i have updated a fresh install of manjaro gnome with toolbox.
The das to dock no longer works after the update. The extension manager shows the following error:
GLib.FileError: Datei »/usr/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/schemas/gschemas.compiled« konnte nicht geöffnet werden: open() ist gescheitert: Datei oder Verzeichnis nicht gefunden
Also make sure you don’t have it installed twice. Open the Extensions application and make sure Dash to Dock is only listed under Built-In, not Manually Installed. If it is, remove it.
I’ve installed twice from manjaro-gnome-21.1.6-211017-linux513.iso and both times the same.
your advice worked! But needed to restart after removing the dock because it was still in extensions with the error message.
I needed to restart again after reinstalling it and now it works perfect.
Thanks a lot!
If you’re using a Wayland session, you only need to log out / login. In a Xorg session, you can just restart GNOME Shell by pressing Alt+F2 and typing r then Enter.
I installed Manjaro Gnome today and I too had the same problem. Just go to the add/remove software app, search for gnome-shell-extension dash to dock, re install it and don’t forget to restart the PC after.
