After a succesfull Install of Davinci Resolve 17 through yay (AUR auto-installer) everything seemes to be working fine (after an install of the official NVIDIA GPU Drivers), except the audio. Here is an example video:
https://drive.google.com/file/d/1W-zQu24mxxlI7J9gw9YpxUaz2UfzsYZV/view?usp=sharing
The Audio used in this clip is 2SCOOPS - Donuts from NoCopyrighSounds.
The Log shows this error many times:
ALSA lib confmisc.c:165:(snd_config_get_card) Cannot get card index for Loopback
By the way: VLC Media Player shows an error with ALSA when it’s trying to use the audio device “default”:
Audioausgabe fehlgeschlagen:
Das Audiogerät “default” konnte nicht benutzt werden:
Kein passendes Gerät gefunden.
That just means:
Audio Output failed:
The Audio Device “default” could not be used:
No matching Device found.
Maybe that’s the problem?
I already trid to edit /etc/asound.conf to select a default audio device, with no luck.
And something like this post didn’t help me:
