Crashed GDM, need help debugging or reinstalling
Problem description
I freshly installed Manjaro today on my new harddisk. I then restored my home folder from a back-up. Everything seemed to work and have been restored, until I rebooted a second time and gdm kept crashing. After 10 crashes he now sometimes gives up and sometimes restarts with X11, which seemed to work.
After rebooting again though, it got stuck in the restart-cycle and did not switch to X11 and did not allow me to open a TTY-session, as it kept restarting.
journalctl
The following report kept repeating over and over.
jan 08 21:09:03 Manjaro-laptop systemd[1]: Starting GNOME Display Manager...
jan 08 21:09:03 Manjaro-laptop systemd[1]: Started GNOME Display Manager.
jan 08 21:09:03 Manjaro-laptop audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=gdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=su>
jan 08 21:09:03 Manjaro-laptop audit[1288]: USER_AUTH pid=1288 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_permit acct="max" exe="/usr/lib/gdm-sessio>
jan 08 21:09:03 Manjaro-laptop dbus-daemon[508]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.58' (uid=0 pid=1288 comm="gdm-se>
jan 08 21:09:03 Manjaro-laptop dbus-daemon[508]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
jan 08 21:09:03 Manjaro-laptop gdm-autologin][1288]: pam_systemd_home(gdm-autologin:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
jan 08 21:09:03 Manjaro-laptop audit[1288]: USER_ACCT pid=1288 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="max" exe="/usr/>
jan 08 21:09:03 Manjaro-laptop audit[1288]: CRED_ACQ pid=1288 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_permit acct="max" exe="/usr/lib/gdm-session-worker>
jan 08 21:09:03 Manjaro-laptop audit[1288]: SYSCALL arch=c000003e syscall=1 success=yes exit=4 a0=a a1=7ffe2e0f33c0 a2=4 a3=3e8 items=0 ppid=1285 pid=1288 auid=1000 uid=0 gid=1001 euid=0 suid=0 fsuid=0 egid=100>
jan 08 21:09:03 Manjaro-laptop audit: PROCTITLE proctitle=67646D2D73657373696F6E2D776F726B6572205B70616D2F67646D2D6175746F6C6F67696E5D
jan 08 21:09:03 Manjaro-laptop gdm-autologin][1288]: pam_unix(gdm-autologin:session): session opened for user max(uid=1000) by (uid=0)
jan 08 21:09:03 Manjaro-laptop gdm-autologin][1288]: pam_env(gdm-autologin:session): deprecated reading of user environment enabled
jan 08 21:09:03 Manjaro-laptop gdm-autologin][1288]: gkr-pam: unable to locate daemon control file
jan 08 21:09:03 Manjaro-laptop gdm-autologin][1288]: gkr-pam: gnome-keyring-daemon started properly
jan 08 21:09:03 Manjaro-laptop audit[1288]: USER_START pid=1288 uid=0 auid=1000 ses=8 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,>
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (--) Log file renamed from "/var/log/Xorg.pid-1300.log" to "/var/log/Xorg.0.log"
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: X.Org X Server 1.21.1.2
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: X Protocol Version 11, Revision 0
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: Current Operating System: Linux Manjaro-laptop 5.15.12-1-MANJARO #1 SMP PREEMPT Wed Dec 29 18:08:07 UTC 2021 x86_64
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=bb738703-329b-426b-9a8c-e3e4f0a6faff rw quiet cryptdevice=UUID=81065014-05ba-4060>
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: Current version of pixman: 0.40.0
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         Before reporting problems, check http://wiki.x.org
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         to make sure that you have the latest version.
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: Markers: (--) probed, (**) from config file, (==) default setting,
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         (++) from command line, (!!) notice, (II) informational,
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) Log file: "/var/log/Xorg.0.log", Time: Sat Jan  8 21:09:03 2022
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) Using config directory: "/etc/X11/xorg.conf.d"
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) ServerLayout "layout"
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) No screen section available. Using defaults.
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) |-->Screen "Default Screen Section" (0)
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) |   |-->Monitor "<default monitor>"
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) No monitor specified for screen "Default Screen Section".
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         Using a default monitor configuration.
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) Automatically adding devices
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) Automatically enabling devices
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) Automatically adding GPU devices
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) Automatically binding GPU devices
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) Max clients allowed: 256, resource mask: 0x1fffff
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (WW) The directory "/usr/share/fonts/OTF" does not exist.
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         Entry deleted from font path.
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (WW) The directory "/usr/share/fonts/Type1" does not exist.
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (WW) The directory "/usr/share/fonts/100dpi" does not exist.
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (WW) The directory "/usr/share/fonts/75dpi" does not exist.
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) FontPath set to:
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         /usr/share/fonts/misc,
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         /usr/share/fonts/TTF
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) ModulePath set to "/usr/lib/xorg/modules"
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) The server relies on udev to provide the list of input devices.
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         If no devices become available, reconfigure udev or disable AutoAddDevices.
