Darktable stopped working (from repos)
Hi!
I can’t exactly know when did happen, for ther hace been two so bussy monthes that I have not played with photo in that time, but darktable, from repos, has stopped working. It just don’t starts any graphic window, nor says nothing when invoked from command line (no error sign, nothing… just stays still as initing till Ctrl^C is invoked, or a new instance tris to be started, and them says the typical message about a lock file present that has to be deleted… but when done, nothing again.
The ones from snap and flatpack do work, but I don’t like using snaps or flatpacks, and also they are not standard in place to keep config, and so. For that i would rather avoid them.
Downgrade does not work, for going to previous 4.2.1.x have the same failure. And 4.2.0.x have dependencies that are not found in pamac, or incompatible with another updates (ffmpeg, for example), so I don’t want to mess with that.
Renaming the .config/darktable folder to start a clean instance also do not work (exactly the same problem)
Any clue? I know there is not much info there to start, but there is absolutely no feedback when startting int from command line, so, not much more I cn say by now.
Thanks
Probably again opencl? Probably these packages: intel-compute-runtime and intel-graphics-compiler. Perhaps Manjaro has newer libraries, which cause problems with darktable now.
I will investigate this. But I don’t feel like that… Deleting the config folder should initiate darktable without opencl
Anyway, will try some things on that direcion and will tell.
I also just check mine, and it also don’t work.
At first, I get the following error at starting it in the Terminal and deleting the database after the prompt, just asking again at restart.
After reinstall darktable the Terminal just IDL and gives no output.
[init] database is locked, probably another process is already using it
trying to open the images in the running instance
ERROR: can't acquire database lock, aborting.
intel-compute-runtime and intel-graphics-compiler is also not on my PC.
…rename the .config/darktable to a backup and start again, did noting as well.
So, exactly the same problem.
I’ll continue testing
Mh… ok. I saw that I have installed already. Started it, no issue, but I am on unstable branch. Btw. opencl is enabled by default, so it seems, because there is a --disable-opencl parameter.
Try this:
darktable --disable-opencl
On VM with Manjaro on the stable branch it works also normally. :man_shrugging: Must be something very specific.
You’re right!
Starting with --disable-opencl makes the trick, and opens without problems. By now that’s enough, though there are interesting modules I use often than become extremely slow without opencl.
I was convinced that it will start without opencl in clean start (it was so time ago, but probably it changed), but so that darktable-cltest give information that opencl is ok and working on my computer, it tries ro use it anyway if noy specifically avoided.
I’ll have to check what has being upgraded related to opencl, but knowing that it works for you in unstable, it will probably get solved in future upgrades again, if unable to find it now.
What kernel are you in, just to check that?
Thanks!
I’ve been trying different things, and downgrading different packages (not much, no to make system unstable), but can’t find what can be modified or upgraded, darktable only opens with --disable-opencl
If anyone has another idea, it will be welcome!
Thanks
That’s what darktable -d opencl gives as output:
[dt_get_sysresource_level] switched to 2 as `large'
  total mem:       15781MB
  mipmap cache:    1972MB
  available mem:   10788MB
  singlebuff:      246MB
  OpenCL tune mem: WANTED
  OpenCL pinned:   OFF
[opencl_init] opencl related configuration options:
[opencl_init] opencl: ON
[opencl_init] opencl_scheduling_profile: 'very fast GPU'
[opencl_init] opencl_library: 'default path'
[opencl_init] opencl_device_priority: '*/!0,*/*/*'
[opencl_init] opencl_mandatory_timeout: 200
[opencl_init] opencl library 'libOpenCL' found on your system and loaded
And then keeps just waiting.
At first sight, seems OK… But does not work.
what opencl packages are installed and what gpu are you using ?
please post the output of
inxi --admin --verbosity=7 --filter --width
Of course!
