Hello! So i wanna try csgo on notebook, because half life 2 ep:2 work fine without problem w and w/o proton But i only got trailer video of operation Even logo (Valve) did’t appear
System specifications:
Kernel: 5.15.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=9771d547-db18-4863-b04c-f93464b4c88e rw quiet
resume=UUID=cfd3f574-a521-45cd-956b-8ae7115695aa udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: HP product: OMEN by HP Laptop v: N/A
Mobo: HP model: 8469 v: 68.21 serial: <superuser required> UEFI: AMI
v: F.09 date: 04/24/2019
ID-1: BAT0 charge: 7.0 Wh (71.4%) condition: 9.8/9.8 Wh (100.0%) volts: 15.5
min: 14.6 model: HP Primary type: Li-ion serial: N/A status: N/A
RAM: total: 7.58 GiB used: 1.1 GiB (14.6%)
RAM Report:
Info: model: Intel Core i5-8300H bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 800/4000 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 36812
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb erms est f16c
flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify
ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear
mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer vme x2apic
Type: itlb_multihit status: KVM: VMX unsupported
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1c8d class-ID: 0300
Device-3: Realtek HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-6:2 chip-ID: 0bda:58eb class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.2 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting display-ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 128
size: 381x214mm (15.0x8.4") diag: 437mm (17.2")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.2.5
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 02:00.0
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:3 chip-ID: 8087:0aaa class-ID: e001
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 931.51 GiB used: 68.17 GiB (7.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM049-2GH172
type: HDD rpm: 7200 serial: <filter> rev: RXM3 scheme: GPT
ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%)
used: 68.13 GiB (7.5%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 9771d547-db18-4863-b04c-f93464b4c88e
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 3031-73DD
ID-1: swap-1 type: partition size: 8.8 GiB used: 45.5 MiB (0.5%)
priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: cfd3f574-a521-45cd-956b-8ae7115695aa
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-6:2 info: Realtek HP Wide Vision HD Camera type: Video
Device-2: 1-14:3 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 37.0 C pch: 43.0 C mobo: N/A
Processes: 227 Uptime: 11h 22m wakeups: 2 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1012 lib: 295
Shell: Bash v: 5.1.12 running-in: xfce4-terminal inxi: 3.3.11
