I have recently installed Manjaro on a brand new laptop and everything works without a hitch, except for sleep. It would seem it is one of these laptops with the fancy new deep sleep mode, but the laptop only goes into s2idle mode regardless of what I do, which basically leaves the entire laptop on, but kills my keyboard and touchpad.
What I have tried so far:
Echoing “deep” and “shallow” into /sys/power/mem_sleep - It replies “Invalid Argument” (s2idle works)
Echoing “standby” into /sys/power/state - It replies “Invalid argument” (freeze works)
Moving to 5.7 kernel and 5.9 kernel
Trying to find an EFI setting to force S3 sleep
Googling a whole bunch, without any real results
I am thinking the problem here is that the kernel doesn’t really support shallow and deep modes and I am not enough of a kernel nerd to be able to find out what flags I need to set or what module I have to install to enable this, is anyone able to help with this?
5.4 seems to just “freeze” the entire startup process somehow. If I jump to screen 2 I can log in, but screen 1 is just a frozen cursor. No devices really seem to work, even though I am able to log in, I am assuming because the hardware is from 2020Q4, so probably not at all supported in 5.4.
Sorry for the screenshot, but half the keyboard and the mouse don’t work.
I tried 5.10rc5 and i get the exact same error messages. Except “failed to get backlight” and “snd_soc_register” lines were there twice instead of once. So I am thinking it might be a while before sleep gets supported. This is the only issue I have though, so I think I can live with it for a while.
If it helps at all, the device is a Lenovo Yoga/Thinkpad 7 with the 4500U AMD APU.
