Greetings All,
I recently fired up CSGO and noticed that it freezes everytime on both the dashboard screen and in game. I can only get in game if I quickly select everything and start a match.
I can’t force quit or shutdown properly. I have to hard restart with the power button.
My workaround for the time being is to use the Intel video driver (removing prime-run from the game properties).
Any help on this would be appreciated.
Cheers,
AT
Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Notebook product: P95_96_97Ex,Rx v: N/A
Mobo: Notebook model: P95_96_97Ex,Rx serial: <superuser required>
UEFI: INSYDE v: 1.07.09LS1 date: 06/13/2019
ID-1: BAT0 charge: 57.3 Wh (100.0%) condition: 57.3/56.2 Wh (101.9%)
volts: 16.8 min: 15.2 model: Notebook BAT type: Li-ion serial: <filter>
status: full
Info: 6-core model: Intel Core i7-9750H bits: 64 type: MT MCP smt: enabled
arch: Coffee Lake level: v3 rev: A cache: L1: 384 KiB L2: 1.5 MiB
L3: 12 MiB
Speed (MHz): avg: 894 high: 900 min/max: 800/4500 cores: 1: 900 2: 900
3: 900 4: 900 5: 899 6: 855 7: 900 8: 900 9: 880 10: 900 11: 900 12: 900
bogomips: 62431
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: CLEVO/KAPOK
driver: i915 v: kernel arch: Gen-9.5 ports: active: eDP-1 empty: none
bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: CLEVO/KAPOK
driver: nvidia v: 515.65.01 arch: Turing pcie: speed: 2.5 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1f11 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x07b6 res: 1920x1080 hz: 144
dpi: 128 size: 382x215mm (15.04x8.46") diag: 438mm (17.3") modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa
22.1.6 direct render: Yes
