Upon launching DaVinci Resolve a pop-up window appears regarding “Reviewing GPU Configuration”
Fatal error: "Review GPU Configuration?", "DaVinci Resolve could not find CUDA capable GPUs.<br>Please review the GPU drivers and GPU configuration under preferences.<ul></ul>"
Urgent message: CRITICAL_PREF: Review GPU Configuration?||DaVinci Resolve could not find CUDA capable GPUs.<br>Please review the GPU drivers and GPU configuration under preferences.<ul></ul>
After checking and messing with settings, whenever I try to select a GPU and save my settings, it asks me to pick a media storage location. After clicking OK, DaVinci closes all suddenly.
Even picking a media storage volume, crashes the programm.
I’ve checked this tool called DaVinci Resolve Checker and it returns me this:
DaVinci Resolve checker 1.4.4 Installed DaVinci Resolve package: davinci-resolve 17.1-3 Chassis type: desktop Installed OpenCL drivers: opencl-nvidia Presented GPUs: GP104 [GeForce GTX 1070] (kernel driver in use: vfio-pci) GK208B [GeForce GT 710] (kernel driver in use: nvidia) OpenGL vendor string: NVIDIA CorporationYou have several NVIDIA GPUs. I am confused. Which one do you intend to use?
Here’s my log from open until crash.
0x7ff2072c5600 | Main | INFO | 2021-04-06 13:35:17,082 | Running DaVinci Resolve v17.1.0.0024 (Linux/Clang x86_64)
0x7ff2072c5600 | Main | INFO | 2021-04-06 13:35:17,082 | BMD_BUILD_UUID 8b9102ed-137f-4151-8202-8c88e3d43bc8
0x7ff2072c5600 | Main | INFO | 2021-04-06 13:35:17,082 | BMD_GIT_COMMIT 5b371db7cafb184ffaac29f3843b849f765fc644
0x7ff2072c5600 | GPUDetect | INFO | 2021-04-06 13:35:17,082 | Starting GPUDetect 1.1_2-a16
0x7ff2072c5600 | GPUDetect | ERROR | 2021-04-06 13:35:17,114 | NVML Error Not Supported (3): Querying device current PCI generation
0x7ff2072c5600 | GPUDetect | ERROR | 2021-04-06 13:35:17,114 | NVML Error Not Supported (3): Querying device max PCI generation
0x7ff2072c5600 | GPUDetect | ERROR | 2021-04-06 13:35:17,114 | NVML Error Not Supported (3): Querying device current PCI link width
0x7ff2072c5600 | GPUDetect | ERROR | 2021-04-06 13:35:17,115 | NVML Error Not Supported (3): Querying device max PCI link width
0x7ff2072c5600 | GPUDetect | INFO | 2021-04-06 13:35:17,118 | Done in 35 ms.
0x7ff2072c5600 | GPUDetect | INFO | 2021-04-06 13:35:17,118 | Detected System:
0x7ff2072c5600 | GPUDetect | INFO | 2021-04-06 13:35:17,118 | - OS: Linux Manjaro
0x7ff2072c5600 | GPUDetect | INFO | 2021-04-06 13:35:17,118 | - Model: Gigabyte X570 AORUS PRO
0x7ff2072c5600 | GPUDetect | INFO | 2021-04-06 13:35:17,118 | - System ID: 8365f6f010b04848a8a1f5a03fed9414
0x7ff2072c5600 | GPUDetect | INFO | 2021-04-06 13:35:17,118 | - CPU: AMD Ryzen 9 3900X, 24 threads, x86-64
0x7ff2072c5600 | GPUDetect | INFO | 2021-04-06 13:35:17,118 | - RAM: 20.5 GiB used of 31.3 GiB
0x7ff2072c5600 | GPUDetect | INFO | 2021-04-06 13:35:17,118 | - NVIDIA Driver: 460.56, supports CUDA 11.2
0x7ff2072c5600 | GPUDetect | INFO | 2021-04-06 13:35:17,118 | Detected 1 GPUs:
0x7ff2072c5600 | GPUDetect | INFO | 2021-04-06 13:35:17,118 | - "NVIDIA GeForce GT 710" (gpu:94b4b6d3.24e4087f) <- Main Display GPU
0x7ff2072c5600 | GPUDetect | INFO | 2021-04-06 13:35:17,118 | Discrete, 323 MiB used of 932 MiB VRAM, PCI:13:0.0
0x7ff2072c5600 | GPUDetect | INFO | 2021-04-06 13:35:17,118 | Matches: CUDA, NVML, OpenCL, XOrg
0x7ff2072c5600 | GPUDetect | INFO | 2021-04-06 13:35:17,118 | Detected 1 monitors:
0x7ff2072c5600 | GPUDetect | INFO | 2021-04-06 13:35:17,118 | - "Monitor" <- Main Monitor
0x7ff2072c5600 | GPUDetect | INFO | 2021-04-06 13:35:17,118 | 3000x1920, connected to "NVIDIA GeForce GT 710" (gpu:94b4b6d3.24e4087f)
0x7ff2072c5600 | Main.GPUConfig | INFO | 2021-04-06 13:35:17,118 | Compute API set to automatic, defaulting to CUDA.
