CyPS/2 Cypress Trackpad not working
I just installed Manjaro 20.1 Mikah with latest kernel 5.8.1-3-MANJARO and I noticed the CyPS/2 Cypress Trackpad is not working. No cursor moving and no left/right clicking also. Despite the trackpad is being recognized correctly as CyPS/2 Cypress Trackpad. Here is the debug info of my trackpad. How can I make it work? Which driver package do I need to install?
~ >>> xinput list
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ MOSART Semi. 2.4G Keyboard Mouse id=12 [slave pointer (2)]
⎜ ↳ MOSART Semi. 2.4G Keyboard Mouse Consumer Control id=13 [slave pointer (2)]
⎜ ↳ CyPS/2 Cypress Trackpad id=16 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Video Bus id=7 [slave keyboard (3)]
↳ Power Button id=8 [slave keyboard (3)]
↳ Sleep Button id=9 [slave keyboard (3)]
I: Bus=0011 Vendor=0002 Product=0011 Version=0001
N: Name=“CyPS/2 Cypress Trackpad”
P: Phys=isa0060/serio2/input0
S: Sysfs=/devices/platform/i8042/serio2/input/input26
U: Uniq=
H: Handlers=event12 mouse1
B: PROP=9
B: EV=b
B: KEY=e520 70000 0 0 0 0
B: ABS=660800011000003
~ >>> xinput
↳ USB 2.0 PC Cam id=10 [slave keyboard (3)]
↳ MOSART Semi. 2.4G Keyboard Mouse id=11 [slave keyboard (3)]
↳ MOSART Semi. 2.4G Keyboard Mouse System Control id=14 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=15 [slave keyboard (3)]
↳ MOSART Semi. 2.4G Keyboard Mouse Consumer Control id=17 [slave keyboard (3)]
~ >>> xinput --list-props 16
Device ‘CyPS/2 Cypress Trackpad’:
Device Enabled (169): 1
Coordinate Transformation Matrix (171): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
libinput Tapping Enabled (324): 0
libinput Tapping Enabled Default (325): 0
libinput Tapping Drag Enabled (326): 1
libinput Tapping Drag Enabled Default (327): 1
libinput Tapping Drag Lock Enabled (328): 0
libinput Tapping Drag Lock Enabled Default (329): 0
libinput Tapping Button Mapping Enabled (330): 1, 0
libinput Tapping Button Mapping Default (331): 1, 0
libinput Natural Scrolling Enabled (304): 0
libinput Natural Scrolling Enabled Default (305): 0
libinput Disable While Typing Enabled (332): 1
libinput Disable While Typing Enabled Default (333): 1
libinput Scroll Methods Available (306): 1, 1, 0
libinput Scroll Method Enabled (307): 1, 0, 0
libinput Scroll Method Enabled Default (308): 1, 0, 0
libinput Accel Speed (315): 0.000000
libinput Accel Speed Default (316): 0.000000
libinput Left Handed Enabled (320): 0
libinput Left Handed Enabled Default (321): 0
libinput Send Events Modes Available (289): 1, 1
libinput Send Events Mode Enabled (290): 0, 0
libinput Send Events Mode Enabled Default (291): 0, 0
Device Node (292): “/dev/input/event12”
Device Product ID (293): 2, 17
libinput Drag Lock Buttons (322):
libinput Horizontal Scroll Enabled (323): 1
[    0.177187] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 1.573895] dw_dmac INTL9C60:01: Missing DT data
[ 3.075644] atkbd serio0: Unknown key released (translated set 2, code 0x7c on isa0060/serio0).
[ 3.075659] atkbd serio0: Use 'setkeycodes 7c ’ to make it known.
[ 3.276820] atkbd serio0: Unknown key released (translated set 2, code 0x7c on isa0060/serio0).
[ 3.276835] atkbd serio0: Use 'setkeycodes 7c ’ to make it known.
[ 3.480471] atkbd serio0: Unknown key released (translated set 2, code 0x7c on isa0060/serio0).
[ 3.480486] atkbd serio0: Use 'setkeycodes 7c ’ to make it known.
[ 3.683893] atkbd serio0: Unknown key released (translated set 2, code 0x7c on isa0060/serio0).
[ 3.683908] atkbd serio0: Use 'setkeycodes 7c ’ to make it known.
[ 7.832617] r8169 0000:01:00.0: can’t disable ASPM; OS doesn’t have ASPM control
[ 8.971719] atkbd serio0: Unknown key released (translated set 2, code 0x7c on isa0060/serio0).
