Creative Sound Blaster AE-7/AE-9 errors while booting and not recognised
I just bought a brand new Creative SB AE-7 and while it took me maybe 5min to boot into Manjaro.
Now after i finally at the Desktop, i sadly see there is no sound card detected from Pavucontrol and the same can be said around Alsamixer :frowning:
I heared some bad stuff around the AE-7 that newer revisions/models (i guess i probably got a newer revision :grimacing: ) leading to system freezes while booting and people stuck there. But i read also that it should be related to boot from NVMe’s, while i thought i maybe fine with my USB SSD Bootdrive which was also leading to many system repair checks while the system was loading into Manjaro.
$ inxi -zv8
  Kernel: 7.2.3-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-7.2-x86_64
    root=UUID=7d0165de-089c-45ee-adb3-9a8ca8d12132 rw amd_pstate=passive
    amdgpu.ppfeaturemask=0xffffffff sysrq_always_enabled=1
    resume=UUID=342d34b4-152b-4a04-9479-c0b3cbc6c96f udev.log_priority=3
  Desktop: KDE Plasma v: 6.7.4 tk: Qt v: N/A info: frameworks v: 6.29.0
  Type: Desktop Mobo: Gigabyte model: X870E AORUS ELITE WIFI7 v: x.x
    serial: <superuser required> uuid: <superuser required> Firmware: UEFI
    vendor: American Megatrends LLC. v: FA7 date: 12/12/2025
  System RAM: total: 32 GiB available: 30.95 GiB used: 2.24 GiB (7.2%)
  Device-1: Channel-A DIMM 0 type: no module installed
  Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: 6000 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: TeamGroup
    part-no: UD5-6000 serial: <filter>
  Device-3: Channel-B DIMM 0 type: no module installed
  Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 9800X3D bits: 64 type: MT MCP arch: Zen 5 gen: 5
    level: v4 note: check built: 2024+ process: TSMC n4 (4nm) family: 0x1A (26)
    model-id: 0x44 (68) stepping: 0 microcode: 0xB404035
    smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
  Speed (MHz): avg: 5272 min/max: 603/5272 boost: enabled scaling:
    driver: amd-pstate governor: performance cores: 1: 5272 2: 5272 3: 5272
    4: 5272 5: 5272 6: 5272 7: 5272 8: 5272 9: 5272 10: 5272 11: 5272 12: 5272
    13: 5272 14: 5272 15: 5272 16: 5272 bogomips: 150108
    apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl avx_vnni bmi1 bmi2 bpext
    bus_lock_detect cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov
    cmp_legacy constant_tsc cpb cppc cpuid cpuid_fault cqm cqm_llc
    cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de
    decodeassists erms extapic extd_apicid f16c flush_l1d flushbyasid fma fpu
    fsgsbase fsrm fxsr fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs
    invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
    movbe movdir64b movdiri msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx
    ospke osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
    perfctr_core perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni
    stibp succor svm svm_lock syscall tce topoext tsc tsc_adjust tsc_scale
    umip user_shstk v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme
    vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec
    xsaveerptr xsaveopt xsaves xtopology
  Type: spec_rstack_overflow mitigation: IBPB on VMEXIT only
    conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Type: vmscape mitigation: IBPB on VMEXIT
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 [Radeon RX 9070/9070
    XT/9070 GRE] vendor: Tul / PowerColor driver: amdgpu v: kernel
    arch: RDNA-4 code: Navi-4x process: TSMC n4 (4nm) built: 2025+ pcie:
    gen: 5 speed: 32 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1,
    DP-2, DP-3, Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:7550 class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: 0
  Monitor-1: HDMI-A-1 model: HannSpree/HannStar HS233 serial: <filter>
    built: 2010 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 96 gamma: 1.2
    chroma: red: x: 0.647 y: 0.333 green: x: 0.302 y: 0.600 blue: x: 0.149
    y: 0.055 white: x: 0.314 y: 0.329 size: 510x287mm (20.08x11.3")
    diag: 585mm (23") ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024,
    1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 832x624, 800x600,
    720x576, 720x480, 640x480, 720x400
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi wayland:
    drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 vendor: amd mesa v: 26.2.2-arch1.1 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon RX 9070 (radeonsi gfx1201 ACO DRM
    3.64 7.2.3-2-MANJARO) device-ID: 1002:7550 memory: 15.62 GiB unified: no
    display-ID: :1.0
  API: Vulkan v: 1.4.357 layers: 6 device: 0 type: discrete-gpu name: AMD
    Radeon RX 9070 (RADV GFX1201) driver: mesa radv v: 26.2.2-arch1.1
    device-ID: 1002:7550 surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: corectrl wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 HDMI/DP Audio
    driver: snd_hda_intel v: kernel pcie: gen: 5 speed: 32 GT/s lanes: 16
    bus-ID: 03:00.1 chip-ID: 1002:ab40 class-ID: 0403
  Device-2: Creative Labs CA0132 Sound Core3D [Sound Blaster AE-7/AE-9]
    driver: snd_hda_intel v: kernel bus-ID: 12:00.0 chip-ID: 1102:0010
    class-ID: 0403
  Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: Gigabyte
    bus-ID: 1e:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k7.2.3-2-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.8 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8922AE 802.11be PCIe Wireless Network Adapter
    driver: N/A modules: rtw89_8922ae pcie: gen: 2 speed: 5 GT/s lanes: 1
    port: e000 bus-ID: 0f:00.0 chip-ID: 10ec:8922 class-ID: 0280
  Device-2: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 10:00.0
  IF: enp16s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:2 chip-ID: 0bda:8922
  Local Storage: total: 3.18 TiB used: 502.22 GiB (15.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SFYRDY2000G
    lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK51.2 temp: 39.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung model: SSD 960 EVO 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 2B7QCXE7 temp: 20.9 C
    scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: PSSD T7
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.2 spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1 tech: SSD
    serial: <filter> scheme: GPT
  ID-1: / raw-size: 390.62 GiB size: 383.43 GiB (98.16%)
    used: 14.26 GiB (3.7%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: root
    uuid: 7d0165de-089c-45ee-adb3-9a8ca8d12132
    used: 328 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: efi
    uuid: 3BE0-5B02
  ID-3: /home raw-size: 503.28 GiB size: 494.31 GiB (98.22%)
