Customized folder options for every folder
I noticed that if I change a “folder option” in any folder (for example Arrange Items by : … , or Icon view , List view …) , it will change on every other single folder on my Manjaro OS XFCE (Thunar).
Wouldn’t be better to save each configuration for its own folder ( I guess ““Windows”” (some random OS) does that .) , like having Icon view in folder1 while List View in folder2.
Is there a config file I can store within a folder that dictates such kind of customization for the folder content . (Would be an easy solution then) …
AFAIK thunar (Xfce’s file manager) doesn’t handle that. But dolphin (KDE) does, and probably others…