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Module ABI versions:
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         X.Org ANSI C Emulation: 0.4
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         X.Org Video Driver: 25.2
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         X.Org XInput driver : 24.4
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         X.Org Server Extension : 10.0
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (++) using VT number 2
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (EE) systemd-logind: failed to get session: PID 1300 does not belong to any known session
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) xfree86: Adding drm device (/dev/dri/card1)
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card1
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) xfree86: Adding drm device (/dev/dri/card0)
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Platform probe for /sys/devices/pci0000:00/0000:00:1c.4/0000:09:00.0/drm/card0
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg>
jan 08 21:09:03 Manjaro-laptop kernel: nvidia 0000:09:00.0: Enabling HDA controller
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (--) PCI:*(0@0:2:0) 8086:1616:1179:f840 rev 9, Mem @ 0xb3000000/16777216, 0xc0000000/268435456, I/O @ 0x00006000/64, BIOS @ 0x????????/131072
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (--) PCI: (9@0:0:0) 10de:1346:1179:f842 rev 162, Mem @ 0xb4000000/16777216, 0xa0000000/268435456, 0xb0000000/33554432, I/O @ 0x00003000/128
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) LoadModule: "glx"
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Module glx: vendor="X.Org Foundation"
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         compiled for 1.21.1.2, module version = 1.0.0
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         ABI class: X.Org Server Extension, version 10.0
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Applying OutputClass "intel" to /dev/dri/card1
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         loading driver: modesetting
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Applying OutputClass "nvidia" to /dev/dri/card0
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         loading driver: nvidia
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) Matched modesetting as autoconfigured driver 0
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) Matched nvidia as autoconfigured driver 1
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) Matched nouveau as autoconfigured driver 2
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) Matched nv as autoconfigured driver 3
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) Matched fbdev as autoconfigured driver 4
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) Matched vesa as autoconfigured driver 5
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) Assigned the driver to the xf86ConfigLayout
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) LoadModule: "modesetting"
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Module modesetting: vendor="X.Org Foundation"
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         compiled for 1.21.1.2, module version = 1.21.1
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         Module class: X.Org Video Driver
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         ABI class: X.Org Video Driver, version 25.2
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) LoadModule: "nvidia"
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Module nvidia: vendor="NVIDIA Corporation"
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         compiled for 1.6.99.901, module version = 1.0.0
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) LoadModule: "nouveau"
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Module nouveau: vendor="X.Org Foundation"
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         compiled for 1.21.1.1, module version = 1.0.17
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) LoadModule: "nv"
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (WW) Warning, couldn't open module nv
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (EE) Failed to load module "nv" (module does not exist, 0)
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) LoadModule: "fbdev"
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (WW) Warning, couldn't open module fbdev
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (EE) Failed to load module "fbdev" (module does not exist, 0)
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) LoadModule: "vesa"
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (WW) Warning, couldn't open module vesa
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (EE) Failed to load module "vesa" (module does not exist, 0)
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modesetting: Driver for Modesetting Kernel Drivers: kms
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) NVIDIA dlloader X Driver  495.44  Fri Oct 22 06:11:21 UTC 2021
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) NOUVEAU driver
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) NOUVEAU driver for NVIDIA chipset families :
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         RIVA TNT            (NV04)
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         RIVA TNT2           (NV05)
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         GeForce 256         (NV10)
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         GeForce 2           (NV11, NV15)
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         GeForce 4MX         (NV17, NV18)
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         GeForce 3           (NV20)
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         GeForce 4Ti         (NV25, NV28)
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         GeForce FX          (NV3x)
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         GeForce 6           (NV4x)
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         GeForce 7           (G7x)
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         GeForce 8           (G8x)
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         GeForce 9           (G9x)
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         GeForce GTX 2xx/3xx (GT2xx)
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         GeForce GTX 4xx/5xx (GFxxx)
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         GeForce GTX 6xx/7xx (GKxxx)
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         GeForce GTX 9xx     (GMxxx)
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         GeForce GTX 10xx    (GPxxx)
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): using drv /dev/dri/card1
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Loading sub module "fb"
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) LoadModule: "fb"
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Module "fb" already built-in
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Loading sub module "wfb"
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) LoadModule: "wfb"
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Loading /usr/lib/xorg/modules/libwfb.so
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Module wfb: vendor="X.Org Foundation"
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         ABI class: X.Org ANSI C Emulation, version 0.4
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Loading sub module "ramdac"
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) LoadModule: "ramdac"
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Module "ramdac" already built-in
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Creating default Display subsection in Screen section
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         "Default Screen Section" for depth/fbbpp 24/32
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) modeset(0): Depth 24, (==) framebuffer bpp 32
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) modeset(0): RGB weight 888
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) modeset(0): Default visual is TrueColor
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Loading sub module "glamoregl"
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) LoadModule: "glamoregl"
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Loading /usr/lib/xorg/modules/libglamoregl.so
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Module glamoregl: vendor="X.Org Foundation"
jan 08 21:09:03 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         compiled for 1.21.1.2, module version = 1.0.1
jan 08 21:09:04 Manjaro-laptop kernel: nvidia 0000:09:00.0: Enabling HDA controller
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) HD Graphics 5500 (BDW GT2)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): glamor initialized
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) modeset(0): VariableRefresh: disabled
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) modeset(0): AsyncFlipSecondaries: disabled
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Output eDP-1 has no monitor section
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Output HDMI-1 has no monitor section
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): EDID for output eDP-1
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Manufacturer: LGD  Model: 470  Serial#: 0
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Year: 2014  Week: 0
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): EDID Version: 1.4
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Digital Display Input
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): 6 bits per channel
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Digital interface is DisplayPort
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Max Image Size [cm]: horiz.: 35  vert.: 19
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Gamma: 2.20
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): DPMS capabilities: StandBy Suspend Off
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): First detailed timing is preferred mode
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Preferred mode is native pixel format and refresh rate
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): redX: 0.640 redY: 0.345   greenX: 0.335 greenY: 0.625
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): blueX: 0.150 blueY: 0.052   whiteX: 0.313 whiteY: 0.329
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Manufacturer's mask: 0
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Supported detailed timing:
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): clock: 138.7 MHz   Image Size:  345 x 194 mm
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): h_active: 1920  h_sync: 1968  h_sync_end 2000 h_blank_end 2080 h_border: 0
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): v_active: 1080  v_sync: 1083  v_sync_end 1088 v_blanking: 1111 v_border: 0
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0):  LG Display
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0):  LP156WF6-SPA1
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): EDID (in hex):
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0):         00ffffffffffff0030e4700400000000
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0):         0018010495231378eadc95a35855a026
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0):         0d505400000001010101010101010101
