Hello,
I had Resolve working on my MSI GT72 before, but had to reinstall Manjaro recently. The reinstallation of Resolve via pamac/AUR went through, but when trying to start it crashes on the splash screen at the message “loading Fairlight page”. Nvidia drivers 4.60, OpenCL 4.60 and nvidia-prime are installed.
Errors in DebugResolve:
[0x7fbd41593640] | SyManager | ERROR | 2021-02-01 18:46:55,867 | Failed to connect to panel socket
[0x7fbd800755c0] | DtManager | INFO | 2021-02-01 18:46:55,867 | Using 8 generic IO threads
[0x7fbd41593640] | SyManager | ERROR | 2021-02-01 18:46:55,867 | DRIVER: open /var/tmp/davinci_socket failed
/opt/resolve/bin/BlackmagicRawAPI/libBlackmagicRawAPI.so: cannot open shared object file: No such file or directory
/opt/resolve/bin/libBlackmagicRawAPI.so: cannot open shared object file: No such file or directory
[0x7fbd800755c0] | UI | ERROR | 2021-02-01 18:46:58,188 | Failed to find text ‘Apple ProRes’ in combo-box
[0x7fbd800755c0] | UI | WARN | 2021-02-01 18:46:58,189 | Failed to find value ‘0’ in combo-box
libScannerAPI.so: cannot open shared object file: No such file or directory
[0x7fbd800755c0] | DbCommon2 | INFO | 2021-02-01 18:46:58,291 | Sm2SysIdEntry is not supported in disk database (xml) mode
SY panel handler thread starts: 41593640
[0x7fbd41593640] | SyManager | ERROR | 2021-02-01 18:46:58,371 | Failed to connect to panel socket
[0x7fbd800755c0] | UI | WARN | 2021-02-01 18:46:58,666 | Failed to load media metadata preset list or the list is empty.
[0x7fbd800755c0] | UI | WARN | 2021-02-01 18:46:58,679 | Failed to load media metadata preset list or the list is empty.
[0x7fbd800755c0] | UI.ActionManager | WARN | 2021-02-01 18:46:58,762 | Action [fairlightAutomationFollowsEdit] is not a global action
[0x7fbd800755c0] | UI | WARN | 2021-02-01 18:46:59,134 | Failed to load media metadata preset list or the list is empty.
[0x7fbd800755c0] | UI | WARN | 2021-02-01 18:46:59,137 | Failed to load media metadata preset list or the list is empty.
[0x7fbd800755c0] | UI | WARN | 2021-02-01 18:46:59,250 | Failed to load media metadata preset list or the list is empty.
[0x7fbd800755c0] | UI | WARN | 2021-02-01 18:46:59,253 | Failed to load media metadata preset list or the list is empty.
[0x7fbd800755c0] | CrashReport | ERROR | 2021-02-01 18:47:01,132 | Compress() : Failed to add file:/home/admin/.local/share/DaVinciResolve/configs/UI.preset to archive.
[0x7fbd800755c0] | CrashReport | ERROR | 2021-02-01 18:47:01,133 | Compress() : Failed to add file:/home/admin/.local/share/DaVinciResolve/Fusion/Profiles/Default/Fusion.prefs to archive.
I am tempted to say everything else looks good Can anyone help?