    used: 14.19 GiB (2.9%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: home
    uuid: 938cd14e-1366-4038-9b43-1348b0e4aae4
  ID-4: /media/nvme-games raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
    used: 473.76 GiB (25.9%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
    label: nvme-games uuid: ef738838-b40e-4cbe-a55d-a3f8bcfdb11a
  ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%)
    priority: -1 dev: /dev/sda2 maj-min: 8:2 label: swap
    uuid: 342d34b4-152b-4a04-9479-c0b3cbc6c96f
  ID-1: /dev/nvme1n1p1 maj-min: 259:3 size: 100 MiB fs: vfat label: N/A
    uuid: 9095-62C6
  ID-2: /dev/nvme1n1p2 maj-min: 259:4 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme1n1p3 maj-min: 259:5 size: 396.75 GiB fs: ntfs label: N/A
    uuid: 388AB2318AB1EB8E
  ID-4: /dev/nvme1n1p4 maj-min: 259:6 size: 546 MiB fs: ntfs label: N/A
    uuid: 800CA58D0CA57EB2
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-6:2 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:8922 class-ID: e001 serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-7:2 info: Integrated Express GIGABYTE Device type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5711 class-ID: 0300
  Device-2: 3-9:3 info: CHERRY G83 (RS 6000) Keyboard type: keyboard
    chip-ID: 046a:0011 class-ID: 0301
  Device-3: 3-10:4 info: A4Tech XL-730K / XL-747H XL-750BK XL-755BK Mice
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    chip-ID: 09da:9090 class-ID: 0301
  Hub-4: 4-0:1 info: super-speed hub ports: 6 rev: 3.1
  Device-1: 4-1:2 info: Samsung PSSD T7 type: mass storage driver: uas
    interfaces: 1 rev: 3.2 speed: 10 Gb/s (1.16 GiB/s) lanes: 1
    mode: 3.2 gen-2x1 power: 896mA chip-ID: 04e8:4001 class-ID: 0806
    serial: <filter>
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-8: 8-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-9: 9-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-10: 10-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-11: 11-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  System Temperatures: cpu: 42.1 C mobo: 42.5 C gpu: amdgpu temp: 27.0 C
    mem: 25.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 674
  Packages: pm: pacman pkgs: 1373 libs: 377 tools: pamac pm: flatpak pkgs: 0
    1: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    2: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    3: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 349
  1: cpu: 37.7% command: [kworker/8:1-cgroup_release] pid: 130
    mem: 0.00 MiB (0.0%)
  2: cpu: 5.7% command: firefox pid: 2117 mem: 365.1 MiB (1.1%)
  3: cpu: 3.8% command: firefox pid: 1881 mem: 620.8 MiB (1.9%)
  4: cpu: 1.8% command: firefox pid: 2032 mem: 263.7 MiB (0.8%)
  5: cpu: 1.5% command: kwin_wayland pid: 1135 mem: 242.8 MiB (0.7%)
  Memory top: 5 of 349
  1: mem: 620.8 MiB (1.9%) command: firefox pid: 1881 cpu: 3.8%
  2: mem: 365.1 MiB (1.1%) command: firefox pid: 2117 cpu: 5.7%
  3: mem: 353.3 MiB (1.1%) command: plasmashell pid: 1260 cpu: 0.7%
  4: mem: 263.7 MiB (0.8%) command: firefox pid: 2032 cpu: 1.8%
  5: mem: 242.8 MiB (0.7%) command: kwin_wayland pid: 1135 cpu: 1.5%
  Processes: 349 Power: uptime: 10m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.31 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 261 default: graphical
    tool: systemctl
  Compilers: gcc: 16.2.1 Shell: Bash v: 5.3.15 running-in: konsole
    inxi: 3.3.41
Boot errors after a Reboot:
Okt 12 20:29:02 koboldx-x870e kernel: virt/tdx: TDX not supported by the host platform
Okt 12 20:29:02 koboldx-x870e kernel: integrity: Problem loading X.509 certificate -22
Okt 12 20:29:02 koboldx-x870e kernel: amdgpu: Overdrive is enabled, please disable it before reporting any bugs unrelated to overdrive.
Okt 12 20:29:03 koboldx-x870e kernel: thunderbolt 0000:1d:00.0: error -ETIMEDOUT: failed to allocate host router
Okt 12 20:29:03 koboldx-x870e kernel: thunderbolt 0000:1d:00.0: error -ETIMEDOUT: failed to add domain
Okt 12 20:29:03 koboldx-x870e kernel: thunderbolt 0000:1d:00.0: probe with driver thunderbolt failed with error -110
Okt 12 20:29:29 koboldx-x870e kernel: watchdog: CPU9: Watchdog detected hard LOCKUP on cpu 9
Okt 12 20:29:29 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#11 stuck for 26s! [(udev-worker):620]
Okt 12 20:29:29 koboldx-x870e kernel: CPU#11 Utilization every 4000ms during lockup:
Okt 12 20:29:29 koboldx-x870e kernel:         #1: 100% system,          0% softirq,          1% hardirq,          0% idle
Okt 12 20:29:29 koboldx-x870e kernel:         #2: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:29:29 koboldx-x870e kernel:         #3: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:29:29 koboldx-x870e kernel:         #4: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:29:29 koboldx-x870e kernel:         #5: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:29:29 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#8 stuck for 26s! [rcu_exp_gp_kthr:19]
Okt 12 20:29:29 koboldx-x870e kernel: CPU#8 Utilization every 4000ms during lockup:
Okt 12 20:29:29 koboldx-x870e kernel:         #1: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:29:57 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#11 stuck for 52s! [(udev-worker):620]
Okt 12 20:29:57 koboldx-x870e kernel: CPU#11 Utilization every 4000ms during lockup:
Okt 12 20:29:57 koboldx-x870e kernel:         #1: 100% system,          0% softirq,          1% hardirq,          0% idle
Okt 12 20:29:57 koboldx-x870e kernel:         #2: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:29:57 koboldx-x870e kernel:         #3: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:29:57 koboldx-x870e kernel:         #4: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:29:57 koboldx-x870e kernel:         #5: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:29:57 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#8 stuck for 52s! [rcu_exp_gp_kthr:19]
Okt 12 20:29:57 koboldx-x870e kernel: CPU#8 Utilization every 4000ms during lockup:
Okt 12 20:29:57 koboldx-x870e kernel:         #1: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:30:03 koboldx-x870e kernel: rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
Okt 12 20:30:03 koboldx-x870e kernel: rcu:         9-...!: (0 ticks this GP) idle=6834/1/0x4000000000000000 softirq=425/425 fqs=104
Okt 12 20:30:03 koboldx-x870e kernel: rcu:         (detected by 11, t=60002 jiffies, g=21, q=1485 ncpus=16)
Okt 12 20:30:03 koboldx-x870e kernel: rcu: rcu_preempt kthread starved for 59569 jiffies! g21 f0x0 RCU_GP_WAIT_FQS(5) ->state=0x0 ->cpu=8
Okt 12 20:30:03 koboldx-x870e kernel: rcu:         Unless rcu_preempt kthread gets sufficient CPU time, OOM is now expected behavior.
