Hello,
I have updated a few days ago from davinci resolve 18.1 to 18.5.
Here i had to upgrade additionally to mesa 23.1.4-2 and therefore i switched from my normal stable branch to unstable.
So far Davinci works as well. But now when I click on the fusion tab Davinci crashes.
Can you help me here?
I have attached the debuglog.
Greetings
draekster
0x7fe3a6c18f80 | Main | INFO | 2023-07-28 10:56:06,578 | Running DaVinci Resolve v18.5.0.0041 (Linux/Clang x86_64)
0x7fe3a6c18f80 | Main | INFO | 2023-07-28 10:56:06,578 | BMD_BUILD_UUID 2fbf171e-a9d3-4d3a-9423-00e561c95e2d
0x7fe3a6c18f80 | Main | INFO | 2023-07-28 10:56:06,578 | BMD_GIT_COMMIT 83d5c0fe1ab179cf2933a314a655ebb96f6dd2bc
0x7fe3a6c18f80 | GPUDetect | INFO | 2023-07-28 10:56:06,579 | Starting GPUDetect 1.2_4-a3
0x7fe3a6c18f80 | GPUDetect | INFO | 2023-07-28 10:56:06,892 | Done in 312 ms.
0x7fe3a6c18f80 | GPUDetect | INFO | 2023-07-28 10:56:06,892 | Detected System:
0x7fe3a6c18f80 | GPUDetect | INFO | 2023-07-28 10:56:06,892 | - OS: Linux Manjaro
0x7fe3a6c18f80 | GPUDetect | INFO | 2023-07-28 10:56:06,892 | - Model: MSI Z170A TOMAHAWK (MS-7970)
0x7fe3a6c18f80 | GPUDetect | INFO | 2023-07-28 10:56:06,892 | - System ID: b9b31956f9af436785b393448f3babcd
0x7fe3a6c18f80 | GPUDetect | INFO | 2023-07-28 10:56:06,892 | - CPU: Intel Core i7-6700, 8 threads, x86-64
0x7fe3a6c18f80 | GPUDetect | INFO | 2023-07-28 10:56:06,892 | - RAM: 4.4 GiB used of 31.3 GiB
0x7fe3a6c18f80 | GPUDetect | INFO | 2023-07-28 10:56:06,893 | Detected 1 GPUs:
0x7fe3a6c18f80 | GPUDetect | INFO | 2023-07-28 10:56:06,893 | - "AMD Radeon RX 6600" (gpu:00158869.a0aa77a0) <- Main Display GPU
0x7fe3a6c18f80 | GPUDetect | INFO | 2023-07-28 10:56:06,893 | Discrete, 0 B used of 8.0 GiB VRAM, PCI:3:0.0
0x7fe3a6c18f80 | GPUDetect | INFO | 2023-07-28 10:56:06,893 | Matches: OpenCL, XOrg
0x7fe3a6c18f80 | GPUDetect | INFO | 2023-07-28 10:56:06,893 | Detected 1 monitors:
0x7fe3a6c18f80 | Main.GPUConfig | INFO | 2023-07-28 10:56:06,893 | Selected compute API: OpenCL
0x7fe3a6c18f80 | Main.GPUConfig | INFO | 2023-07-28 10:56:06,893 | Manual GPU Selection:
0x7fe3a6c18f80 | Main.GPUConfig | INFO | 2023-07-28 10:56:06,893 | - "AMD Radeon RX 6600" (gpu:00158869.a0aa77a0)
0x7fe3a6c18f80 | IO | INFO | 2023-07-28 10:56:06,893 | RED InitializeSdk with library path at /opt/resolve/libs
0x7fe3a6c18f80 | IO | INFO | 2023-07-28 10:56:06,945 | R3DAPI 8.3.1-52407 (20220725 Lx64S) R3DSDK 8.3.1-52407 (20220725 Lx64D C3B1) RED OPENCL 8.3.1-52408 (20220725) [/opt/resolve/libs/] init is successful
0x7fe3a6c18f80 | Main | INFO | 2023-07-28 10:56:06,946 | 0 RED rocket cards available
libDeckLinkAPI.so: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden
0x7fe3a6c18f80 | Main | INFO | 2023-07-28 10:56:06,946 | Decklink model name: '', version: ''
0x7fe3a6c18f80 | DVIP | INFO | 2023-07-28 10:56:06,947 | DVIP release/18.5 build 79 (e2f39be8fd300842d537eaf7df4ecdc6d7fc3fd0). Release, version 18.5.0.
0x7fe269dff680 | IO | INFO | 2023-07-28 10:56:07,151 | Using DNxHR library v2.7.3.27r
0x7fe268dfd680 | SyManager | ERROR | 2023-07-28 10:56:07,154 | GetProjectLibraries() - Access token is empty
0x7fe26f1f0680 | Fusion | INFO | 2023-07-28 10:56:07,346 | Fusion Build: 1f4ca5f7_0073 (Jul 19 2023 12:27:07)
0x7fe25f9fb680 | Fusion | INFO | 2023-07-28 10:56:07,354 | fusionsystem: = "/opt/resolve/libs/Fusion/libfusionsystem.so"
0x7fe25f9fb680 | Fusion | INFO | 2023-07-28 10:56:07,368 | FusionLibs: = "/opt/resolve/libs/Fusion/"
0x7fe25f9fb680 | Fusion | INFO | 2023-07-28 10:56:07,368 | UserData: = "/home/draekster/.local/share/DaVinciResolve/Fusion"
0x7fe25f9fb680 | Fusion | INFO | 2023-07-28 10:56:07,368 | Profiles: = "UserData:Profiles/"
0x7fe269dff680 | IO | INFO | 2023-07-28 10:56:07,372 | IO codec library load completed in 221 ms.
