Hi guys
I need to create a vpn connection through my pc.
In particular I would like to connect my pc to a network (via wi-fi or ethernet is indifferent) not protected by vpn, and then create a network (hotspot or cable) protected by vpn.
So that all devices connected to the pc network use the pc vpn.
I hope I explained myself well, any advice could be useful, thanks in advance.
Well, you cannot possibly think of connecting your “other” devices though your pc (with vpn) without connecting “your pc” to that vpn. Well, you could just connect your router to that vpn instead. It would be far better than trying to connect your devices through your pc without connecting your pc. All you have to do is not to connect your pc to your router.
