I’m trying to Install MS Office 2016 for MS access install on Crossover 22
Now I’m stuck at installation with error :
Fehlende 32-bit libsane.so.1 Bibliothek: The SANE library allows Windows applications to access document scanners.
Is there any solution for it?
Also, why is there Crossover 21 and 22
my pacman.conf is set with:
[multilib]
# SigLevel = PackageRequired
Include = /etc/pacman.d/mirrorlist
Try installing lib32-sane
from the AUR (Arch User Repository). Thing is, nothing else requires it and the package may be deleted soon.
Each major version has it’s own license. Which version are you using?
Yeah, thanks It could not satisfy the build dependency
lib32-rav1e-0.6.6-1 lib32-libheif-1.16.2-1 lib32-gd-2.3.3-2 lib32-libgphoto2-2.5.30-1 lib32-sane-1.2.1-2
I try all 3 version 21,22 and AUR 23.
For now, I use MS access in the VM on W10