Inxi:
  Kernel: 6.1.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=4d2d0e11-44f4-4f14-a6dc-d1f83f358998 rw quiet
    cryptdevice=UUID=95fc649b-53b3-4137-813b-69f906456198:luks-95fc649b-53b3-4137-813b-69f906456198
    root=/dev/mapper/luks-95fc649b-53b3-4137-813b-69f906456198 apparmor=1
    security=apparmor
    resume=/dev/mapper/luks-e4419e8b-5200-43f2-9f1f-8f886ee1616a
    udev.log_priority=3 ibt=off mem_sleep_default=deep
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel, cairo-dock
    wm: xfwm v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux
    base: Arch Linux
  Type: Laptop System: LENOVO product: 82K1 v: IdeaPad Gaming 3 15IHU6
    serial: <superuser required> Chassis: type: 10 v: IdeaPad Gaming 3 15IHU6
  Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <superuser required>
    UEFI: LENOVO v: H4CN23WW(V1.08) date: 02/11/2022
  ID-1: BAT1 charge: 27.1 Wh (58.8%) condition: 46.1/45.0 Wh (102.4%)
    volts: 11.9 min: 11.5 model: SMP L20M3PC2 type: Li-ion serial: <filter>
    status: not charging cycles: 14
  RAM: total: 15.41 GiB used: 4.59 GiB (29.8%)
  Info: model: 11th Gen Intel Core i5-11320H bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 2
    microcode: 0x28
    L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
    desc: 1x8 MiB
  Speed (MHz): avg: 3173 high: 4474 min/max: 400/4500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 3200 2: 1716 3: 4474
    4: 3200 5: 3200 6: 3200 7: 3200 8: 3200 bogomips: 51008
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
    invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
    movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
    rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
    sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
    vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
    filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
    driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
    ports: active: eDP-1 empty: DP-1, DP-2, DP-3, HDMI-A-1 bus-ID: 0000:00:02.0
    chip-ID: 8086:9a49 class-ID: 0300
  Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo
    driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
    status: current (as of 2023-03) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-22 bus-ID: 0000:01:00.0
    chip-ID: 10de:1f9d class-ID: 0302
  Device-3: Syntek Integrated Camera type: USB driver: uvcvideo bus-ID: 1-6:2
    chip-ID: 174f:244c class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
    loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: iris
    gpu: i915 display-ID: :0.0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: BOE Display 0x09d2 built: 2020 res: 1920x1080
    hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel Xe Graphics (TGL GT2)
    direct-render: Yes
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
    driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
    chip-ID: 8086:a0c8 class-ID: 0401
  API: ALSA v: k6.1.25-1-MANJARO status: kernel-api with: aoss
    type: oss-emulator tools: alsamixer,amixer
  Server-2: JACK v: 1.9.22 status: off with: a2jmidid status: off
    tools: cadence,jack_control,jack_mixer
  Server-3: PipeWire v: 0.3.70 status: active with: 1: pipewire-pulse
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
    chip-ID: 8086:a0f0 class-ID: 0280
    vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 0000:02:00.0
  Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-10:4
    chip-ID: 8087:0026 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 8 state: up address: see --recommends
  Device-1: luks-95fc649b-53b3-4137-813b-69f906456198 maj-min: 254:0
    type: LUKS dm: dm-0 size: 459.68 GiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 459.69 GiB
  Device-2: luks-e4419e8b-5200-43f2-9f1f-8f886ee1616a maj-min: 254:1
    type: LUKS dm: dm-1 size: 16.95 GiB
  Components:
  p-1: nvme0n1p3 maj-min: 259:3 size: 16.96 GiB
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
  Local Storage: total: 476.94 GiB used: 153.48 GiB (32.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512GZL
    lanes: 4 type: SSD serial: <filter> rev: C01C temp: 26.9 C scheme: GPT
  ID-1: / raw-size: 459.68 GiB size: 451.4 GiB (98.20%)
    used: 153.06 GiB (33.9%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-95fc649b-53b3-4137-813b-69f906456198 label: N/A
    uuid: 4d2d0e11-44f4-4f14-a6dc-d1f83f358998
    used: 14.5 MiB (4.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: NO_LABEL uuid: 932A-C731
  ID-1: swap-1 type: partition size: 16.95 GiB used: 416.7 MiB (2.4%)
    priority: -2 dev: /dev/dm-1 maj-min: 254:1
    mapped: luks-e4419e8b-5200-43f2-9f1f-8f886ee1616a label: swap
    uuid: 7cc37bde-631a-4e3b-8949-05e856d1a0e5
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-6:2 info: Syntek Integrated Camera type: Video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 174f:244c
  Device-2: 1-8:3 info: Integrated Express ITE Device(8176) type: Keyboard
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
    chip-ID: 048d:c966 class-ID: 0301
  Device-3: 1-10:4 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
    interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
    class-ID: e001
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 43.0 C mobo: N/A
  Processes: 385 Uptime: 2d 16h 20m wakeups: 11 Init: systemd v: 251
  default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: 2026 pm: pacman pkgs: 2020 libs: 491
  tools: octopi,pacaur,pamac,trizen,yay pm: flatpak pkgs: 6 Shell: Bash
  v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.26
opencl packages (everything from repos, no AUR)
opencl-headers 2:2022.09.30-1
opencl-nvidia 530.41.03-4
intel-oneapi-compiler-shared-opencl.cpu 2023.0.0-7
ocl-icd 2.3.1-1
lib32-ocl-icd 2.3.1-1
And acording to darktable info, all the chain seem fine (and was working a couple of monthes ago):
libOpenCl.so  --> /etc/OpenCL/vendors/nvidia.icd  which directs to
libnvidia-opencl1.so.1  which is a link to
libnividia-opencl.so.530.41.03
and modules nvidia and nvidia_uvm and special devices /dev/nvidia0  / dev/nvidiactl /dev/nvidia_uvm
exist are seem to be ok
So, I have no clue…
I don’t have that one installed. I did a quick install et viola it doesn’t run. So I conclude that darktable cannot use it and stuck somehow.
