I’d like to modify the behavior of the CTRL and ALT modifiers on the terminal keyboard so that it behaves like the SHIFT key (off, on until nonmodifier is pressed, locked on). The current behavior is to toggle between OFF and LOCK, which is not ideal for emacs usage.
The build I’m using is Manjaro-ARM-phosh-pinephone-beta12.img.
If someone can point me to where the dev on this happens, I’d be happy to put some time in.