0x7ff2072c5600 | Main.GPUConfig | INFO | 2021-04-06 13:35:17,118 | Selected compute API: CUDA
0x7ff2072c5600 | Main.GPUConfig | INFO | 2021-04-06 13:35:17,118 | Automatic GPU Selection:
0x7ff2072c5600 | IO | INFO | 2021-04-06 13:35:17,118 | RED InitializeSdk with library path at /opt/resolve/libs
0x7ff2072c5600 | IO | INFO | 2021-04-06 13:35:17,143 | R3DAPI 8.0.0-49A09 (20201217 Lx64S) R3DSDK 8.0.0-49A09 (20201217 Lx64D C3B1) RED CUDA 8.0.0-50396 (20201217) [/opt/resolve/libs/] init is successful
0x7ff2072c5600 | Main | INFO | 2021-04-06 13:35:17,143 | 0 RED rocket cards available
libDeckLinkAPI.so: cannot open shared object file: No such file or directory
0x7ff2072c5600 | Main | INFO | 2021-04-06 13:35:17,143 | Decklink model name: '', version: ''
0x7ff2072c5600 | DVIP | INFO | 2021-04-06 13:35:17,143 | DVIP release/17.1 build 35 (db6ea058cd9b335e602984b011c11cca73266561). Release, version 17.1.0.
0x7ff2072c5600 | Main | INFO | 2021-04-06 13:35:17,363 | Installed custom font: Open Sans
0x7ff2072c5600 | Main | INFO | 2021-04-06 13:35:17,364 | Installed custom font: Open Sans
0x7ff2072c5600 | Main | INFO | 2021-04-06 13:35:17,374 | Finished loading Application style sheet
Local.Speed.Debug switched OFF - ''
0x7ff2072c5600 | BtCommon | INFO | 2021-04-06 13:35:17,510 | Memory config: reserved=6000M pinned=4500M log=0
0x7ff2072c5600 | BtCommon | INFO | 2021-04-06 13:35:17,510 | Using default pooled memory manager
0x7ff1cfc6d640 | LeManager | INFO | 2021-04-06 13:35:17,510 | 521, 29
0x7ff1cec6b640 | BtCommon | INFO | 2021-04-06 13:35:17,510 | BtResourceManager Process Thread Started
0x7ff2072c5600 | BtCommon | INFO | 2021-04-06 13:35:17,510 | Daemon DPDecoder is started 28740
0x7ff2072c5600 | BtCommon | INFO | 2021-04-06 13:35:17,510 | Daemon DPDecoder is started 28741
0x7ff2072c5600 | BtCommon | INFO | 2021-04-06 13:35:17,510 | Daemon DPDecoder is started 28742
0x7ff2072c5600 | BtCommon | INFO | 2021-04-06 13:35:17,510 | Daemon DPDecoder is started 28743
0x7ff2072c5600 | BtCommon | INFO | 2021-04-06 13:35:17,510 | Daemon DPDecoder is started 28744
0x7ff2072c5600 | BtCommon | INFO | 2021-04-06 13:35:17,510 | Daemon DPDecoder is started 28745
0x7ff2072c5600 | BtCommon | INFO | 2021-04-06 13:35:17,511 | Daemon DPDecoder is started 28746
0x7ff2072c5600 | BtCommon | INFO | 2021-04-06 13:35:17,511 | Daemon DPDecoder is started 28747
0x7ff2072c5600 | SyManager | INFO | 2021-04-06 13:35:17,515 | Total: 20, NumDtThreads: 8, NumComms: 0, NumSites: 1
0x7ff2072c5600 | SyManager | INFO | 2021-04-06 13:35:17,515 | Lookaheads -> playback = 20, record = 20, stop = 1
Sy High Command Handler Thread ----- (140676499404352)
SY high priority cmd handler thread starts: CCC67640
Sy Data Handler Thread ----- (140676482618944)
SY data handler thread starts: CBC65640
Sy Low Command Handler Thread ----- (140676491011648)
SY low priority cmd handler thread starts: CC466640
Gs High Command Handler Thread ----- (140676457440832)
GS high priority cmd handler thread starts: CA462640
0x7ff1c9460640 | GsManager | INFO | 2021-04-06 13:35:17,515 | Gs Processor Thread ----- (140676440655424)
