Crowdsec 1.8.2 and using override.conf
Using crowdsec 1.8.2-1 and cs-firewall-bouncer 0.0.36-1
Cosmetic problems solved by using overrides:
At (only the) first start (and then daily) there is an error in journalctl:
Failed to start Crowdsec agent.
The crowdsec.service starts successful after automatic retrie(s)
as the crowdse-firewall-bouncer.service does.
I made two overrides to avoid the message(s):
1.
sudo mkdir /etc/systemd/system/crowdsec.service.
sudo mkdir /etc/systemd/system/crowdsec-firewall-bouncer.service.d
  1. sudo systemctl edit crowdsec
    My override.conf contains:
    [Unit]
    After=gdm.service systemd-journald.service network.target remote-fs.target nss-lookup.target
    [Service]
    Type=notify
    Environment=LC_ALL=C LANG=C
    ExecStartPre=
    ExecStartPre=/usr/bin/sleep 11s
    ExecStartPre=/usr/bin/crowdsec -c /etc/crowdsec/config.yaml -t -error
    RestartSec=10
  2. sudo systemctl edit crowdsec-firewall-bouncer
    [Service]
    RestartSec=20
  3. systemctl daemon-reload
  4. sudo systemd-analyze verify crowdsec.service
  5. sudo systemd-analyze verify crowdsec-firewall.bouncer.service
(success: when no reply)
Mod edit: tidied up a bit. :ok_hand:
