I was editing a file in console, i tried to save it using ctrl + o but i just did a upper case O , Im Using Linux Manjaro the latest version of the system and the version 5.9.11-3 core*. i tried searching help online but it seems no one had this problem.
Editing with what? My guess is Nano since Ctrl + O is the shortcut for saving a file (Write Out).
What happens if you use Ctrl + X (Exit)? It will prompt to save before exiting.
Nothing. alt , ctrl , fn work like shift, even in minecraft
ps. this is my alt that i created today i forgot my password to my main and password reset doesn’t work idk why