GS processor thread starts: C9460640
Local.Speed.Verbose switched OFF - ''
Gs Low Command Handler Thread ----- (140676449048128)
GS low priority cmd handler thread starts: C9C61640
Dp High Command Handler Thread ----- (140676432262720)
DP high priority cmd handler thread starts: C8C5F640
Dp Low Command Handler Thread ----- (140676423870016)
DP low priority cmd handler thread starts: C845E640
Dt Low Command Handler Thread ----- (140676407084608)
DT low priority cmd handler thread starts: C745C640
0x7ff1cac63640 | SyManager | ERROR | 2021-04-06 13:35:17,515 | Failed to connect to panel socket
Dt High Command Handler Thread ----- (140676415477312)
DT high priority cmd handler thhread starts: C7C5D640
0x7ff2072c5600 | DtManager | INFO | 2021-04-06 13:35:17,515 | Using 8 generic IO threads
0x7ff1cac63640 | SyManager | ERROR | 2021-04-06 13:35:17,515 | DRIVER: open /var/tmp/davinci_socket failed
0x7ff2072c5600 | DtManager | INFO | 2021-04-06 13:35:17,515 | Total of 16 IO threads (including 8 generic and 8 Red decode threads)
0x7ff1c6c5b640 | DtManager | INFO | 2021-04-06 13:35:17,515 | Dt Data Handler Thread Started
DT data handler thread starts: C6C5B640
0x7ff1c645a640 | DtManager | INFO | 2021-04-06 13:35:17,515 | Dt Worker Thread Started
0x7ff1c4c57640 | DtManager | INFO | 2021-04-06 13:35:17,515 | Dt Worker Thread Started
0x7ff1c5458640 | DtManager | INFO | 2021-04-06 13:35:17,515 | Dt Worker Thread Started
0x7ff1c2c53640 | DtManager | INFO | 2021-04-06 13:35:17,515 | Dt Worker Thread Started
0x7ff1c5c59640 | DtManager | INFO | 2021-04-06 13:35:17,515 | Dt Worker Thread Started
0x7ff1c3c55640 | DtManager | INFO | 2021-04-06 13:35:17,515 | Dt Worker Thread Started
0x7ff1bfc4e640 | DtManager | INFO | 2021-04-06 13:35:17,516 | Dt Worker Thread Started
0x7ff1c2452640 | DtManager | INFO | 2021-04-06 13:35:17,515 | Dt Worker Thread Started
0x7ff1c4456640 | DtManager | INFO | 2021-04-06 13:35:17,515 | Dt Worker Thread Started
Ls High Command Handler Thread ----- (140676188898880)
Ls Data Handler Thread ----- (140676172113472)
0x7ff1be44d640 | DtManager | INFO | 2021-04-06 13:35:17,516 | Dt Worker Thread Started
Ls Low Command Handler Thread ----- (140676180506176)
LS low priority cmd handler thread starts: B9C47640
Ls Low Command Handler Thread ----- (140676155328064)
0x7ff1bc84c640 | DtManager | INFO | 2021-04-06 13:35:17,516 | Dt Worker Thread Started
LS data handler thread starts: B9446640
LS low priority cmd handler thread starts: B8444640
Ls High Command Handler Thread ----- (140676163720768)
0x7ff1c0c4f640 | DtManager | INFO | 2021-04-06 13:35:17,516 | Dt Worker Thread Started
Ls Data Handler Thread ----- (140676146935360)
LS data handler thread starts: B7C43640
0x7ff1c1c51640 | DtManager | INFO | 2021-04-06 13:35:17,516 | Dt Worker Thread Started
Ls Low Command Handler Thread ----- (140676130149952)
Ls Data Handler Thread ----- (140676121757248)
Ls High Command Handler Thread ----- (140676138542656)
0x7ff1bbc4b640 | DtManager | INFO | 2021-04-06 13:35:17,516 | Dt Worker Thread Started
LS low priority cmd handler thread starts: B6C41640Mem Data Transmitter Thread ----- (140676113364544)