Probably use intel-compute-runtime instead. :man_shrugging:
may you post the additional infos of
echo $XDG_SESSION_TYPE
glxinfo | grep server
please install “mesa-utils” if glxinfo isn’t avaiable
I’m on x11
and the output is
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
Well, not solved yet, but we’re further on the line.
I’ve eliminated the intel-oneapi and related packages (don’t know why there were
Now darktable-cltest doesn’t stop so soon as before. Now it asked for gdb to be installed. I did so. And then darktable-cltest runs much further, but then segfaults.
[dt_get_sysresource_level] switched to 1 as `default'
  total mem:       15781MB
  available mem:   7890MB
  singlebuff:      123MB
  OpenCL tune mem: OFF
  OpenCL pinned:   OFF
[opencl_init] opencl_scheduling_profile: 'default'
[opencl_init] opencl_device_priority: '*/!0,*/*/*/!0,*'
[opencl_init] opencl_mandatory_timeout: 400
[opencl_init] found 2 platforms
[opencl_init] found 2 devices
[dt_opencl_device_init]
   DEVICE:                   0: 'Intel(R) Iris(R) Xe Graphics [0x9a49]'
   CANONICAL NAME:           intelririsrxegraphics0x9a49
   PLATFORM NAME & VENDOR:   Intel(R) OpenCL HD Graphics, Intel(R) Corporation
   DRIVER VERSION:           22.43.24595
   DEVICE VERSION:           OpenCL 3.0 NEO
   DEVICE_TYPE:              GPU
   GLOBAL MEM SIZE:          12626 MB
   MAX MEM ALLOC:            4096 MB
   MAX IMAGE SIZE:           16384 x 16384
   MAX WORK GROUP SIZE:      512
   MAX WORK ITEM DIMENSIONS: 3
   MAX WORK ITEM SIZES:      [ 512 512 512 ]
   ASYNC PIXELPIPE:          NO
   PINNED MEMORY TRANSFER:   NO
   MEMORY TUNING:            NO
   FORCED HEADROOM:          400
   AVOID ATOMICS:            NO
   MICRO NAP:                250
   ROUNDUP WIDTH:            16
   ROUNDUP HEIGHT:           16
   CHECK EVENT HANDLES:      128
   TILING ADVANTAGE:         0.000
   DEFAULT DEVICE:           NO
   KERNEL DIRECTORY:         /usr/share/darktable/kernels
   CL COMPILER OPTION:       -cl-fast-relaxed-math
   KERNEL LOADING TIME:       0.0098 sec
   DEVICE:                   1: 'NVIDIA GeForce GTX 1650'
   CANONICAL NAME:           nvidiageforcegtx1650
   PLATFORM NAME & VENDOR:   NVIDIA CUDA, NVIDIA Corporation
   DRIVER VERSION:           530.41.03
   DEVICE VERSION:           OpenCL 3.0 CUDA, SM_20 SUPPORT
   DEVICE_TYPE:              GPU
   GLOBAL MEM SIZE:          3906 MB
   MAX MEM ALLOC:            977 MB
   MAX IMAGE SIZE:           32768 x 32768
   MAX WORK GROUP SIZE:      1024
   MAX WORK ITEM SIZES:      [ 1024 1024 64 ]
   ASYNC PIXELPIPE:          NO
   MEMORY TUNING:            NO
   AVOID ATOMICS:            NO
   MICRO NAP:                250
   ROUNDUP WIDTH:            16
   ROUNDUP HEIGHT:           16
   DEFAULT DEVICE:           NO
0.109344 [opencl_fopen_stat] could not open file `/home/nacho/.cache/darktable/cached_kernels_for_NVIDIAGeForceGTX1650_5304103/demosaic_ppg.cl.bin'!
