Hello, this is my first post so apologies in advance for any mistakes
I have an MSI laptop(1) and an HP external monitor(2) connected via HDMI, and set my external monitor(2) as primary display.
Now all works butter-smooth except a minor inconvenience: every time I boot my laptop, the login screen appears in my laptop display(1) instead of my external monitor(2) (hp monitor appears as if it’s not connected). After I log in, my external monitor(2) becomes active & primary. After logging out, the login screen appears on external(2) as it should, just not on the first boot. What settings do I need to tweak for the login screen to appear on my external monitor(2) on first boot?
TLDR: How can I activate my external monitor as primary on first boot (show login screen there)?
Kernel: 5.8.16-2-MANJARO x86_64 bits: 64 compiler: N/A Desktop: KDE Plasma 5.19.5
tk: Qt 5.15.1 info: latte-dock wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Type: Laptop System: Micro-Star product: GE62VR 7RF v: REV:1.0 serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Micro-Star model: MS-16JB v: REV:1.0 serial: <filter> UEFI: American Megatrends
v: E16JBIMS.31A date: 09/05/2018
ID-1: BAT1 charge: 37.9 Wh condition: 38.6/53.4 Wh (72%) volts: 12.2/10.9
model: MSI Corp. MS-16JB type: Li-ion serial: N/A status: Unknown
RAM: total: 15.52 GiB used: 2.09 GiB (13.4%)
Topology: Quad Core model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake
rev: 9 L2 cache: 6144 KiB bogomips: 44817
Speed: 900 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 900 2: 900 3: 900 4: 900
5: 900 6: 900 7: 900 8: 900
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art avx avx2
bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de
ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc
nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel HD Graphics 630 vendor: Micro-Star MSI driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:591b
Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 455.28 bus ID: 01:00.0 chip ID: 10de:1c20
Device-3: Acer BisonCam NB Pro type: USB driver: uvcvideo bus ID: 1-11:6
chip ID: 5986:0683 serial: <filter>
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: modesetting,nvidia
unloaded: intel,nouveau alternate: fbdev,nv,vesa resolution: 1: 1920x1080~60Hz
2: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 20.1.8
direct render: Yes
Device-1: Intel CM238 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus ID: 00:1f.3 chip ID: 8086:a171
Sound Server: ALSA v: k5.8.16-2-MANJARO
Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi v: kernel
port: e000 bus ID: 02:00.0 chip ID: 8086:24fb
IF: wlp2s0 state: down mac: <filter>
Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet vendor: Micro-Star MSI
driver: alx v: kernel port: d000 bus ID: 03:00.0 chip ID: 1969:e0b1
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Local Storage: total: 1.14 TiB used: 196.04 GiB (16.8%)
ID-1: /dev/sda vendor: SanDisk model: SD9SN8W256G size: 238.47 GiB speed: 6.0 Gb/s
serial: <filter> rev: 7000 scheme: GPT
ID-2: /dev/sdb vendor: HGST (Hitachi) model: HTS721010A9E630 size: 931.51 GiB
speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: A3U0 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUD0N rev: 1.00 dev-links: cdrom
ID-1: / size: 68.22 GiB used: 30.52 GiB (44.7%) fs: ext4 dev: /dev/sda6 label: N/A
uuid: 1bfb7bb9-b827-4db9-bd61-3e4117bb5041
ID-2: /boot/efi size: 296.0 MiB used: 44.5 MiB (15.0%) fs: vfat dev: /dev/sda1
label: SYSTEM uuid: 7427-F937
ID-3: /run/media/florian/Secondary size: 200.00 GiB used: 165.48 GiB (82.7%) fs: ntfs
dev: /dev/sdb2 label: Secondary uuid: 5CCE05FBCE05CDE8
ID-1: /dev/sda2 size: 128.0 MiB fs: <superuser/root required> label: N/A uuid: N/A
ID-2: /dev/sda3 size: 166.80 GiB fs: ntfs label: N/A uuid: 449EAA589EAA41F2
ID-3: /dev/sda4 size: 570.0 MiB fs: ntfs label: N/A uuid: 78EC7F11EC7EC940
ID-4: /dev/sda5 size: 900.0 MiB fs: ntfs label: WinRE tools uuid: 5C3C30503C302802
ID-5: /dev/sdb1 size: 713.97 GiB fs: ntfs label: Data uuid: 225835A25835761F
ID-6: /dev/sdb3 size: 17.54 GiB fs: ntfs label: BIOS_RVY uuid: 5CB63721B636FB5A
Hub: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 1-3:2 info: Holtek USB Laser Game Mouse type: Mouse,Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s chip ID: 04d9:fc12
Device-2: 1-4:3
info: MosArt 2 4Ghz Wireless Transceiver [for Delux M618 Plus Wireless Vertical Mouse]
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
chip ID: 062a:4c01
Device-3: 1-7:4 info: MSI steel series rgb keyboard type: HID driver: usbhid
interfaces: 1 rev: 1.1 speed: 12 Mb/s chip ID: 1770:ff00 serial: <filter>
Device-4: 1-10:5 info: Intel Wireless-AC 3168 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0aa7
Device-5: 1-11:6 info: Acer BisonCam NB Pro type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 5986:0683 serial: <filter>
Device-6: 1-12:7 info: Realtek RTS5129 Card Reader Controller type: <vendor specific>
driver: rtsx_usb,rtsx_usb_ms,rtsx_usb_sdmmc interfaces: 1 rev: 2.0 speed: 480 Mb/s
chip ID: 0bda:0129 serial: <filter>
Hub: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 58.5 C mobo: 27.8 C
Processes: 245 Uptime: 30m Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages:
pacman: 1212 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
