Crash with nvidia proprietary driver, but mouse moves
I did a fresh install yesterday (May 14, 2024), and everything went fine with nouveau. But if I install proprietary nvidia drivers (or hybrid), the system constantly crashes either during boot, on the login screen or soon after login. In the last two cases, the mouse still moves on screen, but nothing else responds.
I have no idea how to fix this. For now I can only use my notebook with nouveau. I appreciate any help because I need CUDA working on this notebook.
My notebook is a Dell G15 5030 with intel i7-13650HX and dual VGA:
00:02.0 VGA compatible controller [0300]: Intel Corporation Raptor Lake-S UHD Graphics [8086:a78b] (rev 04)
	Subsystem: Dell Device [1028:0bf8]
	Kernel driver in use: i915
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GN20-P0-R-K2 [GeForce RTX 3050 6GB Laptop GPU] [10de:25ec] (rev a1)
	Kernel driver in use: nouveau
Here’s the output of inxi -G:
  Device-1: Intel Raptor Lake-S UHD Graphics driver: i915 v: kernel
  Device-2: NVIDIA GN20-P0-R-K2 [GeForce RTX 3050 6GB Laptop GPU]
    driver: nouveau v: kernel
  Device-3: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB
  Display: x11 server: X.org v: 1.21.1.13 with: Xwayland v: 23.2.6 driver:
    X: loaded: modesetting dri: iris,nouveau gpu: i915,nouveau resolution:
    1: 1920x1080~60Hz 2: 1920x1080~120Hz
  API: EGL v: 1.5 drivers: iris,nouveau,swrast
  API: OpenGL v: 4.6 compat-v: 4.3 vendor: intel mesa v: 24.0.6-manjaro1.1
    renderer: Mesa Intel Graphics (RPL-S)
to force the reinstallation of the propietary driver use
sudo mhwd -f -i pci video-hybrid-intel-nvidia-prime
and btw. please post the full output of the inxi, without proper information what gui (plasma,gnome etc… ) and all the other informations it’s impossible to give assistance and help.
post the full output, use minimum
or
inxi --admin --verbosity=8 --filter --no-host --width
it will filter all privacy informations and gives an overview
I already tried this force reinstall. It does not solve the problem. If I use the proprietary driver, I get crashes.
But I’ll try again now just to be sure. I’ll reply again in a few of minutes.
I just tried the video-hybrid-intel-nvidia-prime again, and it crashed after reboot during the boot first, and on a second try it crashed after login.
Now I removed the proprietary driver and I’m back on nouveau.
Here’s the output of inxi --admin --verbosity=8 --filter --no-host --width:
  Kernel: 6.9.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
    root=UUID=fb417ba2-edd2-4c62-8a32-a7434ad25f2a rw quiet splash
    resume=UUID=091786d3-4e6b-494c-993e-149cdfdc19f3 udev.log_priority=3
  Desktop: GNOME v: 46.1 tk: GTK v: 3.24.41 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 46.0 Distro: Manjaro base: Arch Linux
  Type: Laptop System: Dell product: Dell G15 5530 v: N/A
  Mobo: Dell model: 0RKFTM v: A00 serial: <superuser required> part-nu: 0BF8
    uuid: <superuser required> UEFI: Dell v: 1.14.0 date: 03/19/2024
  ID-1: BAT0 charge: 49.1 Wh (100.0%) condition: 49.1/54.9 Wh (89.4%)
    volts: 12.7 min: 11.4 model: BYD DELL DVG8M34 type: Li-poly serial: <filter>
    status: not charging cycles: 13
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
    status: discharging
  System RAM: total: 16 GiB available: 15.31 GiB used: 3.07 GiB (20.0%)
  Device-1: DIMM A type: DDR5 detail: synchronous size: 8 GiB
    speed: 4800 MT/s volts: curr: 1 width (bits): data: 64 total: 64
    manufacturer: 80AD000080AD part-no: HMCG66AEBSA092N serial: <filter>
  Device-2: DIMM B type: DDR5 detail: synchronous size: 8 GiB
  Info: model: 13th Gen Intel Core i7-13650HX bits: 64 type: MST AMCP
    arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
    process: Intel 7 (10nm) family: 6 model-id: 0xB7 (183) stepping: 1
    microcode: 0x123
  Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
    cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