0.109349 [opencl_load_program] could not load cached binary program, trying to compile source
This GDB supports auto-downloading debuginfo from the following URLs:
  <https://debuginfod.archlinux.org>
Enable debuginfod for this session? (y or [n]) [answered N; input not from terminal]
Debuginfod has been disabled.
To make this setting permanent, add 'set debuginfod enabled off' to .gdbinit.
[New LWP 5137]
[New LWP 5138]
[New LWP 5139]
[New LWP 5140]
[New LWP 5144]
[New LWP 5145]
[New LWP 5146]
[New LWP 5147]
[New LWP 5148]
[New LWP 5149]
[New LWP 5150]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/usr/lib/libthread_db.so.1".
0x00007f5a060ea747 in wait4 () from /usr/lib/libc.so.6
Warning: 'set logging on', an alias for the command 'set logging enabled', is deprecated.
Use 'set logging enabled on'.
"on" or "off" expected.
#0  0x00007f5a060ea747 in wait4 () at /usr/lib/libc.so.6
#1  0x00007f5a063af7ea in  () at /usr/bin/../lib/darktable/libdarktable.so
#2  0x00007f5a06051f50 in <signal handler called> () at /usr/lib/libc.so.6
#3  0x00007f59a8a01002 in  () at /usr/lib/libnvidia-nvvm.so.4
#4  0x000000000000001d in  ()
#5  0x00007f59aa374d26 in  () at /usr/lib/libnvidia-nvvm.so.4
#6  0x0000000000000004 in  ()
#7  0x00007f5900000003 in  ()
#8  0x00007f59aa1dd568 in  () at /usr/lib/libnvidia-nvvm.so.4
#9  0x000000000000001e in  ()
#10 0x00007f59aa2fae10 in  () at /usr/lib/libnvidia-nvvm.so.4
#11 0x0000000000000031 in  ()
#12 0x00007f59aa3058ef in  () at /usr/lib/libnvidia-nvvm.so.4
#13 0x0000000000000004 in  ()
#14 0x0000564800000000 in  ()
#15 0x00007f59aa1ddafc in  () at /usr/lib/libnvidia-nvvm.so.4
#16 0x000000000000000e in  ()
#17 0x00007f59aa1ddb0b in  () at /usr/lib/libnvidia-nvvm.so.4
#18 0x0000000000000006 in  ()
#19 0x0000564800000001 in  ()
#20 0x00007f59aa1dd548 in  () at /usr/lib/libnvidia-nvvm.so.4
#21 0x000000000000001f in  ()
#22 0x00007f59aa1ddb12 in  () at /usr/lib/libnvidia-nvvm.so.4
#23 0x0000000000000006 in  ()
#24 0x00007ffe00000002 in  ()
#25 0x00007f59aa1ddb19 in  () at /usr/lib/libnvidia-nvvm.so.4
#26 0x000000000000001d in  ()
#27 0x00007f59aa374d26 in  () at /usr/lib/libnvidia-nvvm.so.4
#28 0x0000000000000004 in  ()
#29 0x00007f5900000003 in  ()
#30 0x00007f59aa1dd568 in  () at /usr/lib/libnvidia-nvvm.so.4
#31 0x000000000000001e in  ()
#32 0x00007ffe68f351c0 in  ()
#33 0x00007f59aabef830 in  () at /usr/lib/libnvidia-nvvm.so.4
#34 0x00007ffe68f351c0 in  ()
#35 0x00007ffe68f3e578 in  ()
#36 0x00007ffe68f3e588 in  ()
#37 0x00005648f1140070 in  ()
#38 0x0000000000000000 in  ()
  Id   Target Id                                          Frame
