Dark Mode in XFCE with gtk?
How do I use GTK+ to make default system theme dark?
im am noob very dum
If i remember correctly, the default GTK theme on Manjaro is Matcha-sea. Then its dark variant would be Matcha-dark-sea, and AFAIK is already installed. So you would only need to change the main theme and the window manager theme.
https://docs.xfce.org/xfce/xfce4-settings/appearance#style
https://docs.xfce.org/xfce/xfwm4/preferences#style
That’s correct. If you go into Settings > Appearance > Style & select Matcha-dark-sea, it will give you a dark mode. Personally I like the Adwaita look, so you could always download the Adwaita themes & choose the dark option. Hopefully you get sorted…:slight_smile:
PS, welcome to Manjaro!!!
I’m comfortable using Greybird-Dark theme:
Thanks for being so helpful!
Pleasure. Enjoy the adventure :slight_smile:
