Hi,
Issue with crowdsec after this up date.
Issue with libraries: libabsl_flags.so.2301.0.0
find below more details :
[nls@h3 ~]$ sudo systemctl status crowdsec
[sudo] password for nls:
● crowdsec.service - Crowdsec agent
Loaded: loaded (/etc/systemd/system/crowdsec.service; enabled; preset: disabled)
Active: activating (auto-restart) (Result: exit-code) since Thu 2023-10-05 17:14:23 CEST; 53s ago
Process: 196441 ExecStartPre=/usr/local/bin/crowdsec -c /etc/crowdsec/config.yaml -t (code=exited, status=127)
CPU: 1ms
[nls@h3 ~]$ sudo systemctl start crowdsec
Job for crowdsec.service failed because the control process exited with error code.
See "systemctl status crowdsec.service" and "journalctl -xeu crowdsec.service" for details.
CPU: 1ms
[nls@h3 ~]$ crowdsec --version
crowdsec: error while loading shared libraries: libabsl_flags.so.2301.0.0: cannot open shared object file: No such file or directory
crowdsec version 1.5.4-1
https://archlinux.pkgs.org/rolling/chaotic-aur-x86_64/crowdsec-1.5.4-1-any.pkg.tar.zst.html
I found the needed file not dated with 2301 but 2308
edit: I reported the issue to the crowdsec support team, thanks to the manjaro dev and users for your help, suggestions to solve this issue.