0x7fe256dff680 | DbCommon2 | INFO | 2023-07-28 10:56:07,384 | Loading dblist file: /home/draekster/.local/share/DaVinciResolve/configs/.dblist
0x7fe3a6c18f80 | Main | INFO | 2023-07-28 10:56:07,480 | Finished loading Application style sheet
0x7fe3a6c18f80 | Main | INFO | 2023-07-28 10:56:07,498 | Show splash screen
0x7fe3a6c18f80 | Main | INFO | 2023-07-28 10:56:07,498 | Show splash screen message: Starting Up
0x7fe3a6c18f80 | UI.GLContext | INFO | 2023-07-28 10:56:07,609 | Creating shared OpenGL context for this thread (1 total).
0x7fe3a6c18f80 | UI.GLContext | INFO | 2023-07-28 10:56:07,627 | Initialized OpenGL 4.6 (requested 4.5) on device 'AMD AMD Radeon RX 6600 (navi23, LLVM 15.0.7, DRM 3.42, 5.15.123-1-MANJARO)'
0x7fe245cbe680 | LeManager | INFO | 2023-07-28 10:56:07,639 | 521, 29
0x7fe3a6c18f80 | BtCommon | INFO | 2023-07-28 10:56:07,639 | Memory config: reserved=8175M pinned=4000M log=0
0x7fe3a6c18f80 | BtCommon | INFO | 2023-07-28 10:56:07,640 | Using default pooled memory manager
0x7fe2454bd680 | BtCommon | INFO | 2023-07-28 10:56:07,640 | BtResourceManager Process Thread Started
0x7fe3a6c18f80 | IO | INFO | 2023-07-28 10:56:07,662 | Setting codec capacity (0)
0x7fe3a6c18f80 | SyManager | INFO | 2023-07-28 10:56:07,669 | Total: 20, NumDtThreads: 8, NumComms: 0, NumSites: 1
0x7fe3a6c18f80 | SyManager | INFO | 2023-07-28 10:56:07,670 | Lookaheads -> playback = 20, record = 20, stop = 2
Sy High Command Handler Thread ----- (140609765262976)
SY high priority cmd handler thread starts: 431C4680
Sy Low Command Handler Thread ----- (140609756870272)
SY low priority cmd handler thread starts: 429C3680
Sy Data Handler Thread ----- (140609748477568)
SY data handler thread starts: 421C2680
Gs High Command Handler Thread ----- (140609731692160)
GS high priority cmd handler thread starts: 411C0680
Gs Low Command Handler Thread ----- (140609723299456)
GS low priority cmd handler thread starts: 409BF680
Dp High Command Handler Thread ----- (140609706514048)
DP high priority cmd handler thread starts: 3F9BD680
Dp Low Command Handler Thread ----- (140609698121344)
DP low priority cmd handler thread starts: 3F1BC680
Dt High Command Handler Thread ----- (140609677145728)
DT high priority cmd handler thhread starts: 3DDBB680
Dt Low Command Handler Thread ----- (140609664558720)
DT low priority cmd handler thread starts: 3D1BA680
0x7fe3a6c18f80 | DtManager | INFO | 2023-07-28 10:56:07,670 | Using 8 generic IO threads
0x7fe23c9b9680 | DtManager | INFO | 2023-07-28 10:56:07,670 | Dt Data Handler Thread Started
DT data handler thread starts: 3C9B9680
0x7fe3a6c18f80 | DtManager | INFO | 2023-07-28 10:56:07,670 | Total of 16 IO threads (including 8 generic and 8 Red decode threads)
0x7fe2401be680 | GsManager | INFO | 2023-07-28 10:56:07,670 | Gs Processor Thread ----- (140609714906752)
GS processor thread starts: 401BE680
0x7fe23b9b7680 | DtManager | INFO | 2023-07-28 10:56:07,671 | Dt Worker Thread Started
0x7fe23a9b5680 | DtManager | INFO | 2023-07-28 10:56:07,671 | Dt Worker Thread Started
0x7fe2361ac680 | DtManager | INFO | 2023-07-28 10:56:07,671 | Dt Worker Thread Started
0x7fe23c1b8680 | DtManager | INFO | 2023-07-28 10:56:07,671 | Dt Worker Thread Started
0x7fe2359ab680 | DtManager | INFO | 2023-07-28 10:56:07,671 | Dt Worker Thread Started
Ls High Command Handler Thread ----- (140609471526528)
Ls Data Handler Thread ----- (140609454741120)
LS data handler thread starts: 309A1680
0x7fe2351aa680 | DtManager | INFO | 2023-07-28 10:56:07,671 | Dt Worker Thread Started
0x7fe23b1b6680 | DtManager | INFO | 2023-07-28 10:56:07,671 | Dt Worker Thread Started
0x7fe3a6c18f80 | Main | INFO | 2023-07-28 10:56:07,672 | Show splash screen message: Loading Project Libraries
Ls High Command Handler Thread ----- (140609446348416)
Ls Data Handler Thread ----- (140609429563008)
0x7fe23a1b4680 | DtManager | INFO | 2023-07-28 10:56:07,672 | Dt Worker Thread Started
Mem Data Transmitter Thread ----- (140609421170304)
Mem data transmitter thread starts: 2E99D680
0x7fe2389b1680 | DtManager | INFO | 2023-07-28 10:56:07,675 | Dt Worker Thread Started
Ls Low Command Handler Thread ----- (140609437955712)
LS low priority cmd handler thread starts: 2F99F680
0x7fe22f19e680 | GPU.MultiBoardMgr | INFO | 2023-07-28 10:56:07,686 | Let There Be OpenCL Light!