0x7ff1c3454640 | DtManager | INFO | 2021-04-06 13:35:17,515 | Dt Worker Thread Started
Mem data transmitter thread starts: B5C3F640
0x7ff1c1450640 | DtManager | INFO | 2021-04-06 13:35:17,516 | Dt Worker Thread Started
0x7ff1bb44a640 | DtManager | INFO | 2021-04-06 13:35:17,516 | Dt Worker Thread Started
0x7ff1bac49640 | DtManager | INFO | 2021-04-06 13:35:17,516 | Dt Worker Thread Started
0x7ff2072c5600 | DbCommon2 | INFO | 2021-04-06 13:35:17,516 | Loading dblist file: /home/pnk2/.local/share/DaVinciResolve/configs/.dblist
/opt/resolve/bin/BlackmagicRawAPI/libBlackmagicRawAPI.so: cannot open shared object file: No such file or directory
/opt/resolve/bin/libBlackmagicRawAPI.so: cannot open shared object file: No such file or directory
0x7ff2072c5600 | IO | INFO | 2021-04-06 13:35:17,520 | Using DNxHR library v2.6.1.19r
0x7ff1b6440640 | GPU.MultiBoardMgr | ERROR | 2021-04-06 13:35:17,521 | Fatal error: "Review GPU Configuration?", "DaVinci Resolve could not find CUDA capable GPUs.<br>Please review the GPU drivers and GPU configuration under preferences.<ul></ul>"
0x7ff1b6440640 | IP | ERROR | 2021-04-06 13:35:17,521 | Failed to initialize multi board manager
LS data handler thread starts: B6440640
0x7ff2072c5600 | IO | INFO | 2021-04-06 13:35:17,522 | Kdu ctx(0), bundle(0), thds(3)
0x7ff2072c5600 | IO | INFO | 2021-04-06 13:35:17,522 | Kdu ctx(3), bundle(0), thds(3)
0x7ff2072c5600 | IO | INFO | 2021-04-06 13:35:17,522 | Kdu ctx(6), bundle(0), thds(3)
0x7ff2072c5600 | IO | INFO | 2021-04-06 13:35:17,522 | Kdu ctx(9), bundle(0), thds(3)
0x7ff2072c5600 | IO | INFO | 2021-04-06 13:35:17,522 | Kdu ctx(12), bundle(0), thds(3)
0x7ff2072c5600 | IO | INFO | 2021-04-06 13:35:17,522 | Kdu ctx(15), bundle(0), thds(3)
0x7ff2072c5600 | IO | INFO | 2021-04-06 13:35:17,522 | Kdu ctx(18), bundle(0), thds(3)
0x7ff2072c5600 | IO | INFO | 2021-04-06 13:35:17,522 | Kdu ctx(21), bundle(0), thds(3)
0x7ff2072c5600 | UI.GLContext | INFO | 2021-04-06 13:35:17,631 | Creating shared OpenGL context for this thread (1 total).
0x7ff2072c5600 | UI.GLContext | INFO | 2021-04-06 13:35:17,684 | Initialized OpenGL 4.6 (requested 2.0) on device 'NVIDIA Corporation GeForce GT 710/PCIe/SSE2'
0x7ff2072c5600 | Fairlight | INFO | 2021-04-06 13:35:18,044 | 00.00.00.175(000): Running Fairlight (4b30d57b41b69ceb9ccbb9741f4a408182be4bb1)
0x7ff2072c5600 | FairlightLoader | INFO | 2021-04-06 13:35:18,044 | Fairlight lib loaded in 360 ms.
All textures are loaded : 1.
0x7ff2072c5600 | Fusion | INFO | 2021-04-06 13:35:18,205 | Fusion Build: 10b389e8_0043 (Mar 4 2021 14:25:49)
0x7ff2072c5600 | Fusion | INFO | 2021-04-06 13:35:18,205 | fusionsystem: = "/opt/resolve/libs/Fusion/libfusionsystem.so"
0x7ff2072c5600 | Fusion | INFO | 2021-04-06 13:35:18,208 | FusionLibs: = "/opt/resolve/libs/Fusion/"
0x7ff2072c5600 | Fusion | INFO | 2021-04-06 13:35:18,208 | UserData: = "/home/pnk2/.local/share/DaVinciResolve/Fusion"
0x7ff2072c5600 | Fusion | INFO | 2021-04-06 13:35:18,208 | Profiles: = "UserData:Profiles/"
0x7ff11ae09640 | UI.GLContext | INFO | 2021-04-06 13:35:18,232 | Creating shared OpenGL context for this thread (2 total).
