Hi,
I am struggling to get the touchscreen deactivated on a Thinkpad Yoga 12. The simple reason is that I get “ghost” touches which sometimes comes even hundreds of times per minute, mostly bringing the mouse cursor jumping near to the screen border. Ideally I want those be gone, but on the device I don’t need the touchscreen that much any more.
Moreover, as I am not sure what causes this presses and the Laptop has a pen input with a passive Wacom too which may be the actual cause and not the touchscreen, I want to deactivate that too.
The laptop was installed around half a year ago with the at the time newest Manjaro KDE and regularly updated via package manager. I am using a Wayland session on KDE.
I already tried with those methods (in parallel, all used the same time):
- Disabling via udev rules:
A 80-touchscreen.rules file is therefore in /etc/udev/rules.d/:
SUBSYSTEM=="usb", ATTRS{idVendor}=="06cb", ATTRS{idProduct}=="7244", ATTRS{authorized}="0"
SUBSYSTEM=="usb", ATTRS{idVendor}=="06cb", ATTRS{idProduct}=="0000", ATTRS{authorized}="0"
SUBSYSTEM=="usb", ATTRS{idVendor}=="06cb", ATTRS{authorized}="0"
SUBSYSTEM=="usb", ATTRS{idVendor}=="056a", ATTRS{authorized}="0"
As seen, I tried to deactivate the components indepentenly for the touchscreen, and afterwards added also a vendor-specific blocking for the Synaptics/Wacom devices (the last two lines).
- Using xorg.conf files, but here I could only set MatchTouchscreen to “off”. When I add Option “Ignore” “on” to the sections for Touchscreen and pointer, all other input hardware is deactivated too (namely touchpad, keyboard and even USB mice/keyboards). I think this is already a problem here but I don’t know why this Option is going over all hardware as it is inside the Section as in the post, see /usr/share/X11/xorg.conf.d/10-evdev.conf
# Catch-all evdev loader for udev-based systems
# We don't simply match on any device since that also adds accelerometers
# and other devices that we don't really want to use. The list below
# matches everything but joysticks.
Section "InputClass"
Identifier "evdev pointer catchall"
MatchIsPointer "off"
MatchDevicePath "/dev/input/event*"
Driver "evdev"
EndSection
Identifier "evdev keyboard catchall"
MatchIsKeyboard "on"
Driver "evdev"
EndSection
Identifier "evdev touchpad catchall"
MatchIsTouchpad "on"
Driver "evdev"
EndSection
Identifier "evdev tablet catchall"
MatchIsTablet "off"
Driver "evdev"
EndSection
Identifier "evdev touchscreen catchall"
MatchIsTouchscreen "off"
Driver "evdev"
EndSection
and /usr/share/X11/xorg.conf.d/40-libinput.conf
# Match on all types of devices but joysticks
# If you want to configure your devices, do not copy this file.
# Instead, use a config snippet that contains something like this:
# Section "InputClass"
# Identifier "something or other"
# MatchDriver "libinput"
# MatchIsTouchpad "on"
# ... other Match directives ...
# Option "someoption" "value"
# EndSection
# This applies the option any libinput device also matched by the other
# directives. See the xorg.conf(5) man page for more info on
# matching devices.
Identifier "libinput pointer catchall"
Driver "libinput"
EndSection
Identifier "libinput keyboard catchall"
Driver "libinput"
EndSection
Identifier "libinput touchpad catchall"
Driver "libinput"
EndSection
Identifier "libinput touchscreen catchall"
Driver "libinput"
EndSection
Identifier "libinput tablet catchall"
MatchIsTablet "off"
Driver "libinput"
EndSection
for this.
- Lastly I tried the deactivation via xinput, but the only noticeable difference is via either
xinput disable 7
or
xinput set-prop 7 120 0
but this only deactivates the pointer within firefox, the other ids do not seem to disable any touch.
Additionally, any setting via input triggers the warning:
WARNING: running xinput against an Xwayland server. See the xinput man page for details.
But of course as I am using wayland, this does not seem a problem.
Is there any error in this approach? Or is it done completely different under Wayland?