0x7fe22f19e680 | GPU.MultiBoardMgr | INFO | 2023-07-28 10:56:07,686 | Initializing OpenCL board manager for Main Display GPU gpu:00158869.a0aa77a0.
0x7fe22d99b680 | UI.GLContext | INFO | 2023-07-28 10:56:07,686 | Creating shared OpenGL context for this thread (2 total).
Ls High Command Handler Thread ----- (140609496704640)
0x7fe2339a7680 | DtManager | INFO | 2023-07-28 10:56:07,688 | Dt Worker Thread Started
0x7fe2341a8680 | DtManager | INFO | 2023-07-28 10:56:07,688 | Dt Worker Thread Started
0x7fe2349a9680 | DtManager | INFO | 2023-07-28 10:56:07,688 | Dt Worker Thread Started
0x7fe2369ad680 | DtManager | INFO | 2023-07-28 10:56:07,689 | Dt Worker Thread Started
0x7fe2371ae680 | DtManager | INFO | 2023-07-28 10:56:07,689 | Dt Worker Thread Started
0x7fe2379af680 | DtManager | INFO | 2023-07-28 10:56:07,689 | Dt Worker Thread Started
0x7fe2381b0680 | DtManager | INFO | 2023-07-28 10:56:07,689 | Dt Worker Thread Started
0x7fe2391b2680 | DtManager | INFO | 2023-07-28 10:56:07,689 | Dt Worker Thread Started
0x7fe2399b3680 | DtManager | INFO | 2023-07-28 10:56:07,689 | Dt Worker Thread Started
Ls Low Command Handler Thread ----- (140609463133824)
LS low priority cmd handler thread starts: 311A2680
Ls Low Command Handler Thread ----- (140609488311936)
LS low priority cmd handler thread starts: 329A5680
Ls Data Handler Thread ----- (140609479919232)
LS data handler thread starts: 321A4680
0x7fe22d99b680 | DVIP | INFO | 2023-07-28 10:56:07,753 | Created OpenCL context for devices gpu:00158869.a0aa77a0
0x7fe3a6c18f80 | Main | INFO | 2023-07-28 10:56:07,828 | Show splash screen message: Initializing system components
0x7fe3a6c18f80 | Main | INFO | 2023-07-28 10:56:07,841 | Show splash screen message: Loading video codecs
0x7fe3a6c18f80 | Main | INFO | 2023-07-28 10:56:07,843 | Show splash screen message: Loading video plugins
0x7fe3a6c18f80 | Main | INFO | 2023-07-28 10:56:07,844 | Show splash screen message: Loading Fairlight Engine
/opt/resolve/bin/BlackmagicRawAPI/libBlackmagicRawAPI.so: cannot open shared object file: No such file or directory
/opt/resolve/bin/libBlackmagicRawAPI.so: cannot open shared object file: No such file or directory
0x7fe269dff680 | IO | INFO | 2023-07-28 10:56:08,575 | IO codec initialization completed in 732 ms.
0x7fe22d99b680 | DVIP | INFO | 2023-07-28 10:56:08,579 | Opened cache "OpenCL" at "/home/draekster/.local/share/DaVinciResolve/DVIP/Cache/OpenCL.cache", version "2" matches. Total size 4.6 MiB.
0x7fe22d99b680 | GPU.SingleBoardMgr | INFO | 2023-07-28 10:56:08,640 | Board manager thread for "AMD Radeon RX 6600" (gpu:00158869.a0aa77a0) is ready.
0x7fe22f19e680 | UI.GLInterop | INFO | 2023-07-28 10:56:08,641 | OpenGL interop was initialized.
LS data handler thread starts: 2F19E680
0x7fe3a6c18f80 | Fairlight | INFO | 2023-07-28 10:56:09,563 | 00.00.01.010(000): Running Fairlight (5a04691e27c127fb02d6af086ebfef11aa33c947)
0x7fe3a6c18f80 | FairlightLoader | INFO | 2023-07-28 10:56:09,563 | Fairlight lib initialized in 1718 ms.
0x7fe26f1f0680 | UI.GLContext | INFO | 2023-07-28 10:56:09,563 | Creating shared OpenGL context for this thread (3 total).
