After the latest Manjaro update with Plasma 6, I did a fresh installation.
My printer Brother HL-L8360CDW model is not listed in CUPS. No driver available through CUPS.
This printer works fine on my original Manjaro installation. Also this printer works fine on a Manjaro lap top that is not updated yet.
The way that I installed this printer and got it working without the driver being listed in CUPS - was to install two files specific to my printer - from the AUR.
Installing brother-hll8360cdw-cups-bin and brother-hll8360cdw-lpr-bin from the AUR previously enabled CUPS to install my printer and driver. With this new fresh Manjaro installation, I also installed these two files from the AUR. However since the most recent Manjaro update, CUPS is not seeing or able to use these two installed files.
Searching for help - I came across an article for packaging Brother Printer Drivers - but that help said to start off with those two exact same files for my specific printer - as a template, and then modify them for other brother printers.
In very basic instructions, can anyone help with getting CUPS able to use those two files so I can install my printer on this fresh installation? Thank you.
Thanks for your reply. Unfortunately that is not the solution. Both manjaro-printer and print-manager are installed on this fresh install.
I should add to my original post - that CUPS can see the wireless printer - Brother HL-L8260CDW. But that particular model is not selectable from the make/model drop down list. CUPS has no compatible driver for it.
Before the latest Manjaro big update - Installing brother-hll8360cdw-cups-bin and brother-hll8360cdw-lpr-bin from the AUR previously enabled CUPS to install printer and driver. I just found this comment on the ARCH user repository. Latest comment from package creator dated 18th May 2024
I also had problems getting the Brother HL-L8360CDW to run completely for a long time. Now I have managed it relatively easily by selecting the driver for the Brother HL-4070CDW from the list - and it just works.