* 1    Thread 0x7f59f45e2680 (LWP 5136) "darktable-cltes" 0x00007f5a060ea747 in wait4 () from /usr/lib/libc.so.6
  2    Thread 0x7f59f3f4c6c0 (LWP 5137) "pool-spawner"    0x00007f5a061190dd in syscall () from /usr/lib/libc.so.6
  3    Thread 0x7f59f374b6c0 (LWP 5138) "gmain"           0x00007f5a061139df in poll () from /usr/lib/libc.so.6
  4    Thread 0x7f59f2f4a6c0 (LWP 5139) "gdbus"           0x00007f5a061139df in poll () from /usr/lib/libc.so.6
  5    Thread 0x7f59f17ff6c0 (LWP 5140) "darktable-cltes" 0x00007f5a0609b766 in ?? () from /usr/lib/libc.so.6
  6    Thread 0x7f59c95ff6c0 (LWP 5144) "cuda-EvtHandlr"  0x00007f5a061139df in poll () from /usr/lib/libc.so.6
  7    Thread 0x7f59c8dfe6c0 (LWP 5145) "darktable-cltes" 0x00007f5a0609b766 in ?? () from /usr/lib/libc.so.6
  8    Thread 0x7f59c1fff6c0 (LWP 5146) "darktable-cltes" 0x00007f5a0609b766 in ?? () from /usr/lib/libc.so.6
  9    Thread 0x7f59c17fe6c0 (LWP 5147) "darktable-cltes" 0x00007f5a0609b766 in ?? () from /usr/lib/libc.so.6
  10   Thread 0x7f59c0ffd6c0 (LWP 5148) "darktable-cltes" 0x00007f5a0609b766 in ?? () from /usr/lib/libc.so.6
  11   Thread 0x7f59adfff6c0 (LWP 5149) "darktable-cltes" 0x00007f5a0609b766 in ?? () from /usr/lib/libc.so.6
  12   Thread 0x7f59ad7fe6c0 (LWP 5150) "darktable-cltes" 0x00007f5a0609b766 in ?? () from /usr/lib/libc.so.6
Thread 12 (Thread 0x7f59ad7fe6c0 (LWP 5150) "darktable-cltes"):
#0  0x00007f5a0609b766 in  () at /usr/lib/libc.so.6
#1  0x00007f5a060a6930 in  () at /usr/lib/libc.so.6
#2  0x00007f59e28fb752 in  () at /usr/lib/libnvidia-opencl.so.1
#3  0x00007f59e2aa6cf8 in  () at /usr/lib/libnvidia-opencl.so.1
#4  0x00007f5a0609ebb5 in  () at /usr/lib/libc.so.6
#5  0x00007f5a06120d90 in  () at /usr/lib/libc.so.6
Thread 11 (Thread 0x7f59adfff6c0 (LWP 5149) "darktable-cltes"):
Thread 10 (Thread 0x7f59c0ffd6c0 (LWP 5148) "darktable-cltes"):
Thread 9 (Thread 0x7f59c17fe6c0 (LWP 5147) "darktable-cltes"):
Thread 8 (Thread 0x7f59c1fff6c0 (LWP 5146) "darktable-cltes"):
Thread 7 (Thread 0x7f59c8dfe6c0 (LWP 5145) "darktable-cltes"):
#1  0x00007f5a0609e294 in pthread_cond_timedwait () at /usr/lib/libc.so.6
#2  0x00007f59e2a1778f in  () at /usr/lib/libnvidia-opencl.so.1
Thread 6 (Thread 0x7f59c95ff6c0 (LWP 5144) "cuda-EvtHandlr"):
#0  0x00007f5a061139df in poll () at /usr/lib/libc.so.6
#1  0x00007f59e2aaaa09 in  () at /usr/lib/libnvidia-opencl.so.1
#2  0x00007f59e2b682db in  () at /usr/lib/libnvidia-opencl.so.1
Thread 5 (Thread 0x7f59f17ff6c0 (LWP 5140) "darktable-cltes"):
#1  0x00007f5a0609df90 in pthread_cond_wait () at /usr/lib/libc.so.6