Okt 12 20:30:03 koboldx-x870e kernel: rcu: RCU grace-period kthread stack dump:
Okt 12 20:30:03 koboldx-x870e kernel: rcu: Stack dump where RCU GP kthread last ran:
Okt 12 20:30:29 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#11 stuck for 82s! [(udev-worker):620]
Okt 12 20:30:29 koboldx-x870e kernel: CPU#11 Utilization every 4000ms during lockup:
Okt 12 20:30:29 koboldx-x870e kernel:         #1: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:30:29 koboldx-x870e kernel:         #2: 100% system,          0% softirq,          1% hardirq,          0% idle
Okt 12 20:30:29 koboldx-x870e kernel:         #3: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:30:29 koboldx-x870e kernel:         #4: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:30:29 koboldx-x870e kernel:         #5: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:30:29 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#8 stuck for 82s! [rcu_exp_gp_kthr:19]
Okt 12 20:30:29 koboldx-x870e kernel: CPU#8 Utilization every 4000ms during lockup:
Okt 12 20:30:29 koboldx-x870e kernel:         #2: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:30:57 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#8 stuck for 108s! [rcu_exp_gp_kthr:19]
Okt 12 20:30:57 koboldx-x870e kernel: CPU#8 Utilization every 4000ms during lockup:
Okt 12 20:30:57 koboldx-x870e kernel:         #1: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:30:57 koboldx-x870e kernel:         #2: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:30:57 koboldx-x870e kernel:         #3: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:30:57 koboldx-x870e kernel:         #4: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:30:57 koboldx-x870e kernel:         #5: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:30:57 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#11 stuck for 108s! [(udev-worker):620]
Okt 12 20:30:57 koboldx-x870e kernel: CPU#11 Utilization every 4000ms during lockup:
Okt 12 20:30:57 koboldx-x870e kernel:         #1: 100% system,          0% softirq,          1% hardirq,          0% idle
Okt 12 20:31:25 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#11 stuck for 134s! [(udev-worker):620]
Okt 12 20:31:25 koboldx-x870e kernel: CPU#11 Utilization every 4000ms during lockup:
Okt 12 20:31:25 koboldx-x870e kernel:         #1: 100% system,          0% softirq,          1% hardirq,          0% idle
Okt 12 20:31:25 koboldx-x870e kernel:         #2: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:31:25 koboldx-x870e kernel:         #3: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:31:25 koboldx-x870e kernel:         #4: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:31:25 koboldx-x870e kernel:         #5: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:31:25 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#8 stuck for 134s! [rcu_exp_gp_kthr:19]
Okt 12 20:31:25 koboldx-x870e kernel: CPU#8 Utilization every 4000ms during lockup:
Okt 12 20:31:25 koboldx-x870e kernel:         #1: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:31:53 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#11 stuck for 160s! [(udev-worker):620]
Okt 12 20:31:53 koboldx-x870e kernel: CPU#11 Utilization every 4000ms during lockup:
Okt 12 20:31:53 koboldx-x870e kernel:         #1: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:31:53 koboldx-x870e kernel:         #2: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:31:53 koboldx-x870e kernel:         #3: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:31:53 koboldx-x870e kernel:         #4: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:31:53 koboldx-x870e kernel:         #5: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:31:53 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#8 stuck for 160s! [rcu_exp_gp_kthr:19]
Okt 12 20:31:53 koboldx-x870e kernel: CPU#8 Utilization every 4000ms during lockup:
Okt 12 20:32:13 koboldx-x870e systemd-udevd[578]: ITE8800:00: Worker [626] processing SEQNUM=4423 killed.
Okt 12 20:32:13 koboldx-x870e systemd-udevd[578]: hdaudioC0D0: Worker [629] processing SEQNUM=5669 killed.
Okt 12 20:32:13 koboldx-x870e systemd-udevd[578]: ITE8800:01: Worker [622] processing SEQNUM=4424 killed.
Okt 12 20:32:13 koboldx-x870e systemd-udevd[578]: cpu8: Worker [599] processing SEQNUM=5136 killed.
Okt 12 20:32:13 koboldx-x870e systemd-udevd[578]: cpu7: Worker [606] processing SEQNUM=5135 killed.
Okt 12 20:32:13 koboldx-x870e systemd-udevd[578]: cpu6: Worker [625] processing SEQNUM=5134 killed.
Okt 12 20:32:13 koboldx-x870e systemd-udevd[578]: cpu5: Worker [601] processing SEQNUM=5133 killed.
Okt 12 20:32:13 koboldx-x870e systemd-udevd[578]: cpu9: Worker [619] processing SEQNUM=5137 killed.
Okt 12 20:32:13 koboldx-x870e systemd-udevd[578]: cpu4: Worker [597] processing SEQNUM=5132 killed.
Okt 12 20:32:13 koboldx-x870e systemd-udevd[578]: cpu3: Worker [608] processing SEQNUM=5131 killed.
Okt 12 20:32:13 koboldx-x870e systemd-udevd[578]: cpu2: Worker [586] processing SEQNUM=5130 killed.
Okt 12 20:32:13 koboldx-x870e systemd-udevd[578]: 0000:1d:00.0: Worker [630] processing SEQNUM=4997 killed.
Okt 12 20:32:13 koboldx-x870e systemd-udevd[578]: cpu14: Worker [587] processing SEQNUM=5128 killed.
Okt 12 20:32:13 koboldx-x870e systemd-udevd[578]: cpu12: Worker [600] processing SEQNUM=5126 killed.
Okt 12 20:32:13 koboldx-x870e systemd-udevd[578]: cpu10: Worker [598] processing SEQNUM=5124 killed.
Okt 12 20:32:13 koboldx-x870e systemd-udevd[578]: cpu11: Worker [631] processing SEQNUM=5125 killed.
Okt 12 20:32:13 koboldx-x870e systemd-udevd[578]: cpu1: Worker [596] processing SEQNUM=5123 killed.
Okt 12 20:32:13 koboldx-x870e systemd-udevd[578]: cpu13: Worker [593] processing SEQNUM=5127 killed.
Okt 12 20:32:13 koboldx-x870e systemd-udevd[578]: cpu0: Worker [623] processing SEQNUM=5122 killed.
Okt 12 20:32:13 koboldx-x870e systemd-udevd[578]: i2c-ITE8800:00: Worker [632] processing SEQNUM=5070 killed.
Okt 12 20:32:13 koboldx-x870e systemd-udevd[578]: i2c-ITE8800:01: Worker [590] processing SEQNUM=5071 killed.
Okt 12 20:32:13 koboldx-x870e systemd-udevd[578]: 1-6:1.0: Worker [607] processing SEQNUM=4851 killed.
Okt 12 20:32:13 koboldx-x870e systemd-udevd[578]: 1-6:1.1: Worker [620] processing SEQNUM=4852 killed.
Okt 12 20:32:13 koboldx-x870e systemd-udevd[578]: cpu15: Worker [628] processing SEQNUM=5129 killed.