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0):         0101010101012e3680a070381f403020
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0):         350059c21000001a0000000000000000
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0):         00000000000000000000000000fe004c
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0):         4720446973706c61790a2020000000fe
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0):         004c503135365746362d53504131007b
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Printing probed modes for output eDP-1
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1920x1080"x60.0  138.70  1920 1968 2000 2080  1080 1083 1088 1111 +hsync -vsync (66.7 kHz eP)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1920x1080"x120.0  356.38  1920 2080 2288 2656  1080 1081 1084 1118 doublescan -hsync +vsync (134.2 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1920x1080"x119.9  266.50  1920 1944 1960 2000  1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1920x1080"x60.0  173.00  1920 2048 2248 2576  1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1920x1080"x59.9  138.50  1920 1968 2000 2080  1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1680x1050"x60.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1400x1050"x60.0  122.00  1400 1488 1640 1880  1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1600x900"x120.0  246.00  1600 1728 1900 2200  900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1600x900"x119.9  186.50  1600 1624 1640 1680  900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1600x900"x59.9  118.25  1600 1696 1856 2112  900 903 908 934 -hsync +vsync (56.0 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1600x900"x59.8   97.50  1600 1648 1680 1760  900 903 908 926 +hsync -vsync (55.4 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1400x900"x60.0  103.50  1400 1480 1624 1848  900 903 913 934 -hsync +vsync (56.0 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1400x900"x59.9   86.50  1400 1448 1480 1560  900 903 913 926 +hsync -vsync (55.4 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1440x810"x120.0  198.12  1440 1548 1704 1968  810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1440x810"x119.9  151.88  1440 1464 1480 1520  810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1368x768"x59.9   85.25  1368 1440 1576 1784  768 771 781 798 -hsync +vsync (47.8 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1368x768"x59.9   72.25  1368 1416 1448 1528  768 771 781 790 +hsync -vsync (47.3 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1280x800"x120.0  174.25  1280 1380 1516 1752  800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1280x800"x119.9  134.25  1280 1304 1320 1360  800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1280x800"x59.8   83.50  1280 1352 1480 1680  800 803 809 831 -hsync +vsync (49.7 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1280x800"x59.9   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1280x720"x120.0  156.12  1280 1376 1512 1744  720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1280x720"x120.0  120.75  1280 1304 1320 1360  720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1280x720"x59.9   74.50  1280 1344 1472 1664  720 723 728 748 -hsync +vsync (44.8 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1280x720"x59.7   63.75  1280 1328 1360 1440  720 723 728 741 +hsync -vsync (44.3 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1024x768"x120.1  133.47  1024 1100 1212 1400  768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "960x720"x120.0  117.00  960 1024 1128 1300  720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "928x696"x120.1  109.15  928 976 1088 1264  696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "896x672"x120.0  102.40  896 960 1060 1224  672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1024x576"x119.9   98.50  1024 1092 1200 1376  576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1024x576"x119.9   78.38  1024 1048 1064 1104  576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1024x576"x59.9   46.50  1024 1064 1160 1296  576 579 584 599 -hsync +vsync (35.9 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "1024x576"x59.8   42.00  1024 1072 1104 1184  576 579 584 593 +hsync -vsync (35.5 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "960x600"x119.9   96.62  960 1028 1128 1296  600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "960x600"x120.0   77.00  960 984 1000 1040  600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "960x540"x119.9   86.50  960 1024 1124 1288  540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "960x540"x120.0   69.25  960 984 1000 1040  540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "960x540"x59.6   40.75  960 992 1088 1216  540 543 548 562 -hsync +vsync (33.5 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "960x540"x59.8   37.25  960 1008 1040 1120  540 543 548 556 +hsync -vsync (33.3 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "800x600"x120.0   81.00  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "840x525"x120.0   73.12  840 892 980 1120  525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "840x525"x119.8   59.50  840 864 880 920  525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "864x486"x59.9   32.50  864 888 968 1072  486 489 494 506 -hsync +vsync (30.3 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "864x486"x59.6   30.50  864 912 944 1024  486 489 494 500 +hsync -vsync (29.8 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "700x525"x120.0   61.00  700 744 820 940  525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "800x450"x119.9   59.12  800 848 928 1056  450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "800x450"x119.6   48.75  800 824 840 880  450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "640x512"x120.0   54.00  640 664 720 844  512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "700x450"x119.9   51.75  700 740 812 924  450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "700x450"x119.8   43.25  700 724 740 780  450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "640x480"x120.0   54.00  640 688 744 900  480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "720x405"x59.5   22.50  720 744 808 896  405 408 413 422 -hsync +vsync (25.1 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "720x405"x59.0   21.75  720 768 800 880  405 408 413 419 +hsync -vsync (24.7 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "684x384"x119.8   42.62  684 720 788 892  384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "684x384"x119.7   36.12  684 708 724 764  384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "640x400"x119.8   41.75  640 676 740 840  400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "640x400"x120.0   35.50  640 664 680 720  400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "640x360"x119.7   37.25  640 672 736 832  360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "640x360"x119.7   31.88  640 664 680 720  360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "640x360"x59.8   18.00  640 664 720 800  360 363 368 376 -hsync +vsync (22.5 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "640x360"x59.3   17.75  640 688 720 800  360 363 368 374 +hsync -vsync (22.2 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "512x384"x120.0   32.50  512 524 592 672  384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "512x288"x120.0   23.25  512 532 580 648  288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "512x288"x119.8   21.00  512 536 552 592  288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "480x270"x119.3   20.38  480 496 544 608  270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "480x270"x119.6   18.62  480 504 520 560  270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "400x300"x120.6   20.00  400 420 484 528  300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "400x300"x112.7   18.00  400 412 448 512  300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "432x243"x119.8   16.25  432 444 484 536  243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "432x243"x119.1   15.25  432 456 472 512  243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "320x240"x120.1   12.59  320 328 376 400  240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "360x202"x119.0   11.25  360 372 404 448  202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "360x202"x118.3   10.88  360 384 400 440  202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "320x180"x119.7    9.00  320 332 360 400  180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Modeline "320x180"x118.6    8.88  320 344 360 400  180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): EDID for output HDMI-1
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Output eDP-1 connected
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Output HDMI-1 disconnected
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Using exact sizes for initial modes
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Output eDP-1 using initial mode 1920x1080 +0+0
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) modeset(0): DPI set to (96, 96)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Loading sub module "fb"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) LoadModule: "fb"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Module "fb" already built-in
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) NVIDIA(G0): Depth 24, (==) framebuffer bpp 32
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) NVIDIA(G0): RGB weight 888
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) NVIDIA(G0): Default visual is TrueColor
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) NVIDIA(G0): Using gamma correction (1.0, 1.0, 1.0)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Option "AllowNVIDIAGpuScreens"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Applying OutputClass "nvidia" options to /dev/dri/card0
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) NVIDIA(G0): Option "AllowEmptyInitialConfiguration"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) NVIDIA(G0): Enabling 2D acceleration
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Loading sub module "glxserver_nvidia"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) LoadModule: "glxserver_nvidia"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         compiled for 1.6.99.901, module version = 1.0.0
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         Module class: X.Org Server Extension
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) NVIDIA GLX Module  495.44  Fri Oct 22 06:08:29 UTC 2021
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) NVIDIA: The X server supports PRIME Render Offload.
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) NVIDIA(G0): NVIDIA GPU NVIDIA GeForce 930M (GM108-A) at PCI:9:0:0 (GPU-0)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (--) NVIDIA(G0): Memory: 2097152 kBytes
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (--) NVIDIA(G0): VideoBIOS: 82.08.46.00.1e
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) NVIDIA(G0): Detected PCI Express Link width: 4X
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) NVIDIA(G0): Validated MetaModes:
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) NVIDIA(G0):     "NULL"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) NVIDIA(G0): Virtual screen size determined to be 640 x 480
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (WW) NVIDIA(G0): Unable to get display device for DPI computation.
