Hi all,
dbus-x11 is an AUR package, and it’s “explicitly installed” by me. However, I forgot why, and I believe it used to be a package from the official repositories.
My question is; has it been deprecated? And can I safely delete it?
Hi all,
You can likely install dbus which will ask if you want to replace dbus-x11 with it and you just say yes to that.
didnt work, could not install dbus:
conflicting dependencies:
- dbus-nosystemd and dbus-x11 are in conflict
Why do you have dbus-nosystemd installed or try to install it?
It’s an AUR package, that has not been updated in almost 2 years.
i dont have dbus-nosystemd installed, i have dbus-x11 installed and when i try to install dbus, that is the error message i get.
Try with sudo pacman -S dbus.
Post all output if it complains.
Does not compute. Why would you see that message if you didn’t?
Full logs, please. See [HowTo] Request support
FYI, dbus-nosystemd is only in the AUR for folks that think they can use Arch (or Arch-based distros like Manjaro) without systemd. There are other distros that don’t use systemd they should probably use instead.
Install dbus with the following command and answer y for all conflicts:
sudo pacman -Syu dbus
it worked with this command, no problems. prior to install, it asked to remove dbus-x11, and I did.
Same problem here! dbus-nosystemd is not installed but get error message if I want to update my system.
Error Msg: “In Konflikt stehende Abhängigkeiten: - dbus-nosystemd und dbus-x11 stehen im Konflikt zueinander”
After that I can edit the buildfiles for openssl-1.0 and dbus-x11.
Why openssl-1.0 it’s rather old. (but installed, dont know why, will remove it cause openssl-1.1 is installed)
lib32-dbus-nosystemd-git 1.12.20-1 AUR
dbus-nosystemd-minimal-git 1.12.20-1 AUR
dbus-nosystemd 1.12.20-1 AUR
dbus-elogind 1.10.18-1 AUR
dbus-x11-docs 1.15.0-2 AUR
dbus-x11 [Installiert] 1.14.4-1 AUR
Arch dropped it from the repos to the AUR just recently.
Worked for me. Thanks!
