I created an rsync-script, which is frequently running for backing up files and basically everything is fine.
The problem is, that there are some files, which can’t be copied/configured without root permissions.
At the moment my scripts runs as result of a command in crontab -e
What i now wanted to do is to shift this command to the sudo crontab -e
or crontab -e -u root
The problem is, that when i enter crontab as sudo, i dont get to edit the crontab.
I end up with this weird window, where i can’t even find a shortcut to exit again → I have to kill the whole terminal window
Does anyone know what im doing wrong or whats missing?
Ive already been searching for a solution but did not find anyone with exactly the same issue …
Why make it hard on yourself? timeshift can do all of that too.
You won’t have write access with that. That command is to be used by the root user only.
That weird window is the vi or vim editor, which is the default editor for crontabs if no other editor has been specified for that user account by way of the $EDITOR variable.
One exits vi by pressing Esc, followed by typing the following (if one does not want to save the file)…
:q!
… followed by pressing Return/Enter
What you could try is the following…
1. Create a systemd timer instead of a crontab; or
Im already using timeshift, and want do “double-backup” these files
→ Im pretty sure, that there is a better way to implement this but i dont have a RAID-Nas or something like this and wanted to keep it simple → Create a redundant version of my timeshift-backups
vi or vim → Yes and already worked fine for crontab without root
$EDITOR-variable → Nice this did the trick
:q!
OK weird but thanks
Use su instead of sudo.
sudo su -
EDITOR=nano crontab -e
This was my prefered way to do it, due to the fact, that everything was already running (without root-permissions)
But sadly it seems that i get some errors in journalctl
regarding crond[725]: (root) CAN'T OPEN (/etc/crontab): Datei oder Verzeichnis nicht gefunden
So maybe i hopefully will find some time to check out your other solution “systemd timer” to get this working
Anyway thanks a lot for your very useful help!
I will give feedback (but i am very busy at the moment)