    L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 844 high: 1147 min/max: 800/4700:4900:3600 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
    5: 800 6: 919 7: 800 8: 800 9: 1086 10: 800 11: 800 12: 800 13: 800 14: 800
    15: 800 16: 800 17: 800 18: 1147 19: 800 20: 939 bogomips: 112160
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb pebs
    pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good
    sdbg sep serialize sha_ni smap smep split_lock_detect ss ssbd sse sse2
    tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
    vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves
    xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Raptor Lake-S UHD Graphics vendor: Dell driver: i915
    v: kernel alternate: xe arch: Gen-13 process: Intel 7 (10nm) built: 2022+
    ports: active: eDP-1 empty: DP-1 bus-ID: 00:02.0 chip-ID: 8086:a78b
    class-ID: 0300
    vendor: Dell driver: nouveau v: kernel non-free: 550.xx+ status: current (as
    of 2024-04; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
    built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 empty: none
    bus-ID: 01:00.0 chip-ID: 10de:25ec class-ID: 0300
  Device-3: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 0bda:567e
    compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris,nouveau gpu: i915,nouveau display-ID: :1 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-size: <missing: xdpyinfo>
  Monitor-1: HDMI-A-1 mapped: HDMI-1-1 pos: primary,right model: LG
    (GoldStar) IPS FULLHD built: 2016 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
    chroma: red: x: 0.647 y: 0.333 green: x: 0.306 y: 0.631 blue: x: 0.149
    y: 0.047 white: x: 0.314 y: 0.329 size: 480x270mm (18.9x10.63")
    diag: 551mm (21.7") ratio: 16:9 modes: 1920x1080, 1680x1050, 1400x1050,
    1600x900, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768,
    800x600, 720x576, 720x480, 640x480, 720x400
  Monitor-2: eDP-1 pos: left model: ChiMei InnoLux 0x1522 built: 2020
    res: 1920x1080 hz: 120 dpi: 142 gamma: 1.2 chroma: red: x: 0.592 y: 0.349
    green: x: 0.329 y: 0.557 blue: x: 0.153 y: 0.118 white: x: 0.314 y: 0.329
    size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
    modes: 1920x1080
  EDID-Warnings: 1: parse_edid: unknown flag 0 2: parse_edid: unknown tag 112
  API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau platforms:
    device: 0 drv: iris device: 1 drv: nouveau device: 2 drv: swrast gbm:
    drv: nouveau surfaceless: drv: iris x11: drv: iris inactive: wayland
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-S)
    device-ID: 8086:a78b memory: 14.95 GiB unified: yes
  Device-1: Intel Raptor Lake High Definition Audio vendor: Dell
    driver: sof-audio-pci-intel-tgl alternate: snd_hda_intel, snd_soc_avs,
    snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7a50 class-ID: 0401
  Device-2: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
  API: ALSA v: k6.9.0-1-MANJARO status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
    status: active 2: wireplumber status: active tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Intel Raptor Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:7a70 class-ID: 0280
  IP v4: <filter> type: dynamic scope: global broadcast: <filter>
    vendor: Dell driver: r8168 v: 8.053.00-NAPI modules: r8169 pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168
    class-ID: 0200
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4 chip-ID: 8087:0026
    class-ID: e001
  Local Storage: total: 491.35 GiB used: 146.68 GiB (29.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA
    model: KBG50ZNS512G NVMe 512GB size: 476.94 GiB block-size: physical: 512 B
    fw-rev: 11200108 temp: 47.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: DataTraveler 3.0
    size: 14.41 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.1
    spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    scheme: MBR