Okt 12 20:32:13 koboldx-x870e systemd-udevd[578]: 0000:0f:00.0: Worker [591] processing SEQNUM=4820 killed.
Okt 12 20:32:44 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#8 stuck for 186s! [rcu_exp_gp_kthr:19]
Okt 12 20:32:44 koboldx-x870e kernel: CPU#8 Utilization every 4000ms during lockup:
Okt 12 20:32:44 koboldx-x870e kernel:         #1: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:32:45 koboldx-x870e kernel:         #2: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:32:45 koboldx-x870e kernel:         #3: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:32:45 koboldx-x870e kernel:         #4: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:32:45 koboldx-x870e kernel:         #5: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:32:45 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#11 stuck for 186s! [(udev-worker):620]
Okt 12 20:32:45 koboldx-x870e kernel: CPU#11 Utilization every 4000ms during lockup:
Okt 12 20:32:45 koboldx-x870e kernel:         #1: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:32:45 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#0 stuck for 22s! [(udev-worker):597]
Okt 12 20:32:45 koboldx-x870e kernel: CPU#0 Utilization every 4000ms during lockup:
Okt 12 20:32:45 koboldx-x870e kernel:         #1: 100% system,          0% softirq,          1% hardirq,          0% idle
Okt 12 20:32:45 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#1 stuck for 22s! [(udev-worker):630]
Okt 12 20:32:45 koboldx-x870e kernel: CPU#1 Utilization every 4000ms during lockup:
Okt 12 20:32:45 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#2 stuck for 22s! [(udev-worker):586]
Okt 12 20:32:45 koboldx-x870e kernel: CPU#2 Utilization every 4000ms during lockup:
Okt 12 20:32:45 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#3 stuck for 22s! [(udev-worker):598]
Okt 12 20:32:45 koboldx-x870e kernel: CPU#3 Utilization every 4000ms during lockup:
Okt 12 20:32:45 koboldx-x870e kernel:         #3: 100% system,          0% softirq,          1% hardirq,          0% idle
Okt 12 20:32:45 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#4 stuck for 22s! [(udev-worker):599]
Okt 12 20:32:45 koboldx-x870e kernel: CPU#4 Utilization every 4000ms during lockup:
Okt 12 20:32:45 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#6 stuck for 22s! [(udev-worker):600]
Okt 12 20:32:45 koboldx-x870e kernel: CPU#6 Utilization every 4000ms during lockup:
Okt 12 20:32:45 koboldx-x870e kernel:         #5: 100% system,          0% softirq,          1% hardirq,          0% idle
Okt 12 20:32:45 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#7 stuck for 22s! [(udev-worker):625]
Okt 12 20:32:45 koboldx-x870e kernel: CPU#7 Utilization every 4000ms during lockup:
Okt 12 20:32:45 koboldx-x870e kernel:         #2: 100% system,          0% softirq,          1% hardirq,          0% idle
Okt 12 20:32:45 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#5 stuck for 22s! [(udev-worker):606]
Okt 12 20:32:45 koboldx-x870e kernel: CPU#5 Utilization every 4000ms during lockup:
Okt 12 20:32:45 koboldx-x870e kernel:         #4: 100% system,          0% softirq,          1% hardirq,          0% idle
Okt 12 20:32:45 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#13 stuck for 22s! [(udev-worker):608]
Okt 12 20:32:45 koboldx-x870e kernel: CPU#13 Utilization every 4000ms during lockup:
Okt 12 20:32:45 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#14 stuck for 22s! [(udev-worker):590]
Okt 12 20:32:45 koboldx-x870e kernel: CPU#14 Utilization every 4000ms during lockup:
Okt 12 20:32:45 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#12 stuck for 22s! [(udev-worker):623]
Okt 12 20:32:45 koboldx-x870e kernel: CPU#12 Utilization every 4000ms during lockup:
Okt 12 20:32:45 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#10 stuck for 22s! [(udev-worker):619]
Okt 12 20:32:45 koboldx-x870e kernel: CPU#10 Utilization every 4000ms during lockup:
Okt 12 20:32:45 koboldx-x870e kernel: snd_hda_intel 0000:12:00.0: CORB reset timeout#2, CORBRP = 65535
Okt 12 20:32:46 koboldx-x870e kernel: hdaudio hdaudioC1D1: no AFG or MFG node found
Okt 12 20:32:46 koboldx-x870e kernel: snd_hda_intel 0000:12:00.0: no codecs initialized
Okt 12 20:32:59 koboldx-x870e org_kde_powerdevil[1184]: [  1184][  1.342061] Time since library initialized:   1.342060 seconds
Okt 12 20:32:59 koboldx-x870e org_kde_powerdevil[1184]: [  1184][  1.342066] Extra delay starting dw_start_watch_displays: 0 millisec
Error logs from the first boot:
$ journalctl -p err -b -1
Okt 12 20:05:42 koboldx-x870e kernel: virt/tdx: TDX not supported by the host platform
Okt 12 20:05:42 koboldx-x870e kernel: integrity: Problem loading X.509 certificate -22
Okt 12 20:05:42 koboldx-x870e kernel: amdgpu: Overdrive is enabled, please disable it before reporting any bugs unrelated to overdrive.
