Hi all, I recently installed the official Nvidia driver using the offline runfile. Now everything seems fine except that the launch time of apps started from my customized keyboard shortcuts are really slow.
For example, I set Ctrl+Alt+T to launch the terminal and it would take about 10 sec to start the terminal by the keyboard shortcut, while it would be normal time to start the apps by directly clicking mouse.
Does anyone know where the problem is??? THX for your help!
Here is my basic system info and Nvidia driver version:
But I do not know what is the difference? Is it NOT recommended to install Nvidia driver by the offline runfile? So far, the OS works fine expept the launching time problem mentioned above. In addition, in Manjaro Setting Manager, ther is only Nvidia-470XX showed up.
Actually, I have already tried to use the mhwd to install the default nvidia driver provided by Manjaro, which, unfortunately, caused me a big trouble, and consequently, I reluctantly turned to the nvidia official site and used the offline method. Maybe it was because of the mismatch of the kernel version and linux-headers.
Anyway, what I want to know is whether the launching delay of the shortcuts is related to the nvidia driver or the gnome desktop bug?
Does anyone have some clues? Excuse me for not being an expert in Linux.