#2  0x00007f5a02acfe51 in __gthread_cond_wait (__mutex=<optimized out>, __cond=<optimized out>) at /usr/src/debug/gcc/gcc-build/x86_64-pc-linux-gnu/libstdc++-v3/include/x86_64-pc-linux-gnu/bits/gthr-default.h:865
        __e = <optimized out>
#3  std::__condvar::wait(std::mutex&) (__m=<optimized out>, this=<optimized out>) at /usr/src/debug/gcc/gcc-build/x86_64-pc-linux-gnu/libstdc++-v3/include/bits/std_mutex.h:155
#4  std::condition_variable::wait(std::unique_lock<std::mutex>&) (this=<optimized out>, __lock=<optimized out>) at /usr/src/debug/gcc/gcc/libstdc++-v3/src/c++11/condition_variable.cc:41
#5  0x00007f59f1fec09e in  () at /usr/lib/intel-opencl/libigdrcl.so
#6  0x00007f5a0609ebb5 in  () at /usr/lib/libc.so.6
#7  0x00007f5a06120d90 in  () at /usr/lib/libc.so.6
Thread 4 (Thread 0x7f59f2f4a6c0 (LWP 5139) "gdbus"):
#1  0x00007f5a05f8517f in  () at /usr/lib/libglib-2.0.so.0
#2  0x00007f5a05f27c7f in g_main_loop_run () at /usr/lib/libglib-2.0.so.0
#3  0x00007f5a05358d5c in  () at /usr/lib/libgio-2.0.so.0
#4  0x00007f5a05f55315 in  () at /usr/lib/libglib-2.0.so.0
#5  0x00007f5a0609ebb5 in  () at /usr/lib/libc.so.6
#6  0x00007f5a06120d90 in  () at /usr/lib/libc.so.6
Thread 3 (Thread 0x7f59f374b6c0 (LWP 5138) "gmain"):
#2  0x00007f5a05f271a2 in g_main_context_iteration () at /usr/lib/libglib-2.0.so.0
#3  0x00007f5a05f271f2 in  () at /usr/lib/libglib-2.0.so.0
Thread 2 (Thread 0x7f59f3f4c6c0 (LWP 5137) "pool-spawner"):
#0  0x00007f5a061190dd in syscall () at /usr/lib/libc.so.6
#1  0x00007f5a05f7e7b5 in g_cond_wait () at /usr/lib/libglib-2.0.so.0
#2  0x00007f5a05ef2fb4 in  () at /usr/lib/libglib-2.0.so.0
#3  0x00007f5a05f59f9e in  () at /usr/lib/libglib-2.0.so.0
Thread 1 (Thread 0x7f59f45e2680 (LWP 5136) "darktable-cltes"):
[Inferior 1 (process 5136) detached]
backtrace written to /tmp/darktable_bt_WZRI41.txt
Violación de segmento (`core' generado)
and the same happens if I use prime-run darktable-cltest to run it on the nvidia card:
  total mem:       15781MB
  singlebuff:      123MB
  OpenCL pinned:   OFF
   DEVICE_TYPE:              GPU
   ASYNC PIXELPIPE:          NO
   MEMORY TUNING:            NO
   AVOID ATOMICS:            NO
   MICRO NAP:                250
   ROUNDUP WIDTH:            16
   ROUNDUP HEIGHT:           16
   DEFAULT DEVICE:           NO
   KERNEL LOADING TIME:       0.0099 sec
   DEVICE_TYPE:              GPU
   ASYNC PIXELPIPE:          NO
   MEMORY TUNING:            NO
   AVOID ATOMICS:            NO
   MICRO NAP:                250
   ROUNDUP WIDTH:            16
   ROUNDUP HEIGHT:           16
   DEFAULT DEVICE:           NO
0.115729 [opencl_fopen_stat] could not open file `/home/nacho/.cache/darktable/cached_kernels_for_NVIDIAGeForceGTX1650_5304103/demosaic_ppg.cl.bin'!