[ 8.971724] atkbd serio0: Use 'setkeycodes 7c ’ to make it known.
[ 9.176397] atkbd serio0: Unknown key released (translated set 2, code 0x7c on isa0060/serio0).
[ 9.176403] atkbd serio0: Use 'setkeycodes 7c ’ to make it known.
[ 9.750767] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[ 9.931085] uvcvideo 1-1:1.0: Entity type for entity Processing 3 was not initialized!
[ 9.931092] uvcvideo 1-1:1.0: Entity type for entity Extension 2 was not initialized!
[ 9.931095] uvcvideo 1-1:1.0: Entity type for entity Camera 1 was not initialized!
[ 11.014978] kauditd_printk_skb: 23 callbacks suppressed
[ 21.055689] kauditd_printk_skb: 6 callbacks suppressed
[ 34.073948] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 34.075654] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 34.084084] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 34.086148] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 34.094193] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 34.114037] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 34.134605] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 34.136240] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 34.144848] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 34.146359] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 34.154681] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 34.175121] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 34.195541] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 36.691156] psmouse serio2: cypress_ps2: Reconnect: Unable to initialize Cypress absolute mode.
[ 48.219004] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 48.221000] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 48.229280] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 48.230837] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 48.238726] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 48.258390] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 48.260396] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 48.268238] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 48.270218] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 48.278103] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 48.280087] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 48.287952] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 48.289980] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 48.297766] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 48.299847] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 48.307818] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 48.309632] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 48.317527] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 48.319619] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 48.321591] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 48.327755] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 48.330069] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 49.454118] psmouse serio2: cypress_ps2: Reconnect: Unable to initialize Cypress absolute mode.
[ 50.996380] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 50.998640] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 51.000360] psmouse serio2: Trackpad at isa0060/serio2/input0 lost sync at byte 1
[ 53.839105] kauditd_printk_skb: 11 callbacks suppressed
[ 77.273264] atkbd serio0: Unknown key released (translated set 2, code 0x7c on isa0060/serio0).
[ 77.273273] atkbd serio0: Use 'setkeycodes 7c ’ to make it known.
[ 77.476495] atkbd serio0: Unknown key released (translated set 2, code 0x7c on isa0060/serio0).
[ 77.476511] atkbd serio0: Use 'setkeycodes 7c ’ to make it known.
~ >>> inxi -Fazy
Kernel: 5.8.1-3-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=f3e rw quiet udev.log_priority=3
Desktop: LXQt 0.15.1 tk: Qt 5.15.0 info: lxqt-panel wm: Openbox 3.6.1
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: LYZPIN product: SL v: N/A serial: Chassis:
type: 10 serial:
Mobo: LYZPIN model: SL v: Type2 - Board Version serial:
UEFI: INSYDE v: 22.16 date: 07/29/2015
ID-1: BAT1 charge: 10.3 Wh condition: 28.6/28.6 Wh (100%) volts: 7.2/8.4
model: LG Harris Beach type: Li-ion serial: status: Discharging
cycles: 34
Topology: Quad Core model: Intel Celeron N3150 bits: 64 type: MCP
arch: Airmont family: 6 model-id: 4C (76) stepping: 3 microcode: 368