Okt 12 20:05:43 koboldx-x870e kernel: thunderbolt 0000:1d:00.0: error -ETIMEDOUT: failed to allocate host router
Okt 12 20:05:43 koboldx-x870e kernel: thunderbolt 0000:1d:00.0: error -ETIMEDOUT: failed to add domain
Okt 12 20:05:43 koboldx-x870e kernel: thunderbolt 0000:1d:00.0: probe with driver thunderbolt failed with error -110
Okt 12 20:06:09 koboldx-x870e kernel: watchdog: CPU8: Watchdog detected hard LOCKUP on cpu 8
Okt 12 20:06:09 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#3 stuck for 26s! [(udev-worker):603]
Okt 12 20:06:09 koboldx-x870e kernel: CPU#3 Utilization every 4000ms during lockup:
Okt 12 20:06:09 koboldx-x870e kernel:         #1: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:06:09 koboldx-x870e kernel:         #2: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:06:09 koboldx-x870e kernel:         #3: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:06:09 koboldx-x870e kernel:         #4: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:06:09 koboldx-x870e kernel:         #5: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:06:09 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#9 stuck for 26s! [swapon:707]
Okt 12 20:06:09 koboldx-x870e kernel: CPU#9 Utilization every 4000ms during lockup:
Okt 12 20:06:09 koboldx-x870e kernel:         #1: 100% system,          0% softirq,          1% hardirq,          0% idle
Okt 12 20:06:09 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#12 stuck for 26s! [(udev-worker):594]
Okt 12 20:06:09 koboldx-x870e kernel: CPU#12 Utilization every 4000ms during lockup:
Okt 12 20:06:37 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#3 stuck for 52s! [(udev-worker):603]
Okt 12 20:06:37 koboldx-x870e kernel: CPU#3 Utilization every 4000ms during lockup:
Okt 12 20:06:37 koboldx-x870e kernel:         #1: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:06:37 koboldx-x870e kernel:         #2: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:06:37 koboldx-x870e kernel:         #3: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:06:37 koboldx-x870e kernel:         #4: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:06:37 koboldx-x870e kernel:         #5: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:06:37 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#12 stuck for 52s! [(udev-worker):594]
Okt 12 20:06:37 koboldx-x870e kernel: CPU#12 Utilization every 4000ms during lockup:
Okt 12 20:06:37 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#9 stuck for 52s! [swapon:707]
Okt 12 20:06:37 koboldx-x870e kernel: CPU#9 Utilization every 4000ms during lockup:
Okt 12 20:06:37 koboldx-x870e kernel:         #1: 100% system,          0% softirq,          1% hardirq,          0% idle
Okt 12 20:06:43 koboldx-x870e kernel: rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
Okt 12 20:06:43 koboldx-x870e kernel: rcu:         (detected by 4, t=60002 jiffies, g=89, q=1069 ncpus=16)
Okt 12 20:06:43 koboldx-x870e kernel: rcu: All QSes seen, last rcu_preempt kthread activity 60002 (4294737738-4294677736), jiffies_till_next_fqs=3, root ->qsmask 0x0
Okt 12 20:06:43 koboldx-x870e kernel: rcu: rcu_preempt kthread starved for 60002 jiffies! g89 f0x2 RCU_GP_WAIT_FQS(5) ->state=0x0 ->cpu=8
Okt 12 20:06:43 koboldx-x870e kernel: rcu:         Unless rcu_preempt kthread gets sufficient CPU time, OOM is now expected behavior.
Okt 12 20:06:43 koboldx-x870e kernel: rcu: RCU grace-period kthread stack dump:
Okt 12 20:06:43 koboldx-x870e kernel: rcu: Stack dump where RCU GP kthread last ran:
Okt 12 20:07:05 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#3 stuck for 78s! [(udev-worker):603]
Okt 12 20:07:05 koboldx-x870e kernel: CPU#3 Utilization every 4000ms during lockup:
Okt 12 20:07:05 koboldx-x870e kernel:         #1: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:07:05 koboldx-x870e kernel:         #2: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:07:05 koboldx-x870e kernel:         #3: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:07:05 koboldx-x870e kernel:         #4: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:07:05 koboldx-x870e kernel:         #5: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:07:05 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#12 stuck for 78s! [(udev-worker):594]
Okt 12 20:07:05 koboldx-x870e kernel: CPU#12 Utilization every 4000ms during lockup:
Okt 12 20:07:05 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#9 stuck for 78s! [swapon:707]
Okt 12 20:07:05 koboldx-x870e kernel: CPU#9 Utilization every 4000ms during lockup:
Okt 12 20:07:05 koboldx-x870e kernel:         #1: 100% system,          0% softirq,          1% hardirq,          0% idle
Okt 12 20:07:33 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#3 stuck for 104s! [(udev-worker):603]
Okt 12 20:07:33 koboldx-x870e kernel: CPU#3 Utilization every 4000ms during lockup:
Okt 12 20:07:33 koboldx-x870e kernel:         #1: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:07:33 koboldx-x870e kernel:         #2: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:07:33 koboldx-x870e kernel:         #3: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:07:33 koboldx-x870e kernel:         #4: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:07:33 koboldx-x870e kernel:         #5: 100% system,          0% softirq,          1% hardirq,          0% idle
Okt 12 20:07:33 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#9 stuck for 104s! [swapon:707]
Okt 12 20:07:33 koboldx-x870e kernel: CPU#9 Utilization every 4000ms during lockup:
Okt 12 20:07:33 koboldx-x870e kernel:         #5: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:07:33 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#12 stuck for 104s! [(udev-worker):594]
Okt 12 20:07:33 koboldx-x870e kernel: CPU#12 Utilization every 4000ms during lockup:
Okt 12 20:08:01 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#3 stuck for 131s! [(udev-worker):603]
Okt 12 20:08:01 koboldx-x870e kernel: CPU#3 Utilization every 4000ms during lockup:
Okt 12 20:08:01 koboldx-x870e kernel:         #1: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:08:01 koboldx-x870e kernel:         #2: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:08:01 koboldx-x870e kernel:         #3: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:08:01 koboldx-x870e kernel:         #4: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:08:01 koboldx-x870e kernel:         #5: 100% system,          0% softirq,          1% hardirq,          0% idle
Okt 12 20:08:01 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#12 stuck for 131s! [(udev-worker):594]
Okt 12 20:08:01 koboldx-x870e kernel: CPU#12 Utilization every 4000ms during lockup:
Okt 12 20:08:01 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#9 stuck for 131s! [swapon:707]
Okt 12 20:08:01 koboldx-x870e kernel: CPU#9 Utilization every 4000ms during lockup:
Okt 12 20:08:01 koboldx-x870e kernel:         #5: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:08:29 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#3 stuck for 157s! [(udev-worker):603]
Okt 12 20:08:29 koboldx-x870e kernel: CPU#3 Utilization every 4000ms during lockup:
Okt 12 20:08:29 koboldx-x870e kernel:         #1: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:08:29 koboldx-x870e kernel:         #2: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:08:29 koboldx-x870e kernel:         #3: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:08:29 koboldx-x870e kernel:         #4: 100% system,          0% softirq,          1% hardirq,          0% idle
Okt 12 20:08:29 koboldx-x870e kernel:         #5: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:08:29 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#12 stuck for 157s! [(udev-worker):594]
Okt 12 20:08:29 koboldx-x870e kernel: CPU#12 Utilization every 4000ms during lockup:
Okt 12 20:08:29 koboldx-x870e kernel:         #4: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:08:29 koboldx-x870e kernel:         #5: 100% system,          0% softirq,          1% hardirq,          0% idle
Okt 12 20:08:29 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#9 stuck for 157s! [swapon:707]
Okt 12 20:08:29 koboldx-x870e kernel: CPU#9 Utilization every 4000ms during lockup:
Okt 12 20:08:33 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#5 stuck for 22s! [plymouthd:357]
Okt 12 20:08:33 koboldx-x870e kernel: CPU#5 Utilization every 4000ms during lockup:
Okt 12 20:08:33 koboldx-x870e kernel:         #1: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:08:33 koboldx-x870e kernel:         #2: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:08:33 koboldx-x870e kernel:         #3: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:08:33 koboldx-x870e kernel:         #4: 100% system,          0% softirq,          1% hardirq,          0% idle
Okt 12 20:08:33 koboldx-x870e kernel:         #5: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:08:53 koboldx-x870e systemd-udevd[577]: ITE8800:00: Worker [609] processing SEQNUM=4413 killed.