  ID-1: / raw-size: 459.8 GiB size: 451.51 GiB (98.20%)
    used: 146.68 GiB (32.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: fb417ba2-edd2-4c62-8a32-a7434ad25f2a
    used: 316 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 57D4-0413
  ID-1: swap-1 type: partition size: 16.84 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: 091786d3-4e6b-494c-993e-149cdfdc19f3
  ID-1: /dev/sda1 maj-min: 8:1 size: 2.63 GiB fs: iso9660
  ID-2: /dev/sda2 maj-min: 8:2 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: 7250-44F0
  Device-1: 1-3:2 info: Realtek Integrated_Webcam_HD type: video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 0bda:567e class-ID: 0e02 serial: <filter>
  Device-2: 1-10:3 info: Logitech Unifying Receiver type: keyboard,mouse
    driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c534 class-ID: 0301
  Device-3: 1-14:4 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0026 class-ID: e001
  Hub-2: 2-0:1 info: super-speed hub ports: 9 rev: 3.1
  Device-1: 2-1:2 info: Kingston DataTraveler 100 G3/G4/SE9 G2/50 Kyson
    type: mass storage driver: usb-storage interfaces: 1 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 296mA
    chip-ID: 0951:1666 class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 64.0 C mobo: 56.0 C sodimm: SODIMM C
  Fan Speeds (rpm): cpu: 403 fan-2: 412
  Packages: pm: pacman pkgs: 1307 libs: 474 tools: gnome-software,pamac
    1: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 422
  1: cpu: 16.9% command: tilix pid: 3159 mem: 78.4 MiB (0.5%)
  2: cpu: 10.7% command: chrome pid: 2250 mem: 250.5 MiB (1.5%)
  3: cpu: 8.8% command: insync pid: 1522 mem: 315.7 MiB (2.0%)
  4: cpu: 7.8% command: zsh pid: 3170 mem: 9.47 MiB (0.0%)
  5: cpu: 5.4% command: chrome pid: 2405 mem: 283.7 MiB (1.8%)
  Memory top: 5 of 422
  1: mem: 316.6 MiB (2.0%) command: chrome pid: 2099 cpu: 5.2%
  2: mem: 315.7 MiB (2.0%) command: insync pid: 1522 cpu: 8.8%
  3: mem: 283.7 MiB (1.8%) command: chrome pid: 2405 cpu: 5.4%
  4: mem: 250.5 MiB (1.5%) command: chrome pid: 2250 cpu: 10.7%
  5: mem: 242.1 MiB (1.5%) command: gnome-shell pid: 1369 cpu: 3.9%
  Processes: 422 Power: uptime: 4m states: freeze,mem,disk suspend: s2idle
    image: 6.09 GiB services: gsd-power,upowerd Init: systemd v: 255
  Compilers: gcc: 13.2.1 Shell: Zsh v: 5.9 running-in: tilix inxi: 3.3.34
I’ve also tested with video-nvidia instead of video-hybrid-intel-nvidia-prime and I get the same result… it crashes during boot, login screen or soon after login, but the mouse still moves.
i’m on plasma not on gnome but i think i know why it crashes. it’s not the installation of the driver but gnome want’s to use wayland instead of x11 as default and that doesn’t end up well. check how to install and use x11 on gnome. that should do the job.
But I am using X11…
$ echo $XDG_SESSION_TYPE
x11
And on /etc/gdm/custom.conf I use WaylandEnable=false.
okay let’s try something. install envycontrol first
pamac install envycontrol
open a console and force reinstallation of the propietary driver first
after installation run
sudo envycontrol -s nvidia
and reboot
keep in mind that envycontrol has much more options as choosing the displaymanager etc…
run
envycontrol
shows all options but fingers crossed switching simply to nvidia with envycontrol will do the job
It didn’t work… it crashed soon after the login. I’m back on nouveau.
It’s getting late here and I have to work early tomorrow. I’ll continue tomorrow, thanks for the help for now!
Tomorrow I’ll switch back to wayland and try the proprietary drivers with wayland again. I’m almost sure I’ve already tried this, but I’m getting crazy here… so let’s test again to be sure.
Indeed, even the live USB failed with proprietary drivers and I had to install using nouveau.
Let me know if I should post some log output here.
I’ve just found these discussion now. The issue seems to match mine and it is the same video card that I have here.