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) NVIDIA(G0): DPI set to (75, 75); computed from built-in default
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) UnloadModule: "nouveau"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Unloading nouveau
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) modeset(0): Backing store enabled
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) modeset(0): Silken mouse enabled
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) modeset(0): DPMS enabled
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): [DRI2] Setup complete
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): [DRI2]   DRI driver: iris
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): [DRI2]   VDPAU driver: va_gl
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) NVIDIA: Reserving 6144.00 MB of virtual memory for indirect memory
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) NVIDIA:     access.
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) NVIDIA(G0): ACPI: failed to connect to the ACPI event daemon; the daemon
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) NVIDIA(G0):     may not be running or the "AcpidSocketPath" X
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) NVIDIA(G0):     configuration option may not be set correctly.  When the
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) NVIDIA(G0):     ACPI event daemon is available, the NVIDIA X driver will
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) NVIDIA(G0):     try to use it to receive ACPI event notifications.  For
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) NVIDIA(G0):     details, please see the "ConnectToAcpid" and
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) NVIDIA(G0):     "AcpidSocketPath" X configuration options in Appendix B: X
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) NVIDIA(G0):     Config Options in the README.
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) NVIDIA(G0): Setting mode "NULL"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) NVIDIA(G0): Disabling shared memory pixmaps
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) NVIDIA(G0): Backing store enabled
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) NVIDIA(G0): Silken mouse enabled
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (==) NVIDIA(G0): DPMS enabled
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Loading sub module "dri2"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) LoadModule: "dri2"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Module "dri2" already built-in
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) NVIDIA(G0): [DRI2] Setup complete
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) NVIDIA(G0): [DRI2]   VDPAU driver: nvidia
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension Generic Event Extension
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension SHAPE
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension MIT-SHM
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension XInputExtension
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension XTEST
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension BIG-REQUESTS
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension SYNC
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension XKEYBOARD
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension XC-MISC
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension SECURITY
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension XFIXES
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension RENDER
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension RANDR
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension COMPOSITE
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension DAMAGE
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension MIT-SCREEN-SAVER
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension DOUBLE-BUFFER
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension RECORD
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension DPMS
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension Present
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension DRI3
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension X-Resource
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension XVideo
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension XVideo-MotionCompensation
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension GLX
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Indirect GLX disabled.
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) AIGLX: Loaded and initialized iris
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) GLX: Initialized DRI2 GL provider for screen 0
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension XFree86-VidModeExtension
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension XFree86-DGA
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension XFree86-DRI
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension DRI2
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension NV-GLX
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Initializing extension NV-CONTROL
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Damage tracking initialized
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) modeset(0): Setting screen physical size to 508 x 285
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) config/udev: Adding input device Power Button (/dev/input/event2)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Power Button: Applying InputClass "evdev keyboard catchall"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Power Button: Applying InputClass "libinput keyboard catchall"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Power Button: Applying InputClass "system-keyboard"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) LoadModule: "libinput"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Module libinput: vendor="X.Org Foundation"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         compiled for 1.21.1, module version = 1.2.0
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         Module class: X.Org XInput Driver
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]:         ABI class: X.Org XInput driver, version 24.4
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Using input driver 'libinput' for 'Power Button'
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Power Button: always reports core events
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Option "Device" "/dev/input/event2"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Option "_source" "server/udev"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) event2  - Power Button: is tagged by udev as: Keyboard
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) event2  - Power Button: device is a keyboard
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) event2  - Power Button: device removed
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Option "xkb_layout" "us"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Option "xkb_variant" "intl"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) config/udev: Adding input device Video Bus (/dev/input/event9)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Video Bus: Applying InputClass "evdev keyboard catchall"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Video Bus: Applying InputClass "libinput keyboard catchall"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Video Bus: Applying InputClass "system-keyboard"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Using input driver 'libinput' for 'Video Bus'
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Video Bus: always reports core events
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Option "Device" "/dev/input/event9"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) event9  - Video Bus: is tagged by udev as: Keyboard
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) event9  - Video Bus: device is a keyboard
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) event9  - Video Bus: device removed
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input16/event9"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) config/udev: Adding input device Video Bus (/dev/input/event10)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Option "Device" "/dev/input/event10"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) event10 - Video Bus: is tagged by udev as: Keyboard
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) event10 - Video Bus: device is a keyboard
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) event10 - Video Bus: device removed
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:4b/LNXVIDEO:01/input/input17/event10"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) config/udev: Adding input device Power Button (/dev/input/event0)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Option "Device" "/dev/input/event0"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) event0  - Power Button: is tagged by udev as: Keyboard
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) event0  - Power Button: device is a keyboard
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) event0  - Power Button: device removed
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) config/udev: Adding input device Lid Switch (/dev/input/event1)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) No input driver specified, ignoring this device.
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) This device may have been added with another device file.