0x7ff11ae09640 | UI.GLIO | INFO | 2021-04-06 13:35:18,310 | Initialized MainPlayer OpenGL I/O on CUDA device 'GeForce GT 710'
0x7ff2072c5600 | UI.GLIO | INFO | 2021-04-06 13:35:18,310 | MainPlayer: OpenGL I/O setup done.
0x7ff115d04640 | UI.GLContext | INFO | 2021-04-06 13:35:18,310 | Creating shared OpenGL context for this thread (3 total).
0x7ff115d04640 | UI.GLIO | INFO | 2021-04-06 13:35:18,324 | Initialized AuxPlayer OpenGL I/O on CUDA device 'GeForce GT 710'
0x7ff2072c5600 | UI.GLIO | INFO | 2021-04-06 13:35:18,324 | AuxPlayer: OpenGL I/O setup done.
0x7ff1153c3640 | UI.GLContext | INFO | 2021-04-06 13:35:18,324 | Creating shared OpenGL context for this thread (4 total).
0x7ff1153c3640 | UI.Scopes | INFO | 2021-04-06 13:35:18,337 | Initialized GPU Scopes Manager on CUDA device 'GeForce GT 710'
0x7ff2072c5600 | UI | ERROR | 2021-04-06 13:35:18,415 | Failed to find text 'Apple ProRes' in combo-box
0x7ff2072c5600 | UI | WARN | 2021-04-06 13:35:18,415 | Failed to find value '0' in combo-box
libScannerAPI.so: cannot open shared object file: No such file or directory
0x7ff2072c5600 | UI.MenuBar | WARN | 2021-04-06 13:35:18,488 | Main menu action [workspaceLayoutFusion_sub001Default]'s slot is not defined: workspaceLayoutFusion_sub001Default_triggered()
0x7ff2072c5600 | DbCommon2 | INFO | 2021-04-06 13:35:18,499 | Sm2SysIdEntry is not supported in disk database (xml) mode
0x7ff113588640 | SyManager | INFO | 2021-04-06 13:35:18,500 | Starting keyboard device monitor thread...
SY panel handler thread starts: CAC63640
0x7ff1cac63640 | SyManager | ERROR | 2021-04-06 13:35:18,517 | Failed to connect to panel socket
0x7ff2072c5600 | UI | WARN | 2021-04-06 13:35:18,601 | Failed to find value '0' in combo-box
0x7ff2072c5600 | UI | WARN | 2021-04-06 13:35:18,721 | Failed to load media metadata preset list or the list is empty.
0x7ff2072c5600 | UI | WARN | 2021-04-06 13:35:18,729 | Failed to load media metadata preset list or the list is empty.
0x7ff2072c5600 | UI.ActionManager | WARN | 2021-04-06 13:35:18,896 | Action [fairlightBusStructure] is not a global action
0x7ff2072c5600 | UI.ActionManager | WARN | 2021-04-06 13:35:18,896 | Action [fairlightImmersiveGenerateImmersiveMaster] is not a valid global action
0x7ff2072c5600 | UI.ActionManager | WARN | 2021-04-06 13:35:18,896 | Action [fairlightImmersiveRendererSettings] is not a valid global action
0x7ff2072c5600 | UI | WARN | 2021-04-06 13:35:19,767 | Failed to load media metadata preset list or the list is empty.
0x7ff2072c5600 | UI | WARN | 2021-04-06 13:35:19,769 | Failed to load media metadata preset list or the list is empty.
0x7ff2072c5600 | UI | WARN | 2021-04-06 13:35:19,866 | Failed to load media metadata preset list or the list is empty.
0x7ff2072c5600 | UI | WARN | 2021-04-06 13:35:19,868 | Failed to load media metadata preset list or the list is empty.
0x7ff2072c5600 | UI | WARN | 2021-04-06 13:35:20,526 | Failed to load media metadata preset list or the list is empty.
0x7ff2072c5600 | UI | WARN | 2021-04-06 13:35:20,530 | Failed to load media metadata preset list or the list is empty.