Okt 12 20:08:53 koboldx-x870e systemd-udevd[577]: hdaudioC0D0: Worker [632] processing SEQNUM=5680 killed.
Okt 12 20:08:53 koboldx-x870e systemd-udevd[577]: ITE8800:01: Worker [607] processing SEQNUM=4414 killed.
Okt 12 20:08:53 koboldx-x870e systemd-udevd[577]: cpu9: Worker [591] processing SEQNUM=5131 killed.
Okt 12 20:08:53 koboldx-x870e systemd-udevd[577]: cpu8: Worker [606] processing SEQNUM=5130 killed.
Okt 12 20:08:53 koboldx-x870e systemd-udevd[577]: cpu7: Worker [594] processing SEQNUM=5129 killed.
Okt 12 20:08:53 koboldx-x870e systemd-udevd[577]: cpu6: Worker [621] processing SEQNUM=5128 killed.
Okt 12 20:08:53 koboldx-x870e systemd-udevd[577]: cpu5: Worker [597] processing SEQNUM=5127 killed.
Okt 12 20:08:53 koboldx-x870e systemd-udevd[577]: cpu4: Worker [608] processing SEQNUM=5126 killed.
Okt 12 20:08:53 koboldx-x870e systemd-udevd[577]: 0000:1d:00.0: Worker [634] processing SEQNUM=4989 killed.
Okt 12 20:08:53 koboldx-x870e systemd-udevd[577]: cpu2: Worker [613] processing SEQNUM=5124 killed.
Okt 12 20:08:53 koboldx-x870e systemd-udevd[577]: cpu15: Worker [615] processing SEQNUM=5123 killed.
Okt 12 20:08:53 koboldx-x870e systemd-udevd[577]: cpu11: Worker [612] processing SEQNUM=5119 killed.
Okt 12 20:08:53 koboldx-x870e systemd-udevd[577]: cpu14: Worker [592] processing SEQNUM=5122 killed.
Okt 12 20:08:53 koboldx-x870e systemd-udevd[577]: cpu13: Worker [630] processing SEQNUM=5121 killed.
Okt 12 20:08:53 koboldx-x870e systemd-udevd[577]: cpu10: Worker [604] processing SEQNUM=5118 killed.
Okt 12 20:08:53 koboldx-x870e systemd-udevd[577]: cpu12: Worker [623] processing SEQNUM=5120 killed.
Okt 12 20:08:53 koboldx-x870e systemd-udevd[577]: cpu1: Worker [617] processing SEQNUM=5117 killed.
Okt 12 20:08:53 koboldx-x870e systemd-udevd[577]: cpu0: Worker [616] processing SEQNUM=5116 killed.
Okt 12 20:08:53 koboldx-x870e systemd-udevd[577]: i2c-ITE8800:01: Worker [599] processing SEQNUM=5065 killed.
Okt 12 20:08:53 koboldx-x870e systemd-udevd[577]: i2c-ITE8800:00: Worker [596] processing SEQNUM=5064 killed.
Okt 12 20:08:53 koboldx-x870e systemd-udevd[577]: cpu3: Worker [600] processing SEQNUM=5125 killed.
Okt 12 20:08:53 koboldx-x870e systemd-udevd[577]: 0000:0f:00.0: Worker [603] processing SEQNUM=4811 killed.
Okt 12 20:08:57 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#3 stuck for 183s! [(udev-worker):603]
Okt 12 20:08:57 koboldx-x870e kernel: CPU#3 Utilization every 4000ms during lockup:
Okt 12 20:08:57 koboldx-x870e kernel:         #1: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:09:24 koboldx-x870e kernel:         #2: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:09:25 koboldx-x870e kernel:         #3: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:09:25 koboldx-x870e kernel:         #4: 100% system,          0% softirq,          1% hardirq,          0% idle
Okt 12 20:09:25 koboldx-x870e kernel:         #5: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:09:24 koboldx-x870e systemd[1]: Failed to activate swap /dev/disk/by-uuid/342d34b4-152b-4a04-9479-c0b3cbc6c96f.
Okt 12 20:09:25 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#9 stuck for 183s! [swapon:707]
Okt 12 20:09:25 koboldx-x870e kernel: CPU#9 Utilization every 4000ms during lockup:
Okt 12 20:09:25 koboldx-x870e kernel:         #1: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:09:25 koboldx-x870e kernel:         #2: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:09:25 koboldx-x870e kernel:         #4: 100% system,          0% softirq,          0% hardirq,          0% idle
Okt 12 20:09:25 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#12 stuck for 183s! [(udev-worker):594]
Okt 12 20:09:25 koboldx-x870e kernel: CPU#12 Utilization every 4000ms during lockup:
Okt 12 20:09:25 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#5 stuck for 48s! [plymouthd:357]
Okt 12 20:09:25 koboldx-x870e kernel: CPU#5 Utilization every 4000ms during lockup:
Okt 12 20:09:25 koboldx-x870e kernel:         #3: 100% system,          0% softirq,          1% hardirq,          0% idle
Okt 12 20:09:25 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#0 stuck for 22s! [(udev-worker):621]
Okt 12 20:09:25 koboldx-x870e kernel: CPU#0 Utilization every 4000ms during lockup:
Okt 12 20:09:25 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#1 stuck for 22s! [(udev-worker):615]
Okt 12 20:09:25 koboldx-x870e kernel: CPU#1 Utilization every 4000ms during lockup:
Okt 12 20:09:25 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#2 stuck for 22s! [(udev-worker):608]
Okt 12 20:09:25 koboldx-x870e kernel: CPU#2 Utilization every 4000ms during lockup:
Okt 12 20:09:25 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#6 stuck for 22s! [(udev-worker):597]
Okt 12 20:09:25 koboldx-x870e kernel: CPU#6 Utilization every 4000ms during lockup:
Okt 12 20:09:25 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#7 stuck for 22s! [(udev-worker):606]
Okt 12 20:09:25 koboldx-x870e kernel: CPU#7 Utilization every 4000ms during lockup:
Okt 12 20:09:25 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#11 stuck for 22s! [(udev-worker):613]
Okt 12 20:09:25 koboldx-x870e kernel: CPU#11 Utilization every 4000ms during lockup:
Okt 12 20:09:25 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#10 stuck for 22s! [(udev-worker):596]
Okt 12 20:09:25 koboldx-x870e kernel: CPU#10 Utilization every 4000ms during lockup:
Okt 12 20:09:25 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#15 stuck for 22s! [(udev-worker):634]
Okt 12 20:09:25 koboldx-x870e kernel: CPU#15 Utilization every 4000ms during lockup:
Okt 12 20:09:25 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#13 stuck for 22s! [(udev-worker):591]
Okt 12 20:09:25 koboldx-x870e kernel: CPU#13 Utilization every 4000ms during lockup:
