Hi
I have installed Manjaro XFCE on a new computer and when I try to configure my printer via CUPS, it wont accept my password.
I have tried both my regular user name and “root”.
here is a inxi info dump.
[eric@zb1 ~]$ inxi -Fzxi
System: Kernel: 5.7.14-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0 Desktop: Xfce 4.14.2
Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ZOTAC model: ZBOX-CI341 serial: <filter>
UEFI: American Megatrends v: 5.13 date: 04/28/2020
CPU: Topology: Quad Core model: Intel Celeron N4100 bits: 64 type: MCP arch: Goldmont Plus
rev: 1 L2 cache: 4096 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 8756
Speed: 1816 MHz min/max: 800/2400 MHz Core speeds (MHz): 1: 1816 2: 2016 3: 2061
4: 2091
Graphics: Device-1: Intel UHD Graphics 605 driver: i915 v: kernel bus ID: 00:02.0
Display: x11 server: X.Org 1.20.8 driver: intel unloaded: modesetting
resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 600 (GLK 2) v: 4.6 Mesa 20.1.5
direct render: Yes
Audio: Device-1: Intel vendor: ZOTAC driver: snd_hda_intel v: kernel bus ID: 00:0e.0
Sound Server: ALSA v: k5.7.14-1-MANJARO
Network: Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel port: f040 bus ID: 01:00.0
IF: wlp1s0 state: down mac: <filter>
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: LG
driver: r8169 v: kernel port: e000 bus ID: 02:00.0
Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: LG
driver: r8169 v: kernel port: d000 bus ID: 03:00.0
IF-ID-1: eno1 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 2.05 TiB used: 194.74 GiB (9.3%)
ID-1: /dev/sda vendor: Western Digital model: WDS250G2B0B size: 232.89 GiB
ID-2: /dev/sdc type: USB vendor: Western Digital model: WD20SMZM-59H3FS1
Partition: ID-1: / size: 227.94 GiB used: 11.79 GiB (5.2%) fs: ext4 dev: /dev/sda2
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 51.0 C mobo: N/A
Info: Processes: 199 Uptime: 23h 33m Memory: 7.37 GiB used: 3.31 GiB (44.8%) Init: systemd
Compilers: gcc: 10.1.0 Packages: 1158 Shell: Bash v: 5.0.18 inxi: 3.1.05
[eric@zb1 ~]$