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=3 (/dev/input/event11)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=7 (/dev/input/event12)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=8 (/dev/input/event13)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=9 (/dev/input/event14)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=10 (/dev/input/event15)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) config/udev: Adding input device TOSHIBA Web Camera - HD: TOSHIB (/dev/input/event16)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) TOSHIBA Web Camera - HD: TOSHIB: Applying InputClass "evdev keyboard catchall"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) TOSHIBA Web Camera - HD: TOSHIB: Applying InputClass "libinput keyboard catchall"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) TOSHIBA Web Camera - HD: TOSHIB: Applying InputClass "system-keyboard"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Using input driver 'libinput' for 'TOSHIBA Web Camera - HD: TOSHIB'
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) TOSHIBA Web Camera - HD: TOSHIB: always reports core events
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Option "Device" "/dev/input/event16"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) event16 - TOSHIBA Web Camera - HD: TOSHIB: is tagged by udev as: Keyboard
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) event16 - TOSHIBA Web Camera - HD: TOSHIB: device is a keyboard
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) event16 - TOSHIBA Web Camera - HD: TOSHIB: device removed
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-7/2-7:1.0/input/input23/event16"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) XINPUT: Adding extended input device "TOSHIBA Web Camera - HD: TOSHIB" (type: KEYBOARD, id 10)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event6)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event7)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) AT Translated Set 2 keyboard: always reports core events
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Option "Device" "/dev/input/event3"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) event3  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) event3  - AT Translated Set 2 keyboard: device is a keyboard
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) event3  - AT Translated Set 2 keyboard: device removed
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 11)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/event8)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) ETPS/2 Elantech Touchpad: Applying InputClass "evdev touchpad catchall"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) ETPS/2 Elantech Touchpad: Applying InputClass "libinput touchpad catchall"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Using input driver 'libinput' for 'ETPS/2 Elantech Touchpad'
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) ETPS/2 Elantech Touchpad: always reports core events
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Option "Device" "/dev/input/event8"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) event8  - ETPS/2 Elantech Touchpad: is tagged by udev as: Touchpad
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) event8  - ETPS/2 Elantech Touchpad: device is a touchpad
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) event8  - ETPS/2 Elantech Touchpad: device removed
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio2/input/input11/event8"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) XINPUT: Adding extended input device "ETPS/2 Elantech Touchpad" (type: TOUCHPAD, id 12)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Option "AccelerationScheme" "none"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) ETPS/2 Elantech Touchpad: (accel) selected scheme none/0
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) ETPS/2 Elantech Touchpad: (accel) acceleration factor: 2.000
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) ETPS/2 Elantech Touchpad: (accel) acceleration threshold: 4
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/mouse0)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) config/udev: Adding input device Toshiba input device (/dev/input/event4)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Toshiba input device: Applying InputClass "evdev keyboard catchall"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Toshiba input device: Applying InputClass "libinput keyboard catchall"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Toshiba input device: Applying InputClass "system-keyboard"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Using input driver 'libinput' for 'Toshiba input device'
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Toshiba input device: always reports core events
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Option "Device" "/dev/input/event4"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) event4  - Toshiba input device: is tagged by udev as: Keyboard
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) event4  - Toshiba input device: device is a keyboard
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) event4  - Toshiba input device: device removed
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (**) Option "config_info" "udev:/sys/devices/virtual/input/input8/event4"
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) XINPUT: Adding extended input device "Toshiba input device" (type: KEYBOARD, id 13)
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1314]: dbus-daemon[1314]: [session uid=1000 pid=1314] Activating service name='org.freedesktop.systemd1' requested by ':1.0' (uid=1000 pid=1298 comm="/usr/l>
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1314]: dbus-daemon[1314]: [session uid=1000 pid=1314] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with stat>
jan 08 21:09:04 Manjaro-laptop /usr/lib/gdm-x-session[1298]: Unable to register display with display manager
jan 08 21:09:04 Manjaro-laptop NetworkManager[509]: <warn>  [1641672544.9593] ndisc[0x55aeccd70ad0,"wlp7s0"]: solicit: failure sending router solicitation: Cannot assign requested address (99)
jan 08 21:09:05 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) event8  - ETPS/2 Elantech Touchpad: device removed
jan 08 21:09:05 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) event4  - Toshiba input device: device removed
jan 08 21:09:05 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) UnloadModule: "libinput"
jan 08 21:09:05 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) NVIDIA(GPU-0): Deleting GPU-0
jan 08 21:09:05 Manjaro-laptop /usr/lib/gdm-x-session[1300]: (II) Server terminated successfully (0). Closing log file.
jan 08 21:09:05 Manjaro-laptop gdm-autologin][1288]: pam_unix(gdm-autologin:session): session closed for user max
jan 08 21:09:05 Manjaro-laptop audit[1288]: USER_END pid=1288 uid=0 auid=1000 ses=8 subj==unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,p>
jan 08 21:09:05 Manjaro-laptop audit[1288]: CRED_DISP pid=1288 uid=0 auid=1000 ses=8 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_permit acct="max" exe="/usr/lib/gdm-session-worker" hostname=Man>
jan 08 21:09:05 Manjaro-laptop gdm[1285]: Gdm: GdmDisplay: Session never registered, failing
jan 08 21:09:05 Manjaro-laptop audit[1285]: ANOM_ABEND auid=4294967295 uid=0 gid=0 ses=4294967295 subj==unconfined pid=1285 comm="gdm" exe="/usr/bin/gdm" sig=11 res=1
jan 08 21:09:05 Manjaro-laptop audit: BPF prog-id=37 op=LOAD
jan 08 21:09:05 Manjaro-laptop audit: BPF prog-id=38 op=LOAD
jan 08 21:09:05 Manjaro-laptop audit: BPF prog-id=39 op=LOAD
jan 08 21:09:05 Manjaro-laptop systemd[1]: Started Process Core Dump (PID 1319/UID 0).
jan 08 21:09:05 Manjaro-laptop audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@6-1319-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? ad>
jan 08 21:09:05 Manjaro-laptop systemd-coredump[1320]: [🡕] Process 1285 (gdm) of user 0 dumped core.
                                                       Module linux-vdso.so.1 with build-id 33391ff5d8b361d70dd5922e8d2b5c1b451401bb
                                                       Module libp11-kit.so.0 with build-id f97c44b297b54185bbe3eb6ed6dab5d8967f1532
                                                       Module libcrypto.so.1.1 with build-id 4c926b672d97886b123e03a008387aecf0786de4
                                                       Module libm.so.6 with build-id 2b8fd1f869ecab4e0b55e92f2f151897f6818acf
                                                       Module libnss_systemd.so.2 with build-id 862c14d40ed4000ef1e3e08c3001b259f2fe8e15
                                                       Module libnss_files.so.2 with build-id 1a36dfc01d3a1010b2ee79766a24a8090a3266d5
                                                       Module libblkid.so.1 with build-id f03a24e92c9852272bd0049b5bcb7ed6cf0e664f
                                                       Module libdl.so.2 with build-id 5abc547e7b0949f89f3c0e21ab0c8331a7440a8a
                                                       Module libgpg-error.so.0 with build-id 3801187d42c4955bd93c605451430cdf1b164e63
                                                       Module libcrypt.so.2 with build-id 93cf352934d276e01cdfac28f6d6304bf0ed817c
                                                       Module libresolv.so.2 with build-id c915c72668282861a813f7ea3c0780f37b681dc0
                                                       Module libmount.so.1 with build-id ff9a1d99d35cf640d0bfdaba294854372672c29b
                                                       Module libz.so.1 with build-id 0c1459c56513efd5d53eb3868290e9afee6a6a26