Okt 12 20:09:25 koboldx-x870e kernel: watchdog: BUG: soft lockup - CPU#14 stuck for 22s! [(udev-worker):607]
Okt 12 20:09:25 koboldx-x870e kernel: CPU#14 Utilization every 4000ms during lockup:
Okt 12 20:09:25 koboldx-x870e kernel:         #5: 100% system,          0% softirq,          1% hardirq,          0% idle
Okt 12 20:09:25 koboldx-x870e kernel: snd_hda_intel 0000:12:00.0: CORB reset timeout#2, CORBRP = 65535
Okt 12 20:09:25 koboldx-x870e kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x00
Okt 12 20:09:27 koboldx-x870e kernel: hdaudio hdaudioC1D1: no AFG or MFG node found
Okt 12 20:09:27 koboldx-x870e kernel: snd_hda_intel 0000:12:00.0: no codecs initialized
Okt 12 20:09:34 koboldx-x870e kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x00
Okt 12 20:09:37 koboldx-x870e kernel: amdgpu 0000:03:00.0: [drm] *ERROR* Unsupported screen format RA24 little-endian (0x34324152)
Okt 12 20:09:37 koboldx-x870e kwin_wayland[1135]: Atomic modeset commit failed! Invalid argument
Okt 12 20:09:38 koboldx-x870e bluetoothd[982]: src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon power down
Okt 12 20:09:38 koboldx-x870e bluetoothd[982]: Failed to set mode: Busy (0x0a)
Okt 12 20:09:38 koboldx-x870e kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x00
Okt 12 20:09:39 koboldx-x870e org_kde_powerdevil[1286]: [  1286][  1.248467] Time since library initialized:   1.248467 seconds
Okt 12 20:09:39 koboldx-x870e org_kde_powerdevil[1286]: [  1286][  1.248468] Extra delay starting dw_start_watch_displays: 0 millisec
Okt 12 20:09:39 koboldx-x870e bluetoothd[982]: Failed to set mode: Failed (0x03)
Okt 12 20:09:39 koboldx-x870e kernel: amdgpu 0000:03:00.0: [drm] *ERROR* Unsupported screen format RA24 little-endian (0x34324152)
Okt 12 20:15:45 koboldx-x870e kwin_wayland[1135]: Pageflip timed out! This is a bug in the amdgpu kernel driver
Okt 12 20:15:45 koboldx-x870e kwin_wayland[1135]: Please report this at https://gitlab.freedesktop.org/drm/amd/-/issues
Okt 12 20:15:45 koboldx-x870e kwin_wayland[1135]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Okt 12 20:15:45 koboldx-x870e kwin_wayland[1135]: Pageflip arrived after all, 2877ms after the commit
Okt 12 20:15:49 koboldx-x870e kwin_wayland[1135]: Pageflip timed out! This is a bug in the amdgpu kernel driver
Okt 12 20:15:49 koboldx-x870e kwin_wayland[1135]: Please report this at https://gitlab.freedesktop.org/drm/amd/-/issues
Okt 12 20:15:49 koboldx-x870e kwin_wayland[1135]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Okt 12 20:15:49 koboldx-x870e kwin_wayland[1135]: Pageflip arrived after all, 3531ms after the commit
Okt 12 20:15:52 koboldx-x870e kwin_wayland[1135]: Pageflip timed out! This is a bug in the amdgpu kernel driver
Okt 12 20:15:52 koboldx-x870e kwin_wayland[1135]: Please report this at https://gitlab.freedesktop.org/drm/amd/-/issues
Okt 12 20:15:52 koboldx-x870e kwin_wayland[1135]: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
Okt 12 20:15:52 koboldx-x870e kwin_wayland[1135]: Pageflip arrived after all, 3315ms after the commit
Okt 12 20:15:54 koboldx-x870e sudo[2619]:  koboldx : a password is required ; TTY=pts/1 ; PWD=/home/koboldx ; USER=root ; COMMAND=/sbin/file -s /dev/nvme1n1p2
Okt 12 20:27:36 koboldx-x870e kernel: watchdog: watchdog0: watchdog did not stop!
Okt 12 20:27:37 koboldx-x870e systemd-journald[463]: Failed to send stream file descriptor to service manager: Connection refused
Okt 12 20:27:37 koboldx-x870e systemd-journald[463]: Failed to send stream file descriptor to service manager: Transport endpoint is not connected
Okt 12 20:27:35 koboldx-x870e org_kde_powerdevil[1286]: [  1469][1076.951116] Open failed for /dev/i2c-4, errno=EACCES(-13): Permission denied in file i2c_bus_core.c near line 433
Okt 12 20:27:35 koboldx-x870e org_kde_powerdevil[1286]: [  1469][1076.951120] Traced function stack 0x7f04880008b0 for current thread [  1469]
Okt 12 20:27:35 koboldx-x870e org_kde_powerdevil[1286]: [  1469][1076.951122]    dw_watch_display_connections
Okt 12 20:27:35 koboldx-x870e org_kde_powerdevil[1286]: [  1469][1076.951123]    invoke_process_screen_change_event
Okt 12 20:27:35 koboldx-x870e org_kde_powerdevil[1286]: [  1469][1076.951124]    process_screen_change_event
Okt 12 20:27:35 koboldx-x870e org_kde_powerdevil[1286]: [  1469][1076.951125]    i2c_edid_exists
Okt 12 20:27:35 koboldx-x870e org_kde_powerdevil[1286]: [  1469][1076.951125]    i2c_open_bus
Okt 12 20:27:35 koboldx-x870e org_kde_powerdevil[1286]: [  1469][1076.951126]    i2c_open_bus_basic
Okt 12 20:27:35 koboldx-x870e org_kde_powerdevil[1286]: [  1469][1077.240504] Open failed for /dev/i2c-4, errno=EACCES(-13): Permission denied in file i2c_bus_core.c near line 433
Okt 12 20:27:35 koboldx-x870e org_kde_powerdevil[1286]: [  1469][1077.240519] open() failed with 1 EACCES errors, total retry ms = 100
Okt 12 20:27:35 koboldx-x870e org_kde_powerdevil[1286]: [  1469][1077.240868] Open failed for /dev/i2c-5, errno=EACCES(-13): Permission denied in file i2c_bus_core.c near line 433
Okt 12 20:27:35 koboldx-x870e org_kde_powerdevil[1286]: [  1469][1077.240874] Traced function stack 0x7f04880008b0 for current thread [  1469]
Okt 12 20:27:35 koboldx-x870e org_kde_powerdevil[1286]: [  1469][1077.240878]    dw_watch_display_connections
Okt 12 20:27:35 koboldx-x870e org_kde_powerdevil[1286]: [  1469][1077.240879]    invoke_process_screen_change_event
Okt 12 20:27:35 koboldx-x870e org_kde_powerdevil[1286]: [  1469][1077.240880]    process_screen_change_event
Okt 12 20:27:35 koboldx-x870e org_kde_powerdevil[1286]: [  1469][1077.240881]    i2c_edid_exists
Okt 12 20:27:35 koboldx-x870e org_kde_powerdevil[1286]: [  1469][1077.240882]    i2c_open_bus
Okt 12 20:27:35 koboldx-x870e org_kde_powerdevil[1286]: [  1469][1077.240883]    i2c_open_bus_basic
Okt 12 20:27:35 koboldx-x870e dbus-broker-launch[978]: Activation request for 'org.bluez' failed.
