hi i wanted to run make
on the 6.5rc kernel’s build directory but i get the error
if i run older kernels i get the same error
i want to do this because need to compile a module for
https://github.com/jonjonarnearne/smi2021
and if i dont i and run the make commands for the module somehow saa7115
will not be found
No need to manually build the kernel. Try somagic-easycap-smi2021-git
in the AUR (Arch User Repository) which uses a fork with newer commits.
tried it but the same errors still there
but this time it says <generated/autoconf.h>
missing since i ran make on the kernel directory