                                                       Module libgmodule-2.0.so.0 with build-id 34cabbd12d9baf397a0255f174e4c96165bc329b
                                                       Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
                                                       Module libffi.so.8 with build-id f90d8b734f6de9b25faedb8cbfab7054dafc0a42
                                                       Module ld-linux-x86-64.so.2 with build-id 040cc3dd10461562f177df39e3be2f3704258c3c
                                                       Module libpthread.so.0 with build-id 07c8f95b4f3251d08550217ad8a1f31066229996
                                                       Module libgcc_s.so.1 with build-id 7f8508bb914546ada778809b64b99d234337d835
                                                       Module libgcrypt.so.20 with build-id db45f5d5e0f7af1e77324fea1885f974619ad268
                                                       Module libcap.so.2 with build-id f56c6cd6ad4d35053340d7ff2f8f954498796739
                                                       Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
                                                       Module libzstd.so.1 with build-id 6214183688018e3fba6d66db10c2c8d0b45e0578
                                                       Module liblzma.so.5 with build-id 8b615460aa230708c5183f16bede67aa0437d95e
                                                       Module librt.so.1 with build-id 75484da2d6f1515189eefa076e0a40328834cd16
                                                       Module libc.so.6 with build-id 4b406737057708c0e4c642345a703c47a61c73dc
                                                       Module libXdmcp.so.6 with build-id 8ca0792d23c8b8b4c0864297512349292bea5955
                                                       Module libxcb.so.1 with build-id 0d1ef11740a5daad2ee331e812a51aa6574af222
                                                       Module libXau.so.6 with build-id 1c67764663e07bec24d8951e5fd93f4d165979ff
                                                       Module libaccountsservice.so.0 with build-id 5bfca519b352299477ede946dd43ef190721bab7
                                                       Module libgio-2.0.so.0 with build-id fc7ccd9c7c26cbb1e938b1c0879f078c2f47d803
                                                       Module libglib-2.0.so.0 with build-id 8214b56e554b7cbead4034b6ba32c90bc8c674da
                                                       Module libgobject-2.0.so.0 with build-id 3e451709a0a5772b9550d3a4c28dcb37a87028fa
                                                       Module libsystemd.so.0 with build-id 5e0c342d74b444cce6793925b41760cf298c417c
                                                       Module gdm with build-id 262a90343fa1c4c4cb83374cf2d14ba1c4c68bb0
                                                       Stack trace of thread 1285:
                                                       #0  0x0000559d1043f94c n/a (gdm + 0x2094c)
                                                       #1  0x0000559d1044059d n/a (gdm + 0x2159d)
                                                       #2  0x00007f1881975d8f g_closure_invoke (libgobject-2.0.so.0 + 0x12d8f)
                                                       #3  0x00007f1881991718 n/a (libgobject-2.0.so.0 + 0x2e718)
                                                       #4  0x00007f1881992dd9 g_signal_emit_valist (libgobject-2.0.so.0 + 0x2fdd9)
                                                       #5  0x00007f1881993330 g_signal_emit (libgobject-2.0.so.0 + 0x30330)
                                                       #6  0x00007f188197d266 n/a (libgobject-2.0.so.0 + 0x1a266)
                                                       #7  0x00007f1881985052 g_object_notify (libgobject-2.0.so.0 + 0x22052)
                                                       #8  0x0000559d1043bbe8 n/a (gdm + 0x1cbe8)
                                                       #9  0x00007f1881975d8f g_closure_invoke (libgobject-2.0.so.0 + 0x12d8f)
                                                       #10 0x00007f1881991718 n/a (libgobject-2.0.so.0 + 0x2e718)
                                                       #11 0x00007f1881992dd9 g_signal_emit_valist (libgobject-2.0.so.0 + 0x2fdd9)
                                                       #12 0x00007f1881993330 g_signal_emit (libgobject-2.0.so.0 + 0x30330)
                                                       #13 0x00007f1881161d4a n/a (libffi.so.8 + 0x6d4a)
                                                       #14 0x00007f1881161267 n/a (libffi.so.8 + 0x6267)
                                                       #15 0x00007f188197bb2e g_cclosure_marshal_generic (libgobject-2.0.so.0 + 0x18b2e)
                                                       #16 0x00007f1881975d8f g_closure_invoke (libgobject-2.0.so.0 + 0x12d8f)
                                                       #17 0x00007f1881991718 n/a (libgobject-2.0.so.0 + 0x2e718)
                                                       #18 0x0000559d10436bc4 n/a (gdm + 0x17bc4)
                                                       #19 0x00007f1881975d8f g_closure_invoke (libgobject-2.0.so.0 + 0x12d8f)
                                                       #20 0x00007f18819910ee n/a (libgobject-2.0.so.0 + 0x2e0ee)
                                                       #21 0x00007f1881992dd9 g_signal_emit_valist (libgobject-2.0.so.0 + 0x2fdd9)
                                                       #22 0x00007f1881993330 g_signal_emit (libgobject-2.0.so.0 + 0x30330)
                                                       #23 0x00007f1881773625 n/a (libgio-2.0.so.0 + 0x106625)
                                                       #24 0x00007f18817604b4 n/a (libgio-2.0.so.0 + 0xf34b4)
                                                       #25 0x00007f1881881435 g_main_context_dispatch (libglib-2.0.so.0 + 0x54435)
                                                       #26 0x00007f18818d57b9 n/a (libglib-2.0.so.0 + 0xa87b9)
                                                       #27 0x00007f1881880ab3 g_main_loop_run (libglib-2.0.so.0 + 0x53ab3)
                                                       #28 0x0000559d1042d4fd n/a (gdm + 0xe4fd)
                                                       #29 0x00007f1881442b25 __libc_start_main (libc.so.6 + 0x27b25)
                                                       #30 0x0000559d1042d81e n/a (gdm + 0xe81e)
                                                       Stack trace of thread 1290:
                                                       #0  0x00007f188151418d syscall (libc.so.6 + 0xf918d)
                                                       #1  0x00007f18818cfbdb g_cond_wait_until (libglib-2.0.so.0 + 0xa2bdb)
                                                       #2  0x00007f18818507d3 n/a (libglib-2.0.so.0 + 0x237d3)
                                                       #3  0x00007f1881850964 g_async_queue_timeout_pop (libglib-2.0.so.0 + 0x23964)
                                                       #4  0x00007f18818b29da n/a (libglib-2.0.so.0 + 0x859da)
                                                       #5  0x00007f18818afd51 n/a (libglib-2.0.so.0 + 0x82d51)
                                                       #6  0x00007f1881170259 start_thread (libpthread.so.0 + 0x9259)
                                                       #7  0x00007f18815195e3 __clone (libc.so.6 + 0xfe5e3)
                                                       Stack trace of thread 1287:
                                                       #0  0x00007f188150eb2f __poll (libc.so.6 + 0xf3b2f)
                                                       #1  0x00007f18818d5749 n/a (libglib-2.0.so.0 + 0xa8749)
                                                       #2  0x00007f1881880ab3 g_main_loop_run (libglib-2.0.so.0 + 0x53ab3)
                                                       #3  0x00007f1881770598 n/a (libgio-2.0.so.0 + 0x103598)
                                                       #4  0x00007f18818afd51 n/a (libglib-2.0.so.0 + 0x82d51)
                                                       #5  0x00007f1881170259 start_thread (libpthread.so.0 + 0x9259)
                                                       #6  0x00007f18815195e3 __clone (libc.so.6 + 0xfe5e3)
                                                       Stack trace of thread 1286:
                                                       #2  0x00007f188187ec11 g_main_context_iteration (libglib-2.0.so.0 + 0x51c11)
                                                       #3  0x00007f188187ec62 n/a (libglib-2.0.so.0 + 0x51c62)
jan 08 21:09:05 Manjaro-laptop systemd[1]: gdm.service: Main process exited, code=dumped, status=11/SEGV
jan 08 21:09:05 Manjaro-laptop kernel: kauditd_printk_skb: 111 callbacks suppressed
jan 08 21:09:05 Manjaro-laptop kernel: audit: type=1131 audit(1641672545.382:239): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@6-1319-0 comm="systemd" exe="/usr/lib/sy>
jan 08 21:09:05 Manjaro-laptop kernel: audit: type=1131 audit(1641672545.385:240): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=gdm comm="systemd" exe="/usr/lib/systemd/systemd" hostnam>
jan 08 21:09:05 Manjaro-laptop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@6-1319-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? add>
jan 08 21:09:05 Manjaro-laptop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=gdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=fai>
jan 08 21:09:05 Manjaro-laptop systemd[1]: gdm.service: Killing process 1288 (gdm-session-wor) with signal SIGKILL.