L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 12805
Speed: 480 MHz min/max: 480/2080 MHz Core speeds (MHz): 1: 482 2: 480 3: 480
4: 480
Type: spec_store_bypass status: Not affected
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
Integrated Graphics
driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:22b1
Device-2: Silicon Motion - Taiwan (formerly Feiya ) 300k Pixel Camera
type: USB driver: uvcvideo bus ID: 1-1:2 chip ID: 090c:037c
Display: x11 server: X 1.20.8 compositor: compton driver: intel
unloaded: modesetting alternate: fbdev,vesa resolution:
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
High Definition Audio
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:2284
Sound Server: ALSA v: k5.8.1-3-MANJARO
Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169 v: kernel
port: 1000 bus ID: 01:00.0 chip ID: 10ec:8136
IF: enp1s0 state: down mac:
Device-2: Realtek RTL8723BU 802.11b/g/n WLAN Adapter type: USB
driver: btusb,rtl8xxxu bus ID: 1-5:3 chip ID: 0bda:b720 serial:
IF: wlp0s20u5i2 state: up mac:
Local Storage: total: 29.12 GiB used: 5.52 GiB (18.9%)
ID-1: /dev/mmcblk0 vendor: Samsung model: BGND3R size: 29.12 GiB block size:
physical: 512 B logical: 512 B serial: rev: 0x7 scheme: GPT
ID-1: / raw size: 29.02 GiB size: 28.44 GiB (98.00%) used: 5.52 GiB (19.4%)
fs: ext4 dev: /dev/mmcblk0p2
System Temperatures: cpu: 39.0 C mobo: N/A
Processes: 173 Uptime: 3m Memory: 3.68 GiB used: 656.3 MiB (17.4%)
Init: systemd v: 245 Compilers: gcc: N/A Packages: pacman: 750 lib: 184
Shell: Zsh v: 5.8 running in: qterminal inxi: 3.1.05
[ 169.648] (II) event7 - CyPS/2 Cypress Trackpad: device is a touchpad
[ 172.411] (II) config/udev: removing device CyPS/2 Cypress Trackpad
[ 172.411] (II) event7 - CyPS/2 Cypress Trackpad: device removed
[ 172.516] (II) UnloadModule: “libinput”
[ 173.740] (II) config/udev: Adding input device CyPS/2 Cypress Trackpad (/dev/input/mouse0)
[ 173.740] () CyPS/2 Cypress Trackpad: Applying InputClass “touchpad catchall”
[ 173.740] (II) LoadModule: “synaptics”
[ 173.743] (WW) Warning, couldn’t open module synaptics
[ 173.743] (EE) Failed to load module “synaptics” (module does not exist, 0)
[ 173.743] (EE) No input driver matching synaptics' [ 173.743] (II) Falling back to input driver libinput’
[ 173.743] (II) Using input driver ‘libinput’ for ‘CyPS/2 Cypress Trackpad’
[ 173.743] (
) CyPS/2 Cypress Trackpad: always reports core events
[ 173.743] () Option “Device” “/dev/input/mouse0”
[ 173.744] (
) Option “_source” “server/udev”
[ 173.791] (II) mouse0 - not using input device ‘/dev/input/mouse0’.
[ 173.791] (EE) libinput: CyPS/2 Cypress Trackpad: Failed to create a device for /dev/input/mouse0
[ 173.792] (EE) PreInit returned 2 for “CyPS/2 Cypress Trackpad”
[ 173.792] (II) UnloadModule: “libinput”
[ 173.999] (II) config/udev: Adding input device CyPS/2 Cypress Trackpad (/dev/input/event7)
[ 173.999] (**) CyPS/2 Cypress Trackpad: Applying InputClass “libinput touchpad catchall”
[ 174.000] () CyPS/2 Cypress Trackpad: Applying InputClass “touchpad catchall”
[ 174.000] (II) LoadModule: “synaptics”
[ 174.002] (WW) Warning, couldn’t open module synaptics
[ 174.002] (EE) Failed to load module “synaptics” (module does not exist, 0)
[ 174.002] (EE) No input driver matching synaptics' [ 174.003] (II) Falling back to input driver libinput’
[ 174.003] (II) Using input driver ‘libinput’ for ‘CyPS/2 Cypress Trackpad’
[ 174.003] (
[ 174.003] () Option “Device” “/dev/input/event7”
[ 174.003] (
[ 174.018] (II) event7 - CyPS/2 Cypress Trackpad: is tagged by udev as: Touchpad
[ 174.032] (II) event7 - CyPS/2 Cypress Trackpad: device is a touchpad
[ 174.033] (II) event7 - CyPS/2 Cypress Trackpad: device removed
[ 174.088] () Option “config_info” “udev:/sys/devices/platform/i8042/serio2/input/input45/event7”
[ 174.088] (II) XINPUT: Adding extended input device “CyPS/2 Cypress Trackpad” (type: TOUCHPAD, id 12)
[ 174.102] (
) Option “AccelerationScheme” “none”
[ 174.110] () CyPS/2 Cypress Trackpad: (accel) selected scheme none/0
[ 174.110] (
) CyPS/2 Cypress Trackpad: (accel) acceleration factor: 2.000
[ 174.110] (**) CyPS/2 Cypress Trackpad: (accel) acceleration threshold: 4
[ 174.125] (II) event7 - CyPS/2 Cypress Trackpad: is tagged by udev as: Touchpad
[ 174.136] (II) event7 - CyPS/2 Cypress Trackpad: device is a touchpad
