I have bought a new Gaming PC and I want to install Manjaro GNOME on it now. I read that the USB Stick should be in GPT Format for the reason that it is the more latest than MBR.
I used Balena Etcher before, but I can’t selct GPT there.
Does anyone know with which programm I can format a GPT USB Stick, and should I really need GPT?
I have a MSI H510M-A Pro Mainboard. Thanks in Advance!
The format does not matter as the iso is (usually) written to the raw device.
The USB essentially becomes a CD drive once you write the iso to it.
Use ventoy if you can - it is easier to handle and you can still use the USB thing for regular storage as well.
Manjaro’s ISO’s are of hybrid design, you can either boot them in BIOS or UEFI mode by selecting the UEFI or non-UEFI entry from your firmware in case your firmware is capable to boot in both modes.