jan 08 21:09:05 Manjaro-laptop systemd[1]: gdm.service: Killing process 1294 (gnome-keyring-d) with signal SIGKILL.
jan 08 21:09:05 Manjaro-laptop systemd[1]: gdm.service: Killing process 1295 (gmain) with signal SIGKILL.
jan 08 21:09:05 Manjaro-laptop systemd[1]: gdm.service: Killing process 1296 (gdbus) with signal SIGKILL.
jan 08 21:09:05 Manjaro-laptop systemd[1]: systemd-coredump@6-1319-0.service: Deactivated successfully.
jan 08 21:09:05 Manjaro-laptop systemd[1]: gdm.service: Failed with result 'core-dump'.
jan 08 21:09:05 Manjaro-laptop audit: BPF prog-id=0 op=UNLOAD
jan 08 21:09:05 Manjaro-laptop kernel: audit: type=1334 audit(1641672545.485:241): prog-id=0 op=UNLOAD
jan 08 21:09:05 Manjaro-laptop kernel: audit: type=1334 audit(1641672545.485:242): prog-id=0 op=UNLOAD
jan 08 21:09:05 Manjaro-laptop kernel: audit: type=1334 audit(1641672545.485:243): prog-id=0 op=UNLOAD
jan 08 21:09:05 Manjaro-laptop systemd[1]: gdm.service: Scheduled restart job, restart counter is at 7.
jan 08 21:09:05 Manjaro-laptop systemd[1]: Stopped GNOME Display Manager.
Crash report
[🡕] Process 1242 (gdm) of user 0 dumped core.
                                                       Stack trace of thread 1242:
                                                       #0  0x000056508c82c94c n/a (gdm + 0x2094c)
                                                       #1  0x000056508c82d59d n/a (gdm + 0x2159d)
                                                       #2  0x00007f2e0ac9bd8f g_closure_invoke (libgobject-2.0.so.0 + 0x12d8f)
                                                       #3  0x00007f2e0acb7718 n/a (libgobject-2.0.so.0 + 0x2e718)
                                                       #4  0x00007f2e0acb8dd9 g_signal_emit_valist (libgobject-2.0.so.0 + 0x2fdd9)
                                                       #5  0x00007f2e0acb9330 g_signal_emit (libgobject-2.0.so.0 + 0x30330)
                                                       #6  0x00007f2e0aca3266 n/a (libgobject-2.0.so.0 + 0x1a266)
                                                       #7  0x00007f2e0acab052 g_object_notify (libgobject-2.0.so.0 + 0x22052)
                                                       #8  0x000056508c828be8 n/a (gdm + 0x1cbe8)
                                                       #9  0x00007f2e0ac9bd8f g_closure_invoke (libgobject-2.0.so.0 + 0x12d8f)
                                                       #10 0x00007f2e0acb7718 n/a (libgobject-2.0.so.0 + 0x2e718)
                                                       #11 0x00007f2e0acb8dd9 g_signal_emit_valist (libgobject-2.0.so.0 + 0x2fdd9)
                                                       #12 0x00007f2e0acb9330 g_signal_emit (libgobject-2.0.so.0 + 0x30330)
                                                       #13 0x00007f2e0a487d4a n/a (libffi.so.8 + 0x6d4a)
                                                       #14 0x00007f2e0a487267 n/a (libffi.so.8 + 0x6267)
                                                       #15 0x00007f2e0aca1b2e g_cclosure_marshal_generic (libgobject-2.0.so.0 + 0x18b2e)
                                                       #16 0x00007f2e0ac9bd8f g_closure_invoke (libgobject-2.0.so.0 + 0x12d8f)
                                                       #17 0x00007f2e0acb7718 n/a (libgobject-2.0.so.0 + 0x2e718)
                                                       #18 0x000056508c823bc4 n/a (gdm + 0x17bc4)
                                                       #19 0x00007f2e0ac9bd8f g_closure_invoke (libgobject-2.0.so.0 + 0x12d8f)
                                                       #20 0x00007f2e0acb70ee n/a (libgobject-2.0.so.0 + 0x2e0ee)
                                                       #21 0x00007f2e0acb8dd9 g_signal_emit_valist (libgobject-2.0.so.0 + 0x2fdd9)
                                                       #22 0x00007f2e0acb9330 g_signal_emit (libgobject-2.0.so.0 + 0x30330)
                                                       #23 0x00007f2e0aa99625 n/a (libgio-2.0.so.0 + 0x106625)
                                                       #24 0x00007f2e0aa864b4 n/a (libgio-2.0.so.0 + 0xf34b4)
                                                       #25 0x00007f2e0aba7435 g_main_context_dispatch (libglib-2.0.so.0 + 0x54435)
                                                       #26 0x00007f2e0abfb7b9 n/a (libglib-2.0.so.0 + 0xa87b9)
                                                       #27 0x00007f2e0aba6ab3 g_main_loop_run (libglib-2.0.so.0 + 0x53ab3)
                                                       #28 0x000056508c81a4fd n/a (gdm + 0xe4fd)
                                                       #29 0x00007f2e0a768b25 __libc_start_main (libc.so.6 + 0x27b25)
                                                       #30 0x000056508c81a81e n/a (gdm + 0xe81e)
                                                       Stack trace of thread 1243:
                                                       #0  0x00007f2e0a834b2f __poll (libc.so.6 + 0xf3b2f)
                                                       #1  0x00007f2e0abfb749 n/a (libglib-2.0.so.0 + 0xa8749)
                                                       #2  0x00007f2e0aba4c11 g_main_context_iteration (libglib-2.0.so.0 + 0x51c11)
                                                       #3  0x00007f2e0aba4c62 n/a (libglib-2.0.so.0 + 0x51c62)
                                                       #4  0x00007f2e0abd5d51 n/a (libglib-2.0.so.0 + 0x82d51)
                                                       #5  0x00007f2e0a496259 start_thread (libpthread.so.0 + 0x9259)
                                                       #6  0x00007f2e0a83f5e3 __clone (libc.so.6 + 0xfe5e3)
                                                       Stack trace of thread 1244:
                                                       #2  0x00007f2e0aba6ab3 g_main_loop_run (libglib-2.0.so.0 + 0x53ab3)
                                                       #3  0x00007f2e0aa96598 n/a (libgio-2.0.so.0 + 0x103598)
                                                       Stack trace of thread 1247:
                                                       #0  0x00007f2e0a83a18d syscall (libc.so.6 + 0xf918d)
                                                       #1  0x00007f2e0abf5bdb g_cond_wait_until (libglib-2.0.so.0 + 0xa2bdb)
                                                       #2  0x00007f2e0ab767d3 n/a (libglib-2.0.so.0 + 0x237d3)
                                                       #3  0x00007f2e0ab76964 g_async_queue_timeout_pop (libglib-2.0.so.0 + 0x23964)
                                                       #4  0x00007f2e0abd89da n/a (libglib-2.0.so.0 + 0x859da)
                                                       #5  0x00007f2e0abd5d51 n/a (libglib-2.0.so.0 + 0x82d51)
                                                       #6  0x00007f2e0a496259 start_thread (libpthread.so.0 + 0x9259)
                                                       #7  0x00007f2e0a83f5e3 __clone (libc.so.6 + 0xfe5e3)
Help with reinstalling
Because I restored everything in my home-folder after the installation, I think I may have overwritten some configurations that are required for it to properly work. That is why I would like to cleanly reinstall Wayland, its dependencies, and packages depending on it, to see whether that fixes the problem.
The problem here is that I don’t know the exact command I could use for this and couldn’t find it on Google. If you know how to do this and have an idea on whether it might help, please let me know.
Help debugging
If you have an idea of what might be going on and how I can fix it, any help is welcome. It is a recent restore, so worst case I could cleanly reinstall Manjaro again, but I would like to prevent that, as I think the problem would return once I restore my back-up.
inxi -Fxzc0
  Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    Desktop: GNOME 41.2 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: TOSHIBA product: SATELLITE P50-C v: PSPTSE-00Q003DU
    serial: <superuser required>
  Mobo: FF50 model: 06F2 v: Type2 - Board Version
    serial: <superuser required> UEFI: INSYDE v: 5.10 date: 09/11/2015
  ID-1: BAT1 charge: 19.4 Wh (60.1%) condition: 32.3/31.7 Wh (102.0%)
    volts: 14.7 min: 14.4 model: SDI PA5185U-1BRS status: Discharging
  Info: dual core model: Intel Core i7-5500U bits: 64 type: MT MCP
    arch: Broadwell rev: 4 cache: L1: 128 KiB L2: 512 KiB L3: 4 MiB
  Speed (MHz): avg: 2371 high: 2395 min/max: 500/3000 cores: 1: 2301
    2: 2395 3: 2394 4: 2395 bogomips: 19160
  Device-1: Intel HD Graphics 5500 vendor: Toshiba driver: i915 v: kernel
    bus-ID: 00:02.0
  Device-2: NVIDIA GM108M [GeForce 930M] vendor: Toshiba driver: nvidia
    v: 495.44 bus-ID: 09:00.0
  Device-3: Chicony TOSHIBA Web Camera - HD type: USB driver: uvcvideo
    bus-ID: 2-7:3
  Display: x11 server: X.org 1.21.1.2 driver: loaded: modesetting,nvidia
    unloaded: nouveau resolution: <missing: xdpyinfo>
  OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2)
    v: 4.6 Mesa 21.3.2 direct render: Yes
  Device-1: Intel Broadwell-U Audio vendor: Toshiba driver: snd_hda_intel
    v: kernel bus-ID: 00:03.0
  Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Toshiba
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
  Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
  Sound Server-3: PulseAudio v: 15.0 running: no
  Sound Server-4: PipeWire v: 0.3.42 running: yes
  Device-1: Intel Wireless 3160 driver: iwlwifi v: kernel bus-ID: 07:00.0
  IF: wlp7s0 state: up mac: <filter>
    vendor: Toshiba driver: r8169 v: kernel port: 4000 bus-ID: 08:00.0
  IF: enp8s0 state: down mac: <filter>
  IF-ID-1: nordlynx state: unknown speed: N/A duplex: N/A mac: N/A
  Local Storage: total: 931.51 GiB used: 343.64 GiB (36.9%)
  ID-1: /dev/sda vendor: Samsung model: SSD 870 EVO 1TB size: 931.51 GiB
  ID-1: / size: 906.86 GiB used: 343.64 GiB (37.9%) fs: ext4 dev: /dev/dm-0
    mapped: luks-81065014-05ba-4060-97a1-8628508d1051
  ID-2: /boot/efi size: 299.4 MiB used: 440 KiB (0.1%) fs: vfat
    dev: /dev/sda1
  ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
    dev: /dev/dm-1 mapped: luks-57e2258a-174c-4859-86d7-be4da642ea45
  System Temperatures: cpu: 48.0 C mobo: N/A
  Processes: 244 Uptime: 59m Memory: 7.68 GiB used: 2.68 GiB (34.9%)
  Init: systemd Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1438
  Shell: Zsh v: 5.8 inxi: 3.3.11
If nothing else, a push in the right direction might be all I need to fix it, but currently I’m stuck and have no idea on how to fix it.
Make sure you only restore your actual data - not the config files
→ hidden files and directories, all starting with a . (a dot)
Exceptions are (not an exhaustive list):
~/.mozilla
~/.thunderbird
~/.config/chromium
~/.config/google-chrome
almost everything else might cause problems in a fresh installation with different default config or different desktop environment
permissions (differences in user/group between new and backup) might also be an issue, depending on how you restored your data
First, after a fresh install, boot and use the default config.
When it works - restore your data to it
but don’t overwrite the config files in the process …
Thanks for your help! I ended up freshly installing and hand-picking the .config files. If I didn’t know what something did, I didn’t copy it. Everything seems to work now.
There are still some glitches and artifacts at boot, but it is already working way better than before. Thanks again.