0.115734 [opencl_load_program] could not load cached binary program, trying to compile source
[New LWP 5194]
[New LWP 5195]
[New LWP 5196]
[New LWP 5197]
[New LWP 5201]
[New LWP 5202]
[New LWP 5203]
[New LWP 5204]
[New LWP 5205]
[New LWP 5206]
[New LWP 5207]
0x00007ff0496ea747 in wait4 () from /usr/lib/libc.so.6
#0  0x00007ff0496ea747 in wait4 () at /usr/lib/libc.so.6
#1  0x00007ff0499af7ea in  () at /usr/bin/../lib/darktable/libdarktable.so
#2  0x00007ff049651f50 in <signal handler called> () at /usr/lib/libc.so.6
#3  0x00007fefeba01002 in  () at /usr/lib/libnvidia-nvvm.so.4
#5  0x00007fefed374d26 in  () at /usr/lib/libnvidia-nvvm.so.4
#7  0x00007fef00000003 in  ()
#8  0x00007fefed1dd568 in  () at /usr/lib/libnvidia-nvvm.so.4
#10 0x00007fefed2fae10 in  () at /usr/lib/libnvidia-nvvm.so.4
#12 0x00007fefed3058ef in  () at /usr/lib/libnvidia-nvvm.so.4
#14 0x000055c900000000 in  ()
#15 0x00007fefed1ddafc in  () at /usr/lib/libnvidia-nvvm.so.4
#17 0x00007fefed1ddb0b in  () at /usr/lib/libnvidia-nvvm.so.4
#19 0x000055c900000001 in  ()
#20 0x00007fefed1dd548 in  () at /usr/lib/libnvidia-nvvm.so.4
#22 0x00007fefed1ddb12 in  () at /usr/lib/libnvidia-nvvm.so.4
#25 0x00007fefed1ddb19 in  () at /usr/lib/libnvidia-nvvm.so.4
#27 0x00007fefed374d26 in  () at /usr/lib/libnvidia-nvvm.so.4
#29 0x00007fef00000003 in  ()
#30 0x00007fefed1dd568 in  () at /usr/lib/libnvidia-nvvm.so.4
#32 0x00007ffec63a42b0 in  ()
#33 0x00007fefedbef830 in  () at /usr/lib/libnvidia-nvvm.so.4
#34 0x00007ffec63a42b0 in  ()
#35 0x00007ffec63ad668 in  ()
#36 0x00007ffec63ad678 in  ()
#37 0x000055c9345baac0 in  ()
  Id   Target Id                                          Frame
* 1    Thread 0x7ff037afa680 (LWP 5193) "darktable-cltes" 0x00007ff0496ea747 in wait4 () from /usr/lib/libc.so.6
  2    Thread 0x7ff0373ff6c0 (LWP 5194) "pool-spawner"    0x00007ff0497190dd in syscall () from /usr/lib/libc.so.6
  3    Thread 0x7ff036bfe6c0 (LWP 5195) "gmain"           0x00007ff0497139df in poll () from /usr/lib/libc.so.6
  4    Thread 0x7ff0363fd6c0 (LWP 5196) "gdbus"           0x00007ff0497139df in poll () from /usr/lib/libc.so.6
  5    Thread 0x7ff034d666c0 (LWP 5197) "darktable-cltes" 0x00007ff04969b766 in ?? () from /usr/lib/libc.so.6
  6    Thread 0x7ff00cfff6c0 (LWP 5201) "cuda-EvtHandlr"  0x00007ff0497139df in poll () from /usr/lib/libc.so.6
  7    Thread 0x7ff005fff6c0 (LWP 5202) "darktable-cltes" 0x00007ff04969b766 in ?? () from /usr/lib/libc.so.6
  8    Thread 0x7ff0057fe6c0 (LWP 5203) "darktable-cltes" 0x00007ff04969b766 in ?? () from /usr/lib/libc.so.6
  9    Thread 0x7ff004ffd6c0 (LWP 5204) "darktable-cltes" 0x00007ff04969b766 in ?? () from /usr/lib/libc.so.6
  10   Thread 0x7ff001fff6c0 (LWP 5205) "darktable-cltes" 0x00007ff04969b766 in ?? () from /usr/lib/libc.so.6
  11   Thread 0x7ff0017fe6c0 (LWP 5206) "darktable-cltes" 0x00007ff04969b766 in ?? () from /usr/lib/libc.so.6
  12   Thread 0x7ff000ffd6c0 (LWP 5207) "darktable-cltes" 0x00007ff04969b766 in ?? () from /usr/lib/libc.so.6
Thread 12 (Thread 0x7ff000ffd6c0 (LWP 5207) "darktable-cltes"):
#0  0x00007ff04969b766 in  () at /usr/lib/libc.so.6
#1  0x00007ff0496a6930 in  () at /usr/lib/libc.so.6
#2  0x00007ff0268fb752 in  () at /usr/lib/libnvidia-opencl.so.1
