Any help for creating keyboard shortcut in Manjaro?
I launch nerd-dictation from terminal and it works with the command:
/home/myhome/nerd-dictation/nerd-dictation begin --vosk-model-dir=/home/myhome/nerd-dictation/model --full-sentence --continuous --config ponctuation.py --idle-time=1&
I tried copying this into the xfce shorcut editor, but it does nothing. What I am missing?
No problem with ponctuation.py, it is a config file and it works in terminal (ponctuation is the french word for punctuation)
Have you tried
sh -c "/home/myhome/nerd-dictation/nerd-dictation begin --vosk-model-dir=/home/myhome/nerd-dictation/model --full-sentence --continuous --config ponctuation.py --idle-time=1&"
in the Xfce shortcut editor?
leodm052:
What I am missing?
A space between final option and job control ampersand --idle-time=1 &
Thanks but finally I found simpler to use the Enable/Disable microphone shortcut, as nerd-dictation keep running and does not need time to start.