I’ll try the solution from there later today (now I’m working). The solution there by @brahma was:
and add this ibt parameter:
nano /etc/default/grub
and inside this line: GRUB_CMDLINE_LINUX_DEFAULT inside the quotes add this parameter:
ibt=off
dont remove anything, just add it to existing parameters, save the file with ctrl+x , update grub:
update-grub
the ibt issue should have been already fixed upstream… you are using kernel 6.9 which have issues with nvidia, at least on the testing branch… there is an possible fix for it in the latest testing updates topic…
Thanks for the quick reply. Indeed the ibt=off option didn’t work. Just to register here, the problem persists with wayland, and on the iso/usb live boot with both gnome and kde versions.
If it is a problem with the 6.9 kernel, what should I do? Downgrade to 6.8? Or stick to nouveau for a while until this is fixed? Any idea how long would it take?
I’ve read the discussion there in the testing announcements (to use nvidia-drm.fbdev=1 and etc), and it also didn’t work for me.
I might try to downgrade the kernel later today.
Ok. I got curious and decided to stop working and keep testing it!
I’ve downgraded to kernel 6.8.9-3 and it seems to be working perfectly now!
Thanks for the help!
It actually crashed just now. I’ve been working for 5 hours with the proprietary drivers working fine, and suddenly that same crash again.
I’ll just go back to nouveau for a while and keep an eye on the testing/stable announcements.
In case it helps, here’s the journalctl output of the crash:
mai 16 16:19:52 tintin kernel: BUG: unable to handle page fault for address: ffffded6ad90a8c8
mai 16 16:19:52 tintin kernel: #PF: supervisor read access in kernel mode
mai 16 16:19:52 tintin kernel: #PF: error_code(0x0000) - not-present page
mai 16 16:19:52 tintin kernel: PGD 0 P4D 0
mai 16 16:19:52 tintin kernel: Oops: 0000 [#1] PREEMPT SMP NOPTI
mai 16 16:19:52 tintin kernel: CPU: 4 PID: 19843 Comm: kworker/4:1 Tainted: P           OE      6.8.9-3-MANJARO #1 3be51f845a62073e1c3cfb9ee30a81dc630dfb69
mai 16 16:19:52 tintin kernel: Hardware name: Dell Inc. Dell G15 5530/0RKFTM, BIOS 1.14.0 03/19/2024
mai 16 16:19:52 tintin kernel: Workqueue: kacpi_notify acpi_os_execute_deferred
mai 16 16:19:52 tintin kernel: RIP: 0010:kfree+0x70/0x2f0
mai 16 16:19:52 tintin kernel: Code: 80 48 01 d8 0f 82 84 02 00 00 48 c7 c2 00 00 00 80 48 2b 15 6a e9 54 01 48 01 d0 48 c1 e8 0c 48 c1 e0 06 48 03 05 48 e9 54 01 <>
mai 16 16:19:52 tintin kernel: RSP: 0018:ffffb915242a3c50 EFLAGS: 00010286
mai 16 16:19:52 tintin kernel: RAX: ffffded6ad90a8c0 RBX: ffffb915242a3d68 RCX: ffff930af73a2ec0
mai 16 16:19:52 tintin kernel: RDX: 00006cf5c0000000 RSI: ffffffffc1aa1d2d RDI: ffffb915242a3d68
mai 16 16:19:52 tintin kernel: RBP: ffffb915242a3c88 R08: ffff930af73a2eb4 R09: 0000000000000000
mai 16 16:19:52 tintin kernel: R10: 00000000000000b5 R11: 0000000000000000 R12: 0000000000000000
mai 16 16:19:52 tintin kernel: R13: ffffffffc26c44c0 R14: ffff930af8c20020 R15: ffff930af73a2ea8
mai 16 16:19:52 tintin kernel: FS:  0000000000000000(0000) GS:ffff930e3f300000(0000) knlGS:0000000000000000