0x7fe26f1f0680 | DVIP | INFO | 2023-07-28 10:56:09,565 | Re-using OpenCL context for devices gpu:00158869.a0aa77a0
0x7fe26f1f0680 | UI.GLIO | INFO | 2023-07-28 10:56:09,569 | Initialized MainPlayer OpenGL I/O on OpenCL device 'gfx1032'
0x7fe3a6c18f80 | UI.GLIO | INFO | 2023-07-28 10:56:09,569 | MainPlayer: OpenGL I/O setup done.
0x7fe1c48ff680 | UI.GLContext | INFO | 2023-07-28 10:56:09,569 | Creating shared OpenGL context for this thread (4 total).
0x7fe1c48ff680 | DVIP | INFO | 2023-07-28 10:56:09,573 | Re-using OpenCL context for devices gpu:00158869.a0aa77a0
0x7fe1c48ff680 | UI.GLIO | INFO | 2023-07-28 10:56:09,583 | Initialized AuxPlayer OpenGL I/O on OpenCL device 'gfx1032'
0x7fe3a6c18f80 | UI.GLIO | INFO | 2023-07-28 10:56:09,583 | AuxPlayer: OpenGL I/O setup done.
0x7fe1c12ff680 | UI.GLContext | INFO | 2023-07-28 10:56:09,583 | Creating shared OpenGL context for this thread (5 total).
0x7fe1c12ff680 | DVIP | INFO | 2023-07-28 10:56:09,597 | Re-using OpenCL context for devices gpu:00158869.a0aa77a0
0x7fe1c12ff680 | UI.Scopes | INFO | 2023-07-28 10:56:09,604 | Initialized GPU Scopes Manager on OpenCL device 'gfx1032'
libScannerAPI.so: cannot open shared object file: No such file or directory
0x7fe3a6c18f80 | UI.MenuBar | WARN | 2023-07-28 10:56:09,672 | Main menu action [workspaceLayoutFusion_sub001Default]'s slot is not defined: workspaceLayoutFusion_sub001Default_triggered()
0x7fe3a6c18f80 | FusionUtils | WARN | 2023-07-28 10:56:09,684 | Fusion DoAction ACTION_SET_FUSION_HOTKEY ignored, init not completed
0x7fe1c30fc680 | SyManager | ERROR | 2023-07-28 10:56:09,689 | Failed to connect to panel socket
0x7fe1c30fc680 | SyManager | ERROR | 2023-07-28 10:56:09,690 | DRIVER: open /var/tmp/davinci_socket failed
SY panel handler thread starts: C30FC680
Opening communication to resolve..
*** WARNING *** The program 'resolve' uses the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=resolve>
0x7fe1bf4f0680 | SyManager | INFO | 2023-07-28 10:56:09,722 | Starting keyboard device monitor thread...
DaVinci Panel API Version: 1.0
0x7fe3a6c18f80 | Main | INFO | 2023-07-28 10:56:09,726 | Show splash screen message: Loading Project Settings
0x7fe2235ff680 | Fusion | INFO | 2023-07-28 10:56:09,974 | 273 templates scanned in 0.19 secs
0x7fe3a6c18f80 | UI | WARN | 2023-07-28 10:56:10,005 | Failed to find value '0' in combo-box
0x7fe3a6c18f80 | Main | INFO | 2023-07-28 10:56:10,506 | Show splash screen message: Loading Media Page
0x7fe3a6c18f80 | UI.ActionManager | WARN | 2023-07-28 10:56:10,591 | Action [fairlightImmersiveGenerateImmersiveMaster] is not a valid global action
0x7fe3a6c18f80 | UI.ActionManager | WARN | 2023-07-28 10:56:10,592 | Action [fairlightImmersiveRendererSettings] is not a valid global action
0x7fe3a6c18f80 | UI.FairlightInterface | WARN | 2023-07-28 10:56:10,729 | SetActionEnabled: Failed to find action [viewTimelineScrollingFixed]'s action connector for handler Id [1]
0x7fe3a6c18f80 | Main | INFO | 2023-07-28 10:56:10,927 | Show splash screen message: Loading Cut Page
0x7fe3a6c18f80 | Main | INFO | 2023-07-28 10:56:11,288 | Show splash screen message: Loading Edit Page
0x7fe3a6c18f80 | Main | INFO | 2023-07-28 10:56:11,578 | Show splash screen message: Loading Fusion Page
0x7fe3a6c18f80 | Main | INFO | 2023-07-28 10:56:11,701 | Show splash screen message: Loading Fairlight Page
0x7fe3a6c18f80 | Main | INFO | 2023-07-28 10:56:11,931 | Show splash screen message: Loading Color Page
0x7fe3a6c18f80 | UI | WARN | 2023-07-28 10:56:12,996 | Failed to find value '100' in combo-box
0x7fe3a6c18f80 | Main | INFO | 2023-07-28 10:56:13,828 | Show splash screen message: Loading Waveform Monitor
0x7fe1c30fc680 | SyManager | INFO | 2023-07-28 10:56:13,940 | Connected to panel socket at 154
