Crypttab - wait for encrypted volume before mounting VeraCrypt container
Dear community,
I’m using Manjaro KDE with an encrypted /home drive (unlocked by password). Additionally to that I’ve got an encrypted VeraCrypt partition for shared use with my Windows 11 installation. The VeraCrypt drive is getting unlocked with a key file that’s located on my /home drive.
To unlock the VeraCrypt partition at boot, I’ve configured the /etc/crypttab:
veracrypt-data /dev/nvme0n1p8 /dev/null tcrypt-veracrypt,tcrypt-keyfile=/home/user/veracrypt-keyfile
And in the /etc/fstab:
/dev/mapper/veracrypt-data /home/user/veracrypt_data auto uid=1000,gid=1000,nodev,nofail 0 0
The problem that I now have is that the crypttab is executed at boot before my /home drive is mounted via password. I get this while the boot process:
[FAILED] Failed to start Cryptography Setup for veracrypt-data
[DEPEND] Dependency failed for Lucal Encrypted Volumes.
[DEPEND] Dependency failed for /dev/mapper/veracrypt-data
Is there a way to let crypttab wait until the encrypted /home is mounted?
Kind regards
Tobias
I guess you should not even put it in crypttab, then
because it can’t be accessed until the filesystem containing it is mounted
perhaps have your $HOME mounted via crypttab instead - or use systemd-mount unit to have it wait for $HOME to be mounted
these where just some thoughts, nothin concrete
others have more insight and experience than I have
:point_up:
The perhaps most obvious thing to do just would not occur to me (and to you) the first time around :man_facepalming:
Why not just move the key file to somewhere else - where it can be accessed?
… work smarter, not harder :grin:
You might as well have said: “Why not just remove the encryption?”
(The OP obviously has a desire to protect that key also :wink:)
true
It seems I can’t think straight anymore - not today at least.
