Im using manjaro now but i want to switch to nitrux distro. I have no idea how to make my usb flash bootable. Is there any app like rufus for arch linux?
Use Ventoy
Or use simply dd:
=> to view a list of all drives currently attached to your system run this command: lsblk
=> umount /dev/sdc* (if sdc is your usb-devive)
=> change to the directory where the ISO is located
=> then you can ls (list / take a look at) your file with: ls *.iso
=> now we should see our ISO file, and we’re inside the same directory with it.
=> since, we’re already in the right directory, we can use:
sudo dd if=[name-of-iso.iso] of=/dev/sdc bs=1M status=progress conv=fdatasync
