I am jusing Manjaro XFCE version.
My bluetooth keyboard when my computer is rebooted will keep saying connected and disconnecting. In order to connect back, i have to set my keyboard to pairing mode then connect.
They keyboard that I am using is the Keychron K8
I have set AutoEnable to true in /etc/bluetooth/main.conf as well.
Kernel: 5.15.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=77ae071f-effa-4023-b31c-07018b3e6b24 rw quiet apparmor=1
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Mobo: ASUSTeK model: PRIME B560M-A v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 0820
date: 04/27/2021
Device-1: hid-dc:2c:26:0f:7f:62-battery model: Keychron K8 serial: N/A
charge: N/A status: discharging
Device-2: hidpp_battery_0 model: Logitech Wireless Gaming Mouse
status: discharging
Device-3: hidpp_battery_1 model: Logitech Wireless Solar Keyboard K750
serial: <filter> charge: 55% rechargeable: yes status: charging
RAM: total: 15.48 GiB used: 2.17 GiB (14.0%)
RAM Report:
Info: model: Intel Core i3-10320 bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 3 microcode: 0xEC
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 800/4600 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 60819
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust
tsc_deadline_timer vme x2apic xgetbv1 xsave xsavec xsaveopt xsaves
xtopology xtpr
Type: itlb_multihit status: KVM: VMX unsupported
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: eVga.com. driver: nvidia
v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1401 class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: nvidia gpu: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 4224x1280 s-dpi: 96 s-size: 1118x339mm (44.02x13.35")
s-diag: 1168mm (45.99")
Monitor-1: DP-0 pos: primary,top-left res: 1024x1280 hz: 60 dpi: 87
size: 299x374mm (11.77x14.72") diag: 479mm (18.85") modes: N/A
Monitor-2: DP-4 pos: bottom-r res: 1280x1024 hz: 60 dpi: 87
size: 374x299mm (14.72x11.77") diag: 479mm (18.85") modes: N/A
Monitor-3: HDMI-0 pos: primary,middle-c res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:f0c8 class-ID: 0403
Device-2: NVIDIA GM206 High Definition Audio vendor: eVga.com.
bus-ID: 01:00.1 chip-ID: 10de:0fba class-ID: 0403
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15fa class-ID: 0200
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:095a class-ID: 0280
bus-ID: 1-8:2 chip-ID: 8087:0a2a class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 931.52 GiB used: 75.12 GiB (8.1%)
model: WDS500G3X0C-00SJG0 size: 465.76 GiB block-size: physical: 4096 B
logical: 4096 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 111110WD temp: 57.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS500G2B0A-00SM50 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 20WD
scheme: GPT
ID-1: / raw-size: 465.46 GiB size: 457.08 GiB (98.20%)
used: 75.12 GiB (16.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 77ae071f-effa-4023-b31c-07018b3e6b24
ID-2: /boot/efi raw-size: 300 MiB size: 299.3 MiB (99.76%)
label: NO_LABEL uuid: 3249-E8A4
ID-1: /dev/sda1 maj-min: 8:1 size: 465.76 GiB fs: ext4 label: N/A
uuid: f77e80f4-d1fd-4755-a619-64de540f4260
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-8:2 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-2: 1-10:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-10.3:5 info: Logitech Unifying Receiver
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-10.4:6 info: Logitech Cordless Mouse Receiver type: Mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c537 class-ID: 0300
Device-3: 1-11:4 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:19af class-ID: 0300 serial: <filter>
Hub-3: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 20 Gb/s
System Temperatures: cpu: 27.8 C mobo: N/A gpu: nvidia temp: 60 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 6%
Processes: 259 Uptime: 4h 23m wakeups: 80 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1210
lib: 328 flatpak: 0 Shell: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.14
on a fresh boot when ever i try to enter a key on the bluetooth keyboard i just get a connected prompt followed by a disconnected prompt, nothing registers.
I have to open bluetooth manager and set the keyboard to pairing mode then connect it.
Either disable power management on the bluetooth device wiha TLP, or remove tlp
package all together and see if the issue persists.
It seems that Keychron firmware needs to have very specific sequence of actions in order for bluetooth to work. This is how it should be in the exact order:
- Remove the keyboard from known bluetooth devices if it’s there.
- Hold Fn+[1-3] to start pairing with the keyboard
- In blueman-manager press “Search” (or type
scan on
in bluetoothctl)
- DO NOT CONNECT THE DEVICE, pair it instead. Right click on device in blueman-manager and select “Pair” (or type
pair <mac>
in bluetoothctl)
- Pairing takes a couple of seconds after which keyboard disconnects. Wait until it fully disconnects
- Now, connect the keyboard. Double click it in blueman-manager (or
connect <mac>
in bluetoothctl)
- After keyboard is connected, make it “trusted”. Right click the device in blueman-manager and select “Trusted” (or
trust <mac>
in bluetoothctl)
This works but for some reason blueman kills the bluetooth signal when the screen is locked, keyboard disconnected, or system goes to sleep. But once you turn it back on the keyboard connects automatically. I can live with that! Thanks!