Okt 12 20:27:35 koboldx-x870e kwin_wayland[1135]: Applying output configuration failed!
Okt 12 20:27:35 koboldx-x870e dbus-broker-launch[978]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Sadly it looks like this is not the case and i think i maybe had bad luck with a newer revision (chipset)? I just looked at the package and it said, Rev D and Model NO. SB1800, SB1521 chinese stuff, maybe thats the newer chip.
I heared some warnings on Reddit and i even saw a Github Topic around that, but i just thought i give it a try, but i think i have bad luck :frowning:
My hopes are not high that this card will be working, but i think its better to ask… before i return that Soundcard, back to vendor :cold_face:
Does this happens to have a Asmedia chip on it?
Data for previous generations of AE-7 devices show the same audio codec but a different name
But AE-9 devices have previously been reported as not supported
Open Bugzilla report: 219552 – CA0132 Creative Soundblaster AE-9 no sound at all [1102:0010]
Starfoxfs 2025-01-07 08:55:42 UTC
I have compiled a Kernel with the complete Patch work of Connor Mcadams but still no sound.
In an email between Connor Mcadams and me he wrote:
"This will take a lot more work than just pincfgs, and the information
you need won’t be in ctxhda.inf. You’d need to capture the correct
commands/GPIO settings from watching the Windows driver.
FWIW, I’ve done some preliminary work on this, but stopped because it
would be more work than I have time for anymore. The biggest issue
will be dealing with the breakout module, my guess was that that will
likely require some kind of background thread in the driver and that’s
something I have no experience with.
I can try to dig up my old patches if those would be of any use, but
they still weren’t enough to get audio working. It might have been
because the AE-9 has two ca0132 codecs on board, or it may have been
due to not handling the breakout module, I’m not sure. I didn’t dig
too deeply into it at the time."
Here this is was i found:
You may have reasons to prefer kernel 7.2, and that’s fair enough, but, could you revert to kernel 6.18 (LTS) for a while and see if you can get the EA-7 working?
If it works on kernel 6.18 (LTS) then it might be an incompatibility with kernel 7.2 that is causing the problem. Neither article you linked to mentions a specific kernel, and being that the articles are from 2023 it might indicate a regression in kernel 7.2.
This is at best a guess, but worth checking, I think.
More information about Sound Blaster AE-9 devices that might be helpful for AE-7/AE-9 device
Kernel Bugzilla – 219552 – CA0132 Creative Soundblaster AE-9 no sound at all [1102:0010]
How to prevent initialization of Sound Blaster AE-9 that prevents boot / Kernel & Hardware / Arch Linux Forums
r/SoundBlasterOfficial – Linux Drivers for AE-9 with ACM Control, SBX, Knob (win db curve) + more
But I would suggest checking PCI ID code for AE-7/AE-9 device before making any changes
lspci -vvnnd 1102::0304
If AE-7/AE-9 device has a different ID code to AE-9 devices it would probably need a separate Bugzilla report for a driver patch
With 6.18 he refused to load into deaktop and went into emergency console.
From my understanding the AE-9 has 2 soundchips and works complettly different compared to AE-7, maybe thats why the first revision from AE-7 got Kernel support together with AE-5.
I executed your command but no output.
lspci -nn show:
12:00.0 Audio device [0403]: Creative Labs CA0132 Sound Core3D [Sound Blaster AE-7/AE-9] [1102:0010] (rev 01)
Related to the most user’s on reddit, there mess around so deep with AI stuff in their system, where i ask myself… if its worth it to execute blind commands.
Im not even sure how to start to made the right changes and i don’t want to rely on AI to made my AE-7 works.
TBH, the AE-7 looks like cursed hardware to me, and made so many system repairs, integrity filesystem checks/repair/replacement at my boot… im not even sure, if this changes will have a bad impact on system stability around future updates.
At this point, i must say i had fresh installed my system 2 month ago and i glad i had most stuff working now.
Maybe its the best if i remove the soundcard and use my latest timeshift snapshot to restore my system. And maybe buy a used AE-5 soundcard which should run without all this big issues.
Fair enough, at least its ruled out.
I wish I could suggest an alternative from first-hand experience, but I’ve been using onboard audio for at least the past five years. Like you, I can only judge by specs and reviews, at this point.
What is also strange, 7.3 RC refused to boot the same way as with 6.18.
So at the moment only 7.2 allows me to boot into desktop. But gave me zero sound options.
I prefered to buy new hardware, but it looks creative abandonded all reversed engineered Linux Hardware at this point. Soundblaster Z and AE-5 no longer able to official to buy as new hardware and the Z SE is facing the same problems related to reddit as with this newer AE-7 models.
And buying a used AE-5 or Z soundcard, is incredible expensive… they charge today on a used creative soundcard even a higher price as the devices was new 6 years ago.
Sick times.
It’s always been the case, I think – we only notice it when we need to buy something, but, sometimes if goes in the reverse direction.
I recall paying for a Creative Soundblaster kit (Card, burner, and something else) in around 1992/93 for almost $1000 - today one can find comparable hardware for much less, if we shop around.
Hmm you probably right, but this time it feels different, because there is no development going on, at least nothing which has higher quality or at least the same quality and by far not the durability as the older hardware.
Anyways, i return the Soundcard to its vendor and bought a other DAC.
I additional bought also a optical TOS cable, just in case i might need to rely on my onboard soundcard, which has btw. also good sound, but im not sure about the 5.1 surround there.
I think Topic can be closed now, thanks you guys anyways for the help.
typo for Class ID should be 0403
Vendor ID:Device ID [1102:0010] is insufficient to identify a specific PCI device
Find parts
also need SubVendor ID and SubDevice ID
But Linux Hardware does not show any data for an AE-7/AE-9 device
Creative Technology Ltd does not like anyone reverse engineering their patented/trademarked technology, and they have been very litigious in the past.
Support for Creative pci-e cards was provided by one Linux developer (Connor McAdams) but he has given up supporting Creative devices. One of his emails mentions a problem with an incompatible pci bridge chip that might make it impossible to provide Linux support
Linux Support for older Creative pci cards is still good because it was reverse-engineered from third-party windows drivers - kxproject · GitHub
If you want a 5.1 audio device that works better on Linux check out Asus sound cards
