I recently experience a crash whilst I was updating some of my gnome extensions. Somehow (don’t ask me how) this crashed my entire system and stopped my kernel from loading properly. Luckily I was able to fix the issue, but I have to keep all GNOME extensions disabled. Enabling them causes me DE (I think) to crash, and I have to do a full reboot, login via the terminal and disable all extensions and systemctl restart gdm. I already removed all the extensions that I installed manually but this also happens for the ‘build in’ extensions.
My question is, is there a way that I could debug this? Or at least enable all extensions in their disabled state so I can check which one is causing the issues? Or perhaps force a reinstall/update of all my extensions? I know I could always just delete them all but I’d like to avoid that if possible.
Yes it seems that maybe the extensions app itself might be the issue. As soon as I toggle this button:
GNOME immediatly crashes…
But perhaps with this command I will be able to figure out witch extension causes the crash. I will give it a try later today and report my findings. Thank you
I kind of put this off for a while, but here is the output that I received:
Oct 07 09:36:00 benedikt-latitude3410 kernel: cgroup2: Unknown parameter 'memory_recursiveprot'
Oct 07 09:36:01 benedikt-latitude3410 kernel: proc: Bad value for 'hidepid'
Oct 07 09:36:02 benedikt-latitude3410 wpa_supplicant[973]: nl80211: kernel reports: Attribute failed policy validation
Oct 07 09:36:02 benedikt-latitude3410 wpa_supplicant[973]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Oct 07 09:36:02 benedikt-latitude3410 wpa_supplicant[973]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Oct 07 09:36:04 benedikt-latitude3410 bluetoothd[979]: src/adapter.c:reset_adv_monitors_complete() Failed to reset Adv Monitors: Unknown Command (0x01)
Oct 07 09:36:04 benedikt-latitude3410 kernel: proc: Bad value for 'hidepid'
Oct 07 09:36:04 benedikt-latitude3410 wpa_supplicant[973]: dbus: wpa_dbus_get_object_properties: failed to get object properties: (org.freedesktop.DBus.Error.Failed) failed to parse RSN IE
Oct 07 09:36:04 benedikt-latitude3410 wpa_supplicant[973]: dbus: Failed to construct signal
Oct 07 09:36:07 benedikt-latitude3410 wpa_supplicant[973]: dbus: wpa_dbus_get_object_properties: failed to get object properties: (org.freedesktop.DBus.Error.Failed) failed to parse RSN IE
Oct 07 09:36:07 benedikt-latitude3410 wpa_supplicant[973]: dbus: Failed to construct signal
Oct 07 09:36:07 benedikt-latitude3410 kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x707
Oct 07 09:36:08 benedikt-latitude3410 kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x707
Oct 07 09:36:08 benedikt-latitude3410 kernel: iwlwifi 0000:00:14.3: No beacon heard and the time event is over already...
Oct 07 09:36:10 benedikt-latitude3410 kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x707
Oct 07 09:41:02 benedikt-latitude3410 gdm-launch-environment][716]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Oct 07 09:41:04 benedikt-latitude3410 kernel: proc: Bad value for 'hidepid'
Oct 07 09:41:05 benedikt-latitude3410 kernel: proc: Bad value for 'hidepid'
Oct 07 09:41:19 benedikt-latitude3410 gdm-password][2836]: gkr-pam: unable to locate daemon control file
Oct 07 09:41:29 benedikt-latitude3410 gdm-launch-environment][2553]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Oct 07 09:41:34 benedikt-latitude3410 kernel: proc: Bad value for 'hidepid'
And the previous boot:
Jun 15 13:11:29 benedikt-latitude3410 kernel: Bluetooth: hci0: advertising data len corrected 20 -> 19
Jun 15 13:11:30 benedikt-latitude3410 kernel: Bluetooth: hci0: advertising data len corrected 20 -> 19
Jun 15 13:11:31 benedikt-latitude3410 kernel: Bluetooth: hci0: advertising data len corrected 20 -> 19
Jun 15 13:11:34 benedikt-latitude3410 kernel: Bluetooth: hci0: advertising data len corrected 20 -> 19
Jun 15 13:11:57 benedikt-latitude3410 kernel: Bluetooth: hci0: advertising data len corrected 20 -> 19
Jun 16 08:30:32 benedikt-latitude3410 kernel: usb 1-2: 1:1: cannot get freq at ep 0x81
Jun 16 08:30:32 benedikt-latitude3410 kernel: usb 1-2: 4:1: cannot get freq at ep 0x2
Jun 16 11:02:50 benedikt-latitude3410 kernel: Out of memory: Killed process 38258 (spotify) total-vm:14585444kB, anon-rss:311208kB, file-rss:0kB, shmem-rss:784kB, UID:1000 pgtables:2240kB oom_score_adj:300
Jun 16 11:14:40 benedikt-latitude3410 gdm[894]: Gdm: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
Jun 16 11:14:40 benedikt-latitude3410 systemd-coredump[196010]: Failed to connect to coredump service: Connection refused
Jun 16 11:14:45 benedikt-latitude3410 systemd-coredump[196451]: Failed to connect to coredump service: Connection refused
Jun 16 11:16:10 benedikt-latitude3410 systemd-cryptsetup[196459]: Device luks-e5c29191-0c87-43e9-bc95-0b67ef689310 is still in use.
Jun 16 11:16:10 benedikt-latitude3410 systemd-cryptsetup[196459]: Failed to deactivate: Device or resource busy
Jun 16 11:16:10 benedikt-latitude3410 kernel: watchdog: watchdog0: watchdog did not stop!
