This indicates that the provided PTX was compiled with an unsupported toolchain. The most common reason for this, is the PTX was generated by a compiler newer than what is supported by the CUDA driver and PTX JIT compiler.
Did some CUDA update break my installation? What could I do to fix this?
Yes, CUDA and its dependencies are all from repo and I have the latest CUDA version. (Looks like it was last updated on 6th November - I havn’t used nvcc since then)
[reik@reik-msi ~]$ pacman -Qi cuda
Version : 11.1.0-2
Description : NVIDIA's GPU programming toolkit
Architecture : x86_64
URL : https://developer.nvidia.com/cuda-zone
Licenses : custom:NVIDIA
Groups : None
Provides : cuda-toolkit cuda-sdk
Depends On : gcc-libs gcc opencl-nvidia nvidia-utils
Optional Deps : gdb: for cuda-gdb [installed]
java-runtime=8: for nsight and nvvp [installed]
Required By : cudnn opencv-cuda
Optional For : None
Conflicts With : None
Replaces : cuda-toolkit cuda-sdk
Installed Size : 5.50 GiB
Packager : Konstantin Gizdov <arch@kge.pw>
Build Date : Tuesday 29 September 2020 02:55:58 PM
Install Date : Friday 06 November 2020 10:28:34 AM
Install Reason : Explicitly installed
Install Script : Yes
Validated By : Signature
