Hello, I have davinci resolve 18.1 installed, it all works so far wonderfully, but unfortunately I have no sound can someone help me? I have already tried everything I found on the net, but nothing has helped.
Kernel: 6.0.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
root=UUID=d0500f07-9490-44a3-9e12-b5ff7085726f rw quiet apparmor=1
Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.6 wm: kwin_wayland vt: 2
Type: Desktop Mobo: Micro-Star model: MPG X570 GAMING PLUS (MS-7C37) v: 2.0
serial: <superuser required> UEFI: American Megatrends LLC. v: A.H0
date: 05/19/2022
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 32 MiB
desc: 2x16 MiB
Speed (MHz): avg: 3598 high: 3600 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3600 2: 3600
3: 3600 4: 3598 5: 3600 6: 3599 7: 3600 8: 3600 9: 3600 10: 3600 11: 3600
12: 3600 13: 3600 14: 3583 15: 3600 16: 3600 bogomips: 115243
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-1 code: Navi
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 2f:00.0
chip-ID: 1002:731f class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 5-1.2.4:8 chip-ID: 046d:082d
class-ID: 0102 serial: <filter>
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.4
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu d-rect: 4480x1440 display-ID: 0
Monitor-1: DP-1 pos: right res: 2560x1440 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: primary,left res: 1920x1080 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 22.2.1 renderer: AMD Radeon RX 5700 XT (navi10
LLVM 14.0.6 DRM 3.48 6.0.6-1-MANJARO) direct render: Yes
Device-1: Creative Labs Sound Core3D [Sound Blaster Recon3D / Z-Series]
driver: snd_hda_intel v: kernel pcie: bus-ID: 1-2.3:6 chip-ID: 0951:16a4
gen: 1 class-ID: 0300 speed: 2.5 GT/s serial: <filter> lanes: 1
bus-ID: 29:00.0 chip-ID: 1102:0012 class-ID: 0403
Device-2: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2f:00.1 chip-ID: 1002:ab38
class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-4: Kingston HyperX 7.1 Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid
Device-5: DCMT USB Condenser Microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-1.2.3:7 chip-ID: 31b2:0011
class-ID: 0300 serial: <filter>
Device-6: Logitech HD Pro Webcam C920 type: USB
Sound API: ALSA v: k6.0.6-1-MANJARO running: yes
Sound Interface: sndio v: N/A running: no
Sound Server-1: PulseAudio v: 16.1 running: no
Sound Server-2: PipeWire v: 0.3.59 running: yes
vendor: Micro-Star MSI X570-A PRO driver: r8168 v: 8.050.03-NAPI
modules: r8169 pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 27:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-b9df6abe8fd1 state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
driver: btusb v: 0.8 bus-ID: 3-6.2:4 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 7.5 TiB used: 3.18 TiB (42.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: DB6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB
type: SSD serial: <filter> rev: 4B6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000LX001-1RG174
type: HDD rpm: 5400 serial: <filter> rev: SDM1 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD40EZRZ-00GXCB0 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 0A80 scheme: GPT
ID-5: /dev/sde maj-min: 8:64 vendor: Samsung model: HD103UJ
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: <filter> rev: 1113 scheme: MBR
ID-1: / raw-size: 500 GiB size: 491.08 GiB (98.22%) used: 247.42 GiB (50.4%)
fs: ext4 dev: /dev/sdb1 maj-min: 8:17
used: 25.9 MiB (27.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
used: 2.02 TiB (55.4%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: HomeVG-HomeVerzeichnissLV
System Temperatures: cpu: 36.0 C mobo: 29.0 C gpu: amdgpu temp: 56.0 C
mem: 58.0 C
Fan Speeds (RPM): fan-1: 733 fan-2: 1746 fan-3: 655 fan-4: 0 fan-5: 446
fan-6: 456 fan-7: 0 gpu: amdgpu fan: 0
Processes: 518 Uptime: 1h 39m wakeups: 0 Memory: 31.27 GiB
used: 8.59 GiB (27.5%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 2702
pm: pacman pkgs: 2684 libs: 562 tools: pamac,paru,yay pm: flatpak pkgs: 18
Shell: fish v: 3.5.1 running-in: konsole inxi: 3.3.23
