I am new to Linux so I used an old laptop to try it out as a daily driver. Everything went well until I wanted to do some light gaming. It defaulted to the Intel integrated graphics and not to my Nvidia gpu.
Kernel: 5.10.36-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=37f89c3b-8156-483f-a4cc-7530953e4045 ro quiet apparmor=1
security=apparmor resume=UUID=d31181d7-92c0-43dd-b635-10089b4d20e1
udev.log_priority=3
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: MEDION product: X682X v: N/A serial: <filter>
Mobo: MEDION model: X682X serial: <filter> BIOS: American Megatrends
v: E16F3IM7.106 date: 03/29/2012
ID-1: BAT1 charge: 35.4 Wh (90.1%) condition: 39.3/86.6 Wh (45.4%)
volts: 12.2 min: 11.1 model: NEC PC-VP-BP77 type: Li-ion serial: N/A
status: Unknown
RAM: total: 15.53 GiB used: 2.1 GiB (13.5%)
Info: Quad Core model: Intel Core i7-3610QM bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
cache: L2: 6 MiB bogomips: 36728
Speed: 1220 MHz min/max: 1200/3300 MHz Core speeds (MHz): 1: 1220 2: 1198
3: 1197 4: 1198 5: 1262 6: 1197 7: 1851 8: 1781
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida
lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat
pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic xsave
xsaveopt xtopology xtpr
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Micro-Star MSI
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: NVIDIA GF114M [GeForce GTX 670M] driver: N/A
alternate: nouveau, nvidia_drm, nvidia bus-ID: 01:00.0 chip-ID: 10de:1213
class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: intel display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: LVDS1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 21.0.3 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1e20 class-ID: 0403
Device-2: NVIDIA GF114 HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:0e0c class-ID: 0403
Sound Server-1: ALSA v: k5.10.36-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.27 running: no
Device-1: Qualcomm Atheros Killer E220x Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel port: d000 bus-ID: 02:00.0
chip-ID: 1969:e091 class-ID: 0200
Device-2: Intel Centrino Wireless-N 2230 driver: iwlwifi v: kernel
port: d000 bus-ID: 03:00.0 chip-ID: 8086:0887 class-ID: 0280
Local Storage: total: 1006.04 GiB used: 138.41 GiB (13.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSA2CW080G3
size: 74.53 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
rotation: SSD serial: <filter> rev: 0362 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10JPVX-22JC3T0
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 1A01 scheme: MBR
Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SN-208BB rev: SB00
dev-links: cdrom
ID-1: / raw-size: 57.44 GiB size: 56.28 GiB (97.99%) used: 20.29 GiB (36.0%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 37f89c3b-8156-483f-a4cc-7530953e4045
ID-2: /mnt/Backup raw-size: 93.32 GiB size: 91.3 GiB (97.83%)
used: 20.67 GiB (22.6%) fs: ext4 dev: /dev/sdb3 maj-min: 8:19 label: Backup
uuid: b2fda00a-44c8-4662-b879-c9ceb38a849e
ID-3: /mnt/Files raw-size: 372.53 GiB size: 365.61 GiB (98.14%)
used: 44 KiB (0.0%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: Files
uuid: 226999fd-fac4-42b8-950b-1e6f5ca2eb0c
ID-4: /mnt/Program raw-size: 465.66 GiB size: 457.28 GiB (98.20%)
used: 97.45 GiB (21.3%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: Program
uuid: e06a2c0f-e4e9-428b-8891-b229237198dd
ID-1: swap-1 type: partition size: 17.09 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: d31181d7-92c0-43dd-b635-10089b4d20e1
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.4:4 info: MSI steel series rgb keyboard type: HID
driver: usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 2mA
chip-ID: 1770:ff00 class-ID: 0300 serial: <filter>
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 238 Uptime: 1h 01m wakeups: 3 Init: systemd v: 247
tool: systemctl Compilers: gcc: N/A Packages: pacman: 1292 lib: 415
flatpak: 0 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.04
Here is some extra information I could find.
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-390xx-bumblebee 2020.11.30 false PCI
ERROR: NVIDIA driver is not loaded
ERROR: Error querying enabled displays on GPU 0 (Missing Extension).
ERROR: Error querying connected displays on GPU 0 (Missing Extension).
ERROR: nvidia-settings could not find the registry key file. This file should have been installed along with this driver at
/usr/share/nvidia/nvidia-application-profiles-key-documentation. The application profiles will continue to work, but values cannot be prepopulated or validated, and will not be
listed in the help text. Please see the README for possible values and descriptions.
I have 390xx Bumblebee installed, I tried reinstalling it and the distro but nothing seems to work for me. Would anyone have an easy solution for a beginner?