0x7fe1c30fc680 | SyManager | INFO | 2023-07-28 10:56:13,941 | Connection to the panel server has been re-established
Resolve discovery
****************** Flushing GPU Buffers
0x7fe3a6c18f80 | Main | INFO | 2023-07-28 10:56:14,272 | Show splash screen message: Loading Audio Plugins
0x7fe3a6c18f80 | SyManager | INFO | 2023-07-28 10:56:14,356 | Collaboration IP Port 0
0x7fe3a6c18f80 | DbCommon2 | INFO | 2023-07-28 10:56:14,356 | Sm2SysIdEntry is not supported in local project library (xml) mode
0x7fe3a6c18f80 | SyManager | ERROR | 2023-07-28 10:56:14,357 | Failed to parse key (SkipVersion) from JsonObject
0x7fe3a6c18f80 | Main | INFO | 2023-07-28 10:56:14,369 | Show splash screen message: Loading Projects
0x7fe3a6c18f80 | SyManager.Signals | INFO | 2023-07-28 10:56:14,394 | Current user pointer is changed
0x7fe3a6c18f80 | UI | WARN | 2023-07-28 10:56:14,420 | UI Persistence - SecondaryScreenIdx not read
0x7fe3a6c18f80 | UI | WARN | 2023-07-28 10:56:14,420 | UI Persistence - UseDisplayNameForClips not read
0x7fe3a6c18f80 | UI | WARN | 2023-07-28 10:56:14,421 | UI Persistence - DefaultTransitionKey not read
0x7fe3a6c18f80 | UI | WARN | 2023-07-28 10:56:14,421 | UI Persistence - DefaultAudioTransitionKey not read
0x7fe3a6c18f80 | IO | INFO | 2023-07-28 10:56:14,434 | RED rocket decode has been disabled in the config file
Resolve discovery
0x7fe3a6c18f80 | SyManager | INFO | 2023-07-28 10:56:14,624 | Search Parameter (-2) or Search Operation (0) not supported, and hence disabling the condition.
0x7fe3a6c18f80 | SyManager | INFO | 2023-07-28 10:56:14,625 | Search Parameter (-1) or Search Operation (-1) not supported, and hence disabling the condition.
0x7fe3a6c18f80 | UI.ActionManager | WARN | 2023-07-28 10:56:15,082 | Action [fairlightImmersiveGenerateImmersiveMaster] is not a valid global action
0x7fe3a6c18f80 | UI.ActionManager | WARN | 2023-07-28 10:56:15,083 | Action [fairlightImmersiveRendererSettings] is not a valid global action
0x7fe3a6c18f80 | UI.ActionManager | WARN | 2023-07-28 10:56:15,088 | Action [fairlightImmersiveGenerateImmersiveMaster] is not a valid global action
0x7fe3a6c18f80 | UI.ActionManager | WARN | 2023-07-28 10:56:15,088 | Action [fairlightImmersiveRendererSettings] is not a valid global action
0x7fe3a6c18f80 | UI.ActionManager | WARN | 2023-07-28 10:56:15,150 | Action [fairlightImmersiveGenerateImmersiveMaster] is not a valid global action
0x7fe3a6c18f80 | UI.ActionManager | WARN | 2023-07-28 10:56:15,150 | Action [fairlightImmersiveRendererSettings] is not a valid global action
0x7fe3a6c18f80 | UI | ERROR | 2023-07-28 10:56:15,234 | Failed to find text 'Apple ProRes' in combo-box
0x7fe3a6c18f80 | UI | WARN | 2023-07-28 10:56:15,234 | Failed to find value '0' in combo-box
0x7fe3a6c18f80 | UI | WARN | 2023-07-28 10:56:15,235 | Failed to find value '0' in combo-box
0x7fe3a6c18f80 | UI | WARN | 2023-07-28 10:56:15,239 | Failed to find value '4' in combo-box
0x7fe3a6c18f80 | SyManager.Gallery | INFO | 2023-07-28 10:56:15,240 | Start purging still caches
0x7fe3a6c18f80 | SyManager.Gallery | INFO | 2023-07-28 10:56:15,240 | Finish purging still caches
0x7fe3a6c18f80 | SyManager.Signals | INFO | 2023-07-28 10:56:15,275 | Media pool relink status changed to 0
0x7fe3a6c18f80 | FusionUtils | WARN | 2023-07-28 10:56:15,290 | Fusion DoAction ACTION_SET_FUSION_HOTKEY ignored, init not completed
0x7fe3a6c18f80 | UI | INFO | 2023-07-28 10:56:15,315 | Launching project manager
0x7fe3a6c18f80 | SyManager.Signals | INFO | 2023-07-28 10:56:15,339 | Main view page is changed to 12
0x7fe3a6c18f80 | Main | INFO | 2023-07-28 10:56:15,361 | Show splash screen message: Ready
0x7fe3a6c18f80 | UI | INFO | 2023-07-28 10:56:15,389 | Gallery pointer is changed, refreshing color gallery