#3  0x00007ff026aa6cf8 in  () at /usr/lib/libnvidia-opencl.so.1
#4  0x00007ff04969ebb5 in  () at /usr/lib/libc.so.6
#5  0x00007ff049720d90 in  () at /usr/lib/libc.so.6
Thread 11 (Thread 0x7ff0017fe6c0 (LWP 5206) "darktable-cltes"):
Thread 10 (Thread 0x7ff001fff6c0 (LWP 5205) "darktable-cltes"):
Thread 9 (Thread 0x7ff004ffd6c0 (LWP 5204) "darktable-cltes"):
Thread 8 (Thread 0x7ff0057fe6c0 (LWP 5203) "darktable-cltes"):
Thread 7 (Thread 0x7ff005fff6c0 (LWP 5202) "darktable-cltes"):
#1  0x00007ff04969e294 in pthread_cond_timedwait () at /usr/lib/libc.so.6
#2  0x00007ff026a1778f in  () at /usr/lib/libnvidia-opencl.so.1
Thread 6 (Thread 0x7ff00cfff6c0 (LWP 5201) "cuda-EvtHandlr"):
#0  0x00007ff0497139df in poll () at /usr/lib/libc.so.6
#1  0x00007ff026aaaa09 in  () at /usr/lib/libnvidia-opencl.so.1
#2  0x00007ff026b682db in  () at /usr/lib/libnvidia-opencl.so.1
Thread 5 (Thread 0x7ff034d666c0 (LWP 5197) "darktable-cltes"):
#1  0x00007ff04969df90 in pthread_cond_wait () at /usr/lib/libc.so.6
#2  0x00007ff045ecfe51 in __gthread_cond_wait (__mutex=<optimized out>, __cond=<optimized out>) at /usr/src/debug/gcc/gcc-build/x86_64-pc-linux-gnu/libstdc++-v3/include/x86_64-pc-linux-gnu/bits/gthr-default.h:865
#5  0x00007ff0355ec09e in  () at /usr/lib/intel-opencl/libigdrcl.so
#6  0x00007ff04969ebb5 in  () at /usr/lib/libc.so.6
#7  0x00007ff049720d90 in  () at /usr/lib/libc.so.6
Thread 4 (Thread 0x7ff0363fd6c0 (LWP 5196) "gdbus"):
#1  0x00007ff04949d17f in  () at /usr/lib/libglib-2.0.so.0
#2  0x00007ff04943fc7f in g_main_loop_run () at /usr/lib/libglib-2.0.so.0
#3  0x00007ff04885fd5c in  () at /usr/lib/libgio-2.0.so.0
#4  0x00007ff04946d315 in  () at /usr/lib/libglib-2.0.so.0
#5  0x00007ff04969ebb5 in  () at /usr/lib/libc.so.6
#6  0x00007ff049720d90 in  () at /usr/lib/libc.so.6
Thread 3 (Thread 0x7ff036bfe6c0 (LWP 5195) "gmain"):
#2  0x00007ff04943f1a2 in g_main_context_iteration () at /usr/lib/libglib-2.0.so.0
#3  0x00007ff04943f1f2 in  () at /usr/lib/libglib-2.0.so.0
Thread 2 (Thread 0x7ff0373ff6c0 (LWP 5194) "pool-spawner"):
#0  0x00007ff0497190dd in syscall () at /usr/lib/libc.so.6
#1  0x00007ff0494967b5 in g_cond_wait () at /usr/lib/libglib-2.0.so.0
#2  0x00007ff04940afb4 in  () at /usr/lib/libglib-2.0.so.0
#3  0x00007ff049471f9e in  () at /usr/lib/libglib-2.0.so.0
Thread 1 (Thread 0x7ff037afa680 (LWP 5193) "darktable-cltes"):
[Inferior 1 (process 5193) detached]
backtrace written to /tmp/darktable_bt_DMBS41.txt
/usr/sbin/prime-run: línea 2:  5193 Violación de segmento  (`core' generado) __NV_PRIME_RENDER_OFFLOAD=1 __VK_LAYER_NV_optimus=NVIDIA_only __GLX_VENDOR_LIBRARY_NAME=nvidia "$@"
The backtrace files generated just say
this is daktable 4.2.1 reporting a segfault:
And nothing more, so not much helpful…
Solved!!!
I had to reinstall some packages (all opencl ones, nvidia ones, darktable, and some other ones just in case) and now darktable is uo and running with opencl again!!
Thanks a lot
If you read along, perhaps that can help you. I had to uninstall the intel-oneapi* packages that were on my system (not sure one) and install the intel-compute, and also install gdb, and reinstall some nvidia and opencl packages, and now everything is working again.
Good luck!
