maj-min: 8:112 type: USB vendor: SanDisk model: Cruzer Blade
size: 14.33 GiB block-size: physical: 512 B logical: 512 B serial: <filter>
rev: 1.00 scheme: MBR
Optical-1: /dev/sr0 vendor: ATAPI model: iHAS324 F rev: CL8M
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 185.38 GiB (20.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 197ff4af-5810-46b0-92bc-b267cfd0b27f
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: EB58-C07B
ID-3: /home/<filter>/Crypt raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
used: 50.13 GiB (11.0%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: Crypt
uuid: 3c0e08cd-6241-4c09-a846-adc6770141a9
ID-4: /home/<filter>/Data raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 427.08 GiB (22.9%) fs: fuseblk dev: /dev/sda1 maj-min: 8:1
label: WD Green 2TB uuid: E21A34941A3467A5
ID-5: /home/<filter>/Shares/music raw-size: N/A size: 1.79 TiB
used: 1.4 TiB (78.5%) fs: cifs source: ERR-102 label: N/A uuid: N/A
ID-6: /home/<filter>/Shares/photo raw-size: N/A size: 1.79 TiB
ID-7: /home/<filter>/Shares/video raw-size: N/A size: 1.79 TiB
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sdc1 maj-min: 8:33 size: 1.82 TiB fs: <superuser required>
label: Music Store uuid: 643E5EAC3E5E76D0
ID-2: /dev/sdh1 maj-min: 8:113 size: 14.33 GiB fs: <superuser required>
label: N/A uuid: 8D44-78D1
Device-1: 1-2:2 info: Cherry type: Keyboard,HID driver: hid-generic,usbhid
interfaces: 2 rev: 2.0 speed: 1.5 Mb/s power: 100mA chip-ID: 046a:0076
class-ID: 0300
Device-2: 1-6:3 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:1939 class-ID: 0300 serial: <filter>
Hub-2: 1-7:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-7.2:5 info: Alcor Micro Flash Card Reader/Writer
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 250mA chip-ID: 058f:6362 class-ID: 0806
serial: <filter>
Device-2: 1-7.3:6 info: SanDisk Cruzer Blade type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
chip-ID: 0781:5567 class-ID: 0806 serial: <filter>
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
Hub-5: 3-1:2 info: VIA Labs Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 2109:3431 class-ID: 0900
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
Hub-7: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-8: 5-2:2 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 045b:0209 class-ID: 0900
Device-1: 5-2.4:3 info: Creative USB Sound Blaster HD type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 1.1
speed: 12 Mb/s power: 500mA chip-ID: 041e:30d7 class-ID: 0300
serial: <filter>
Hub-9: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
Hub-10: 6-2:2 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 045b:0210 class-ID: 0900
Hub-11: 7-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 7-1:2 info: Logitech M105 Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 046d:c077 class-ID: 0301
Device-2: 7-2:3 info: Western Digital Elements Desktop (WDBAAU)
speed: 480 Mb/s power: 2mA chip-ID: 1058:1021 class-ID: 0806
serial: <filter>
Hub-12: 8-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
System Temperatures: cpu: 61.8 C mobo: 0 C gpu: nvidia temp: 38 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Processes: 405 Uptime: 35m wakeups: 0 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1313 pacman: 1302 lib: 335 flatpak: 11
Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.04```