0x7fe3a6c18f80 | UI | INFO | 2023-07-28 10:56:15,400 | Gallery pointer is changed, refreshing gallery browser
0x7fe3a6c18f80 | Main | INFO | 2023-07-28 10:56:15,449 | Close splash screen
0x7fe3a6c18f80 | Main | INFO | 2023-07-28 10:56:15,450 | Launching main loop
0x7fe3a6c18f80 | SyManager.Signals | INFO | 2023-07-28 10:56:15,633 | Fusion templates changed
0x7fe3a6c18f80 | SyManager.ActionExecutor | INFO | 2023-07-28 10:56:31,787 | Database transaction is ongoing, user initiated action Sync Asset Map is postponed
0x7fe3a6c18f80 | SyManager.ActionExecutor | INFO | 2023-07-28 10:56:31,969 | Database transaction completed, enqueueing 1 postponed actions
0x7fe3a6c18f80 | SyManager.ProjectManager | INFO | 2023-07-28 10:56:32,034 | Loading project (Unser Jahr 2023) from project library (Local Database) took 1315 ms
0x7fe3a6c18f80 | UI.ActionManager | WARN | 2023-07-28 10:56:32,163 | Action [fairlightImmersiveGenerateImmersiveMaster] is not a valid global action
0x7fe3a6c18f80 | UI.ActionManager | WARN | 2023-07-28 10:56:32,163 | Action [fairlightImmersiveRendererSettings] is not a valid global action
0x7fe3a6c18f80 | UI | WARN | 2023-07-28 10:56:32,342 | UI Persistence - UI_FC_SEQUENCE_ENLARGED_TRACK_TYPE not read
0x7fe3a6c18f80 | UI | WARN | 2023-07-28 10:56:32,342 | UI Persistence - UI_FC_SEQUENCE_ENLARGED_TRACK_IDX not read
0x7fe22d99b680 | GPU.SingleBoardMgr | INFO | 2023-07-28 10:56:32,539 | Flushing GPU memory...
0x7fe22d99b680 | UI.GLTexPool | INFO | 2023-07-28 10:56:32,539 | Released 0 MiB in 0 unused textures.
0x7fe3a6c18f80 | UI | WARN | 2023-07-28 10:56:32,713 | Failed to find value '0' in combo-box
0x7fe3a6c18f80 | SyManager.Gallery | INFO | 2023-07-28 10:56:32,737 | Start purging still caches
0x7fe3a6c18f80 | SyManager.Gallery | INFO | 2023-07-28 10:56:32,737 | Finish purging still caches
Printing Stack Info
/opt/resolve/bin/resolve() [0x471746f]
/opt/resolve/bin/resolve() [0x4717645]
/opt/resolve/bin/resolve() [0x2f73b72]
/opt/resolve/bin/resolve() [0x449596f]
/opt/resolve/bin/resolve() [0x4495469]
/opt/resolve/bin/../libs/libQt5Core.so.5(+0x2cb925) [0x7fe396b2e925]
/opt/resolve/bin/resolve() [0x4397ec0]
/opt/resolve/bin/../libs/libQt5Core.so.5(+0x2cba5d) [0x7fe396b2ea5d]
/opt/resolve/bin/resolve() [0x4386765]
/opt/resolve/bin/resolve() [0x43852b5]
/opt/resolve/bin/resolve() [0x43ce1e5]
/opt/resolve/bin/resolve() [0x439cbfc]
/opt/resolve/bin/resolve() [0x439be3a]
/opt/resolve/bin/resolve() [0x439d093]
/opt/resolve/bin/resolve() [0x43866c6]
/opt/resolve/bin/resolve() [0x4404864]
/opt/resolve/bin/resolve() [0x44057be]
/opt/resolve/bin/resolve() [0x4382955]
/opt/resolve/bin/resolve() [0x3afc1c5]
/opt/resolve/bin/resolve() [0x3b00e06]
/opt/resolve/bin/resolve() [0x3b1b64b]
/opt/resolve/bin/resolve() [0x3b1d968]
/opt/resolve/bin/../libs/libQt5Widgets.so.5(_ZN14QGraphicsScene5eventEP6QEvent+0x126) [0x7fe3bc761fe6]
/opt/resolve/bin/../libs/libQt5Widgets.so.5(_ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent+0x100) [0x7fe3bc426d00]
/opt/resolve/bin/../libs/libQt5Widgets.so.5(_ZN12QApplication6notifyEP7QObjectP6QEvent+0x1cf) [0x7fe3bc42816f]
/opt/resolve/bin/resolve() [0x24c55b4]
/opt/resolve/bin/../libs/libQt5Core.so.5(_ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent+0xa4) [0x7fe396af7e14]
/opt/resolve/bin/../libs/libQt5Widgets.so.5(_ZN13QGraphicsView21mouseDoubleClickEventEP11QMouseEvent+0x3c5) [0x7fe3bc78b435]
/opt/resolve/bin/../libs/libQt5Widgets.so.5(_ZN7QWidget5eventEP6QEvent+0x877) [0x7fe3bc45f1a7]
/opt/resolve/bin/../libs/libQt5Widgets.so.5(_ZN6QFrame5eventEP6QEvent+0x25) [0x7fe3bc50c155]
/opt/resolve/bin/../libs/libQt5Widgets.so.5(_ZN13QGraphicsView13viewportEventEP6QEvent+0x4c6) [0x7fe3bc78a776]
/opt/resolve/bin/resolve() [0x3b331af]