mai 16 16:19:52 tintin kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
mai 16 16:19:52 tintin kernel: CR2: ffffded6ad90a8c8 CR3: 0000000279a20000 CR4: 0000000000f50ef0
mai 16 16:19:52 tintin kernel: PKRU: 55555554
mai 16 16:19:52 tintin kernel: Call Trace:
mai 16 16:19:52 tintin kernel:  <TASK>
mai 16 16:19:52 tintin kernel:  ? __die+0x23/0x70
mai 16 16:19:52 tintin kernel:  ? page_fault_oops+0x171/0x4e0
mai 16 16:19:52 tintin kernel:  ? exc_page_fault+0x175/0x180
mai 16 16:19:52 tintin kernel:  ? asm_exc_page_fault+0x26/0x30
mai 16 16:19:52 tintin kernel:  ? _nv047150rm+0x2d/0x50 [nvidia 6d98ea4ecba52b97318f3128281d2256db58ac66]
mai 16 16:19:52 tintin kernel:  ? kfree+0x70/0x2f0
mai 16 16:19:52 tintin kernel:  ? _nv026842rm+0x61/0x90 [nvidia 6d98ea4ecba52b97318f3128281d2256db58ac66]
mai 16 16:19:52 tintin kernel:  _nv047150rm+0x2d/0x50 [nvidia 6d98ea4ecba52b97318f3128281d2256db58ac66]
mai 16 16:19:52 tintin kernel:  _nv045170rm+0xee/0x1b0 [nvidia 6d98ea4ecba52b97318f3128281d2256db58ac66]
mai 16 16:19:52 tintin kernel:  _nv047127rm+0x374/0x410 [nvidia 6d98ea4ecba52b97318f3128281d2256db58ac66]
mai 16 16:19:52 tintin kernel:  _nv014160rm+0x3f1/0x690 [nvidia 6d98ea4ecba52b97318f3128281d2256db58ac66]
mai 16 16:19:52 tintin kernel:  _nv045309rm+0x26/0x30 [nvidia 6d98ea4ecba52b97318f3128281d2256db58ac66]
mai 16 16:19:52 tintin kernel:  rm_acpi_notify+0x123/0x280 [nvidia 6d98ea4ecba52b97318f3128281d2256db58ac66]
mai 16 16:19:52 tintin kernel:  ? notifier_call_chain+0x5a/0xd0
mai 16 16:19:52 tintin kernel:  acpi_ev_notify_dispatch+0x4b/0x70
mai 16 16:19:52 tintin kernel:  acpi_os_execute_deferred+0x17/0x30
mai 16 16:19:52 tintin kernel:  process_one_work+0x178/0x350
mai 16 16:19:52 tintin kernel:  worker_thread+0x30f/0x450
mai 16 16:19:52 tintin kernel:  ? __pfx_worker_thread+0x10/0x10
mai 16 16:19:52 tintin kernel:  kthread+0xe5/0x120
mai 16 16:19:52 tintin kernel:  ? __pfx_kthread+0x10/0x10
mai 16 16:19:52 tintin kernel:  ret_from_fork+0x31/0x50
mai 16 16:19:52 tintin kernel:  ret_from_fork_asm+0x1b/0x30
mai 16 16:19:52 tintin kernel:  </TASK>
mai 16 16:19:52 tintin kernel: Modules linked in: ppp_deflate bsd_comp ppp_async ppp_generic slhc tls btrfs blake2b_generic xor raid6_pq ufs hfsplus hfs minix msdos>
mai 16 16:19:52 tintin kernel:  polyval_clmulni polyval_generic snd_soc_core gf128mul ghash_clmulni_intel snd_compress sha512_ssse3 ac97_bus snd_hda_codec_hdmi sha2>
mai 16 16:19:52 tintin kernel:  processor_thermal_wt_req intel_lpss_pci intel_vsec intel_ish_ipc typec_ucsi i2c_i801 mtd snd processor_thermal_power_floor intel_lps>
mai 16 16:19:52 tintin kernel: ---[ end trace 0000000000000000 ]---
mai 16 16:19:52 tintin kernel: note: kworker/4:1[19843] exited with irqs disabled
Why not using LTS 6.6?
I’ll try tomorrow. I did a fresh install and it comes with 6.9. I got the problems and decided to try do downgrade one level back to 6.8. But, indeed, I should try the LTS version.
Up to now, everything seems to be holding fine on the kernel 6.6.
If I get a crash again, I’ll post here.
For now, thanks for the help!