0x7ff2072c5600 | UI | INFO | 2021-04-06 13:35:20,756 | Not creating special GL widget for screen 0
0x7ff2072c5600 | UI.ActionManager | WARN | 2021-04-06 13:35:21,006 | Action [sessionDolbyVisionAnalyzeAllShots] is not a valid global action
0x7ff2072c5600 | UI.ActionManager | WARN | 2021-04-06 13:35:21,006 | Action [sessionDolbyVisionAnalyzeSelectedShots] is not a valid global action
0x7ff2072c5600 | UI.ActionManager | WARN | 2021-04-06 13:35:21,006 | Action [sessionDolbyVisionAnalyzeSelectedAndGroup] is not a valid global action
0x7ff2072c5600 | UI.ActionManager | WARN | 2021-04-06 13:35:21,006 | Action [sessionDolbyVisionAnalyzeCurrentFrame] is not a valid global action
0x7ff2072c5600 | UI.ActionManager | WARN | 2021-04-06 13:35:21,006 | Action [sessionHDR10PlusAnalyzeAllShots] is not a valid global action
0x7ff2072c5600 | UI.ActionManager | WARN | 2021-04-06 13:35:21,006 | Action [sessionHDR10PlusAnalyzeSelectedShots] is not a valid global action
0x7ff2072c5600 | UI.ActionManager | WARN | 2021-04-06 13:35:21,006 | Action [sessionHDR10PlusAnalyzeSelectedAndGroup] is not a valid global action
0x7ff2072c5600 | UI.ActionManager | WARN | 2021-04-06 13:35:21,006 | Action [sessionHDR10PlusAnalyzeCurrentFrame] is not a valid global action
0x7ff2072c5600 | UI | WARN | 2021-04-06 13:35:21,084 | Failed to find value '8192' in combo-box
0x7ff2072c5600 | UI | WARN | 2021-04-06 13:35:21,137 | Failed to find value '100' in combo-box
0x7ff2072c5600 | UI.MenuBar | WARN | 2021-04-06 13:35:21,392 | Plugged In Action [workspace_sub1_menu5_triggered()] is owned by [0x7ff106905060]
0x7ff2072c5600 | UI.MenuBar | WARN | 2021-04-06 13:35:21,392 | Plugged In Action [workspace_sub1_sub001_triggered()] is owned by [0x7ff106905060]
0x7ff2072c5600 | UI.MenuBar | WARN | 2021-04-06 13:35:21,392 | Plugged In Action [workspace_sub1_sub002_triggered()] is owned by [0x7ff106905060]
0x7ff2072c5600 | UI.MenuBar | WARN | 2021-04-06 13:35:21,392 | Plugged In Action [workspace_sub1_sub003_triggered()] is owned by [0x7ff106905060]
0x7ff2072c5600 | UI.MenuBar | WARN | 2021-04-06 13:35:21,392 | Plugged In Action [workspace_sub1_sub004_triggered()] is owned by [0x7ff106905060]
****************** Flushing GPU Buffers
0x7ff2072c5600 | IO | WARN | 2021-04-06 13:35:21,444 | Plugin Repository :: Codec uuid not found
0x7ff2072c5600 | IO | INFO | 2021-04-06 13:35:21,452 | RED rocket decode has been disabled in the config file
0x7ff2072c5600 | UI | WARN | 2021-04-06 13:35:21,518 | Failed to find value '0' in combo-box
0x7ff2072c5600 | UI | WARN | 2021-04-06 13:35:21,519 | Failed to find value '0' in combo-box
0x7ff0dd8e4640 | UI | ERROR | 2021-04-06 13:35:25,580 | UiAutoUpdateController: Failed to get response from server (responseCode:2) (httpStatus:-1) (response:)
static QPlatformTheme *QKdeTheme::createKdeTheme(): Unable to determine KDE dirs
MidiInDummy: This class provides no functionality.
MidiOutDummy: This class provides no functionality.
0x7ff2072c5600 | UI | WARN | 2021-04-06 13:35:28,875 | Failed to find value '0' in combo-box
0x7ff2072c5600 | UI | WARN | 2021-04-06 13:35:28,875 | Failed to find value '-1' in combo-box
0x7ff113588640 | SyManager | INFO | 2021-04-06 13:35:34,416 | Exiting keyboard device monitor thread.
0x7ff2072c5600 | SyManager | INFO | 2021-04-06 13:35:34,416 | Thread release successful.
Assertion 'close_nointr(fd) != -EBADF' failed at src/basic/fd-util.c:73, function safe_close(). Aborting.