/opt/resolve/bin/../libs/libQt5Core.so.5(_ZN23QCoreApplicationPrivate29sendThroughObjectEventFiltersEP7QObjectP6QEvent+0xf9) [0x7fe396af8109]
/opt/resolve/bin/../libs/libQt5Widgets.so.5(_ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent+0xec) [0x7fe3bc426cec]
/opt/resolve/bin/../libs/libQt5Widgets.so.5(_ZN12QApplication6notifyEP7QObjectP6QEvent+0x1978) [0x7fe3bc429918]
/opt/resolve/bin/../libs/libQt5Widgets.so.5(_ZN19QApplicationPrivate14sendMouseEventEP7QWidgetP11QMouseEventS1_S1_PS1_R8QPointerIS0_Ebb+0x38b) [0x7fe3bc42760b]
/opt/resolve/bin/../libs/libQt5Widgets.so.5(+0x1c1de8) [0x7fe3bc47dde8]
/opt/resolve/bin/../libs/libQt5Widgets.so.5(+0x1c0598) [0x7fe3bc47c598]
/opt/resolve/bin/../libs/libQt5Gui.so.5(_ZN22QGuiApplicationPrivate17processMouseEventEPN29QWindowSystemInterfacePrivate10MouseEventE+0x1293) [0x7fe39704a713]
/opt/resolve/bin/../libs/libQt5Gui.so.5(_ZN22QWindowSystemInterface22sendWindowSystemEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE+0xdb) [0x7fe39702a6fb]
0x7fe3a6c18f80 | BtCommon | WARN | 2023-07-28 10:56:32,778 | Negative duration
0x7fe3a6c18f80 | SyManager.Signals | INFO | 2023-07-28 10:56:32,785 | Media pool relink status changed to 0
0x7fe3a6c18f80 | SyManager.Signals | INFO | 2023-07-28 10:56:32,903 | Current project pointer changed to (Unser Jahr 2023) from DB (Local Database : Local)
0x7fe3a6c18f80 | SyManager.Signals | INFO | 2023-07-28 10:56:32,903 | Current timeline pointer (Timeline 1) is changed
0x7fe3a6c18f80 | Undefined | INFO | 2023-07-28 10:56:32,938 | The buttonId [7] is not found for [0] in [0]
0x7fe3a6c18f80 | UI | INFO | 2023-07-28 10:56:32,952 | Gallery pointer is changed, refreshing color gallery
0x7fe3a6c18f80 | UI | INFO | 2023-07-28 10:56:32,980 | Gallery pointer is changed, refreshing gallery browser
0x7fe3a6c18f80 | SyManager.Signals | INFO | 2023-07-28 10:56:33,029 | Main view page is changed to 1
0x7fe3a6c18f80 | UI | WARN | 2023-07-28 10:56:33,029 | Failed to get auto update information.
0x7fe3a6c18f80 | SyManager.Signals | INFO | 2023-07-28 10:56:33,152 | Main view page is changed to 3
0x7fe3a6c18f80 | UI | WARN | 2023-07-28 10:56:33,345 | UI Persistence - OFXLibrarySplitRatio not read
0x7fe3a6c18f80 | UI | WARN | 2023-07-28 10:56:33,345 | UI Persistence - OFXLibrarySplitRatioInFSV not read
0x7fe3a6c18f80 | UI | WARN | 2023-07-28 10:56:33,385 | UI Persistence - MediaPoolFloatingWindowGeometry not read
0x7fe3a6c18f80 | SyManager.Signals | INFO | 2023-07-28 10:56:33,395 | Main view page is changed to 3
0x7fe3a6c18f80 | UI | INFO | 2023-07-28 10:56:33,403 | Launching main window
### DEL_DBG IOFileSys::DeleteDirFully - command = rm -rf '/home/draekster/Videos/Resolve Project Backups/b5548973-e5d6-4e02-8a4d-f3362cde0f35'
### DEL_DBG IOFileSys::DeletePath[1470] p_OSErrCode = 0, p_ErrMsg =
0x7fe3a6c18f80 | SyManager | WARN | 2023-07-28 10:56:33,415 | No reply received from file system, assume successfully deleted folder /home/draekster/Videos/Resolve Project Backups/b5548973-e5d6-4e02-8a4d-f3362cde0f35.
### DEL_DBG IOFileSys::DeleteDirFully - command = rm -rf '/home/draekster/Videos/Davinci_Resolve/CacheClip/b5548973-e5d6-4e02-8a4d-f3362cde0f35'
0x7fe3a6c18f80 | SyManager | WARN | 2023-07-28 10:56:33,426 | No reply received from file system, assume successfully deleted folder /home/draekster/Videos/Davinci_Resolve/CacheClip/b5548973-e5d6-4e02-8a4d-f3362cde0f35.
### DEL_DBG IOFileSys::DeleteDirFully - command = rm -rf '/home/draekster/Videos/Davinci_Resolve/.gallery/b5548973-e5d6-4e02-8a4d-f3362cde0f35'
0x7fe3a6c18f80 | SyManager | WARN | 2023-07-28 10:56:33,436 | No reply received from file system, assume successfully deleted folder /home/draekster/Videos/Davinci_Resolve/.gallery/b5548973-e5d6-4e02-8a4d-f3362cde0f35.
