Kernel: 5.10.84-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=40809886-d17c-433b-876f-89a03d053b64 rw quiet splash apparmor=1
Desktop: GNOME 41.2 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 41.0
Type: Desktop System: Gigabyte product: AB350-Gaming v: N/A
serial: <superuser required>
Mobo: Gigabyte model: AB350-Gaming-CF v: x.x serial: <superuser required>
UEFI: American Megatrends v: F21 date: 02/08/2018
RAM: total: 15.64 GiB used: 2.72 GiB (17.4%)
RAM Report:
Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen
family: 0x17 (23) model-id: 1 stepping: 1 microcode: 0x8001129
L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1714 high: 2804 min/max: 1550/3200 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2128 2: 1981
3: 2804 4: 2720 5: 1357 6: 1353 7: 1375 8: 1370 9: 1374 10: 1371 11: 1373
12: 1370 bogomips: 76671
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate irperf lahf_lm lbrv lm mca mce
nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sha_ni skinit smap smca sme smep
ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
Type: spectre_v2
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: Micro-Star MSI
driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 08:00.0
chip-ID: 10de:1c02 class-ID: 0300
Display: x11 server: X.org 1.21.1.2 compositor: gnome-shell driver:
loaded: nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2
v: 4.6.0 NVIDIA 495.44 direct render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 08:00.1 chip-ID: 10de:10f1
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 0a:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.10.84-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: no
vendor: Gigabyte driver: r8169 v: kernel port: f000 bus-ID: 03:00.0
Device-2: Broadcom BCM4360 802.11ac Wireless Network Adapter driver: wl
v: kernel modules: bcma bus-ID: 07:00.0 chip-ID: 14e4:43a0 class-ID: 0280
IF: wlp7s0 state: up mac: <filter>
Local Storage: total: 698.65 GiB used: 116.94 GiB (16.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 3B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3500312CS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5900 serial: <filter> rev: CA12 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH30N rev: A201
dev-links: cdrom
Features: speed: 40 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
used: 116.93 GiB (51.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 40809886-d17c-433b-876f-89a03d053b64
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: E832-7B45
ID-3: /run/media/nicholas/second disk raw-size: 434.51 GiB
size: 426.62 GiB (98.18%) used: 60 KiB (0.0%) fs: ext4 dev: /dev/sdb2
maj-min: 8:18 label: second disk
uuid: 1ec047b4-ec64-4d28-8893-f16ad7899256
ID-1: /dev/sdb1 maj-min: 8:17 size: 31.25 GiB fs: swap label: N/A
uuid: 14863704-322a-453c-b7a5-87bba34bb094
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-5:2 info: Corsair Gaming K70 LUX RGB Keyboard
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1b1c:1b33 class-ID: 0300
serial: <filter>
Device-2: 1-6:3 info: Logitech G502 Proteus Spectrum Optical Mouse
type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 300mA chip-ID: 046d:c332 class-ID: 0300
serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 34.4 C mobo: N/A gpu: nvidia temp: 53 C
Processes: 320 Uptime: 6h 23m wakeups: 0 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1585
pacman: 1578 lib: 450 flatpak: 0 snap: 7 Shell: Zsh v: 5.8
running-in: gnome-terminal inxi: 3.3.11
I’ve been playing RimWorld and Amid Evil through Lutris and have dash to dock set to the left side of the desktop. Whenever I’m playing these games the intelligent autohide will act up and start unhiding and hiding the dock in quick repetition. Any ideas how to fix this? I haven’t tested it with other fullscreen applications. I have no issues with it otherwise. I love the feature. I can turn it off and my games work fine.
The version of RimWorld I’m running is the Linux version. Amid Evil is running through Wine.
