Of the cursor themes listed in Settings > Mouse and Touchpad > Theme (hereinafter the “GUI setting”), as shown–
–only Adwaita, Breeze, and Breeze Light, when selected, go into effect (i.e. I get to see the icons as from Preview).
Choosing one of the other themes, e.g. Elementary, will just give me Breeze, which I believe is my default from seeing
- /usr/share/icons/default/index.theme has
Inherits=xcursor-breeze - /etc/lightdm/lightdm-gtk-greeter.conf has
cursor-theme-name = xcursor-breeze
Questions
- When I choose a theme in the GUI setting, which configuration file am I editing?
- How could I fix the issue? I see this could take one of two forms: (a) Get the GUI setting to work or (b) bypass the GUI and edit some config file. Either way the desired result would be that I could use a cursor theme other than Adwaita, Breeze, and Breeze Light.
Things I’ve noticed or tried:
In several posts where the problem was a theme’s partial effectiveness (i.e. you sometimes see icons from a theme you did not choose), the fix involved the editing of /usr/share/icons/default/index.theme and /etc/lightdm/lightdm-gtk-greeter.conf:
- System-wide application of specific cursor theme (Simple-and-Soft) - #5 by Rana
- How to do change cursor theme from Breeze to Adwaita on Manjaro Xfce?
But my problem is different. Certain themes are completely ineffective.
I tried creating a ~/.Xresources and entering:
Xcursor.size: 48
Xcursor.theme: Elementary
On reboot, I saw that the new size went into effect, but not Elementary.
Many of the ideas and links come from this earlier post: Incorrect cursor displayed in text editors
ADDED LATER
For anybody else similarly situated, here are the cursor themes involving neither problem (neither this post nor the other post’s) I’ve found:
- Adwaita (which came with the OS install)
- MOYASH-Pixel-White-vr7-Linux.zip from MOYASH Pixel Cursor - Eyecandy for your XFCE-Desktop - xfce-look.org
- Simp1e-Adw.tar.xz and Simp1e-Adw-Dark.tar.xz from Simp1e Cursors - Eyecandy for your XFCE-Desktop - xfce-look.org