0x7fe3a6c18f80 | UI | WARN | 2023-07-28 10:56:33,513 | Unable to submit frame to GPU scopes, legacy OpenGL uploads not supported (Color Page).
0x7fe121d75680 | Fusion | INFO | 2023-07-28 10:56:39,310 | Started FusionAudio Worker thread
0x7fe3a6c18f80 | UI | WARN | 2023-07-28 10:56:39,492 | UI Persistence - MediaPoolFloatingWindowGeometry not read
0x7fe3a6c18f80 | SyManager.Signals | INFO | 2023-07-28 10:56:39,514 | Main view page is changed to 16
==========[CRASH DUMP]==========
#TIME Fri Jul 28 10:56:39 2023 - Uptime 00:00:31 (hh:mm:ss)
#PROGRAM_NAME DaVinci Resolve v18.5.0.0041 (Linux/Clang x86_64)
#BMD_ARCHITECTURE x86_64
#BMD_BUILD_UUID 2fbf171e-a9d3-4d3a-9423-00e561c95e2d
#BMD_GIT_COMMIT 83d5c0fe1ab179cf2933a314a655ebb96f6dd2bc
#BMD_UTIL_VERSION 18.5.0.0041
#OS Linux
/opt/resolve/bin/resolve() [0x47170f9]
/opt/resolve/bin/resolve() [0x47164e0]
/usr/lib/libc.so.6(+0x39ab0) [0x7fe3a784fab0]
/opt/resolve/libs/Fusion/libfusionsystem.so(_ZN6Fusion15GraphicsContext6CreateEPNS_8Graphics7GDeviceEPKcS5_+0x14) [0x7fe26529e0f4]
/opt/resolve/libs/Fusion/libfusionsystem.so(+0x1457ea9) [0x7fe265857ea9]
/opt/resolve/libs/Fusion/libfusionsystem.so(+0x145e22e) [0x7fe26585e22e]
/opt/resolve/bin/../libs/libQt5Widgets.so.5(+0x1c72ce) [0x7fe3bc4832ce]
/opt/resolve/bin/../libs/libQt5Widgets.so.5(_ZN7QWidget5eventEP6QEvent+0x72d) [0x7fe3bc45f05d]
/opt/resolve/bin/../libs/libQt5Widgets.so.5(_ZN14QWidgetPrivate14sendPaintEventERK7QRegion+0x28) [0x7fe3bc458378]
/opt/resolve/bin/../libs/libQt5Widgets.so.5(+0x176894) [0x7fe3bc432894]
/opt/resolve/bin/../libs/libQt5Widgets.so.5(+0x177004) [0x7fe3bc433004]
/opt/resolve/bin/../libs/libQt5Widgets.so.5(_ZN14QWidgetPrivate16syncBackingStoreEv+0x4c) [0x7fe3bc44e54c]
/opt/resolve/bin/../libs/libQt5Widgets.so.5(_ZN7QWidget5eventEP6QEvent+0xab0) [0x7fe3bc45f3e0]
/opt/resolve/bin/../libs/libQt5Widgets.so.5(_ZN11QMainWindow5eventEP6QEvent+0x102) [0x7fe3bc573ac2]
/opt/resolve/bin/resolve() [0x284369b]
/opt/resolve/bin/../libs/libQt5Core.so.5(_ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData+0x16f) [0x7fe396af8b6f]
/opt/resolve/bin/../libs/libQt5Widgets.so.5(+0x49b85a) [0x7fe3bc75785a]
/opt/resolve/bin/../libs/libQt5Core.so.5(_ZN7QObject5eventEP6QEvent+0x373) [0x7fe396b229b3]
/opt/resolve/bin/../libs/libQt5Core.so.5(_ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData+0x334) [0x7fe396af8d34]
/opt/resolve/bin/../libs/libQt5Core.so.5(+0x2ec6d3) [0x7fe396b4f6d3]
/opt/resolve/bin/../libs/libglib-2.0.so.0(g_main_context_dispatch+0x27e) [0x7fe3a8665f2e]
/opt/resolve/bin/../libs/libglib-2.0.so.0(+0x66198) [0x7fe3a8666198]
/opt/resolve/bin/../libs/libglib-2.0.so.0(g_main_context_iteration+0x2c) [0x7fe3a866623c]
/opt/resolve/bin/../libs/libQt5Core.so.5(_ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE+0x58) [0x7fe396b4f188]
/opt/resolve/bin/../libs/libQt5Core.so.5(_ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE+0x1b6) [0x7fe396af3eb6]
/opt/resolve/bin/../libs/libQt5Core.so.5(_ZN16QCoreApplication4execEv+0x71) [0x7fe396af83b1]
/opt/resolve/bin/resolve() [0x24827db]
/opt/resolve/bin/resolve() [0x24803e1]
/opt/resolve/bin/resolve() [0x24694e0]
/usr/lib/libc.so.6(+0x23850) [0x7fe3a7839850]
/usr/lib/libc.so.6(__libc_start_main+0x8a) [0x7fe3a783990a]
/opt/resolve/bin/resolve() [0x246811b]
Signal Number = 11
