context:
My Laptop currently is 4 years old. Mainly divided into one 500 GB partition on sda3 one 243 GB partition on sd4 and one 183 GB partition on sda5. I previously ran Windows on the aforementioned 500 GB disk. I had reinstalled windows multiple times. I then made a dual boot system with Manjaro running on sda5 on ext4. When i was ready to completely shift my system i reformatted my NTFS windows partition to ext4 and used as my main storage, but the partition was not being recognized properly. I consulted the fourm : Manjaro not recognizing other Partitions
I tweaked my Fstab and then it started working fine. After a while the hard drive crashed but after and fsck it started working but showed bad sectors.
Today when I came home, the ext4 partition was registering as an unknown partition type in Manjros Gnome Disk Utility.
I ran fsck, which was able to recognize it was an ext4 partition, but showed the following error:
username@systemname ~> sudo fsck /dev/sda3 (base)
[sudo] password for alux:
fsck from util-linux 2.36.1
e2fsck 1.45.6 (20-Mar-2020)
fsck.ext2: Input/output error while trying to open /dev/sda3
The superblock could not be read or does not describe a valid ext2/ext3/ext4
filesystem. If the device is valid and it really contains an ext2/ext3/ext4
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193 <device>
or
e2fsck -b 32768 <device>
after running e2fsck -b 8193 /dev/sda3
username@systemname ~ [8]> sudo e2fsck -b 8193 /dev/sda3 (base)
e2fsck: Bad magic number in super-block while trying to open /dev/sda3
or
I tried running e2fsck -b 32768 It runs and find alot of the following type errors:
Free inodes count wrong for group #2304 (8192, counted=5109).
Fix<y>? yes
Directories count wrong for group #2304 (0, counted=600).
Fix<y>? yes
Then the following error pops:
Padding at end of inode bitmap is not set. Fix<y>? yes
Error writing block 1 (Input/output error). Ignore error<y>? yes
/dev/sda3: ***** FILE SYSTEM WAS MODIFIED *****
/dev/sda3: 317558/32923648 files (0.6% non-contiguous), 86272400/131664384 blocks
username@systemname ~ [1]>
and abruptly shutsdown.
I dont care about getting the partition working. I have ordered a new hard drive to replace this. There are a bunch of important pictures on this partition. Is there anyway to recover it.
Even paid services would be fine, but I wish to recover as much as i can from it.
Any methods to recover it?
