Hello everyone,
I wrote my own keyboard layout and stored it as /home/david/.Xmodmap. I can activate it with xmodmap /home/david/.Xmodmap .
The first problem is that the new keyboard layout only works outside of the terminal.
I also created a file called myxmod.desktop that looks like this:
[Desktop Entry]
Name=MyXmodmap
MimeType=
Exec=xmodmap /home/david/.Xmodmap
Type=Application
GenericName=Terminal
Terminal=false
Icon=terminal
Comment=xmodmap
X-KDE-StartupNotify=false
Categories=System;
X-GNOME-UsesNotifications=true
I stored this file in ./config/autostart but the new keyboard layout does not automatically work after a startup.
I hope you can help me!
David
PS: Information about my software and hardware:
manjaro% inxi -Fazy
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=116ef32c-01ce-4135-b673-172a7f9c2c4d rw quiet splash apparmor=1
Desktop: GNOME 3.38.2 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1
Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: P8B75-M LX PLUS v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 0501 date: 10/10/2012
Info: Quad Core model: Intel Core i5-3330 bits: 64 type: MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
L2 cache: 6 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 23956
Speed: 1596 MHz min/max: 1600/3200 MHz Core speeds (MHz): 1: 1596 2: 1597
3: 1597 4: 1597
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Type: srbds status: Vulnerable: No microcode
Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics
vendor: ASUSTeK P8H77-I driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:0152
Device-2: NVIDIA GK106 [GeForce GTX 650 Ti] vendor: Gigabyte driver: nouveau
v: kernel bus ID: 01:00.0 chip ID: 10de:11c6
Display: wayland server: X.org 1.20.10 compositor: gnome-shell
driver: intel,nouveau unloaded: modesetting alternate: fbdev,nv,vesa
display ID: 0 resolution: <missing: xdpyinfo>
OpenGL: renderer: NVE6 v: 4.3 Mesa 20.3.1 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: ASUSTeK P8Z77-V LX driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:1e20
Device-2: NVIDIA GK106 HDMI Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 01:00.1 chip ID: 10de:0e0b
Device-3: Microdia Webcam Vitade AF type: USB driver: snd-usb-audio,uvcvideo
bus ID: 1-4:2 chip ID: 0c45:6366 serial: <filter>
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Realtek RTL8192CE PCIe Wireless Network Adapter vendor: ASUSTeK
driver: rtl8192ce v: kernel port: d000 bus ID: 03:00.0 chip ID: 10ec:8178
vendor: ASUSTeK P8 series driver: r8169 v: kernel port: c000 bus ID: 04:00.0
chip ID: 10ec:8168
IF: enp4s0 state: down mac: <filter>
Local Storage: total: 931.51 GiB used: 47.01 GiB (5.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HDS721010DLE630
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: A650
ID-1: / raw size: 48.83 GiB size: 47.81 GiB (97.92%) used: 16.41 GiB (34.3%)
fs: ext4 dev: /dev/sda9 maj-min: 8:9
ID-2: /boot/efi raw size: 512 MiB size: 511 MiB (99.80%)
used: 324 KiB (0.1%) fs: vfat dev: /dev/sda7 maj-min: 8:7
ID-3: /home raw size: 50.63 GiB size: 49.59 GiB (97.94%)
used: 30.61 GiB (61.7%) fs: ext4 dev: /dev/sda10 maj-min: 8:10
ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda8 maj-min: 8:8
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 28.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 1260
Processes: 218 Uptime: 16m wakeups: 0 Memory: 7.64 GiB
used: 2.11 GiB (27.5%) Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages:
pacman: 1376 lib: 382 flatpak: 0 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.2.01
