In the left audio channel, I sometimes hear a crashing sound.
I remember, I had to reinstall Manjaro KDE with pipewire.
Does this come from pipewire or is the mainboard defective (sound chip) ?
I have swaped the two channels of the loudspeakers and now the sound comes from the right channel.
So the source of the sound is the computer.
I measured the booting process (Linux) with a digital voltmeter. I measured a peak of 4.5 mV.
I measured the booting process (Windows) with a digital voltmeter. I measured no peak.
âsometimesâ is not a good start
What is (or may be) the significance of that?
It is the source in any case.
It depends on the type of âvoltmeterâ and how it aquires itâs measurements
and on the measurement process
whether this observed difference can even tell you anything.
The source of the sound could also be the loudspeakers.
But I swaped the two channel (left to right and right to left).
The sound the came from the right channel.
So, the cables and the loudspeakers is not the source.
I measured the peak in the left channel with digital voltmeter in 200mV DC range.
I can measure the peak on every boot process.
The sound of the two channels is the same and sounds good.
If the âcrashing soundâ is audible only when system is booted it is more likely to be an issue with alsa/kernel. But if there is similar noise when starting or stopping audio playback or suspending/hibernating it is more likely to be from pipewire/wireplumber
If you are using kernel v6.7 or v6.8 I suggest you use an LTS kernel v6.6 or v6.1 as a temporary workaround - sometimes these noise issues are resolved by a kernel update
Disabling power management in ALSA may also help
sudo tee /etc/modprobe.d/hda-no-suspend.conf <<< 'options snd_hda_intel power_save=0'
This is my inxi -Fza
inxi -Fza
Kernel: 6.6.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/vmlinuz-6.6-x86_64
root=UUID=86b44fe2-10a4-46cd-a916-50fa4f477973 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Server System: Supermicro product: X10SRA v: 0123456789
serial: <filter> Chassis: type: 17 v: 0123456789 serial: <filter>
Mobo: Supermicro model: X10SRA v: 1.01 serial: <filter>
uuid: 00000000-0000-0000-0000-ac1f6b15f24c UEFI: American Megatrends v: 2.1a
date: 10/24/2018
Info: model: Intel Core i7-6800K socket: LGA2011-3 bits: 64 type: MT MCP
arch: Broadwell gen: core 6 level: v3 note: check built: 2015-18
process: Intel 14nm family: 6 model-id: 0x4F (79) stepping: 1
microcode: 0xB000040
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 15 MiB desc: 1x15 MiB
Speed (MHz): avg: 1417 high: 3800 min/max: 1200/3800 base/boost: 3400/4000
scaling: driver: intel_cpufreq governor: schedutil volts: 1.8 V
ext-clock: 100 MHz cores: 1: 3800 2: 1200 3: 1200 4: 1200 5: 1200 6: 1207
7: 1200 8: 1200 9: 1200 10: 1200 11: 1200 12: 1200 bogomips: 81625
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] driver: nouveau v: kernel
non-free: 545.xx+ status: current (as of 2024-02; EOL~2026-12-xx)
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: DP-1 empty: DVI-D-1,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 10de:2182
class-ID: 0300 temp: 25.0 C
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: nouveau gpu: nouveau display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
s-diag: 777mm (30.58") monitors: <missing: xrandr>
Monitor-1: DP-1 model: Dell U2713HM serial: <filter> built: 2012
res: 2560x1440 dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23")
diag: 685mm (27") ratio: 16:9 modes: max: 2560x1440 min: 720x400
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau x11:
drv: nouveau inactive: wayland
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: NV168 device-ID: 10de:2182
memory: 5.84 GiB unified: no
Device-1: Intel C610/X99 series HD Audio vendor: Super Micro
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8d20
class-ID: 0403
Device-2: NVIDIA TU116 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 03:00.1 chip-ID: 10de:1aeb class-ID: 0403
API: ALSA v: k6.6.19-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: Intel I210 Gigabit Network vendor: Super Micro driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 05:00.0
chip-ID: 8086:1533 class-ID: 0200
Device-2: Intel I210 Gigabit Network vendor: Super Micro driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 06:00.0
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
Info: services: NetworkManager
Local Storage: total: 1.38 TiB used: 277.88 GiB (19.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 22.9 C
scheme: GPT
SMART: yes health: PASSED on: 41d 19h cycles: 11,695
read-units: 90,083,625 [46.1 TB] written-units: 26,355,370 [13.4 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 PRO 512GB
family: based SSDs size: 476.94 GiB block-size: physical: 512 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 4B6Q temp: 20 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 150d 12h cycles: 32496
written: 7.05 TiB
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 8.91 GiB (9.1%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p8 maj-min: 259:8
ID-2: /boot raw-size: 1024 MiB size: 973.4 MiB (95.06%)
used: 230.4 MiB (23.7%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p6
maj-min: 259:6
ID-3: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
used: 300 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p5
maj-min: 259:5
ID-4: /home raw-size: 300 GiB size: 294.23 GiB (98.08%)
used: 15.02 GiB (5.1%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p9
maj-min: 259:9
ID-5: /var raw-size: 32.46 GiB size: 31.66 GiB (97.51%)
used: 4.19 GiB (13.2%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p10
maj-min: 259:10
ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p7 maj-min: 259:7
System Temperatures: cpu: 16.0 C pch: 28.0 C mobo: N/A gpu: nouveau
temp: 25.0 C
Fan Speeds (rpm): N/A gpu: nouveau fan: 409
Memory: total: 32 GiB available: 31.22 GiB used: 2.37 GiB (7.6%)
Processes: 375 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: pm: pacman pkgs: 1201 libs: 362 tools: pamac pm: flatpak pkgs: 0
Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Bash (su) v: 5.2.26
running-in: konsole inxi: 3.3.33
system
Closed
19 March 2024 02:20
6
