I have a weird crack/pop problem. Receiving a notification from Telegram, changing the system volume level or opening Kdenlive and keeping it in the background causes crackling.
inxi
Host: Kernel: 6.6.10-1-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 5.27.10 Distro: Manjaro Linux
Type: Desktop Mobo: Gigabyte model: G31M-S2L serial: <superuser required>
BIOS: Award v: F10f date: 06/01/2009
Info: quad core model: Intel Xeon E5450 bits: 64 type: MCP cache: L2: 12 MiB
Speed (MHz): avg: 2400 min/max: 2400/3600 cores: 1: 2400 2: 2400 3: 2400
4: 2400
Device-1: Intel 82G33/G31 Express Integrated Graphics driver: i915 v: kernel
Display: x11 server: X.Org v: 21.1.10 driver: X: loaded: intel
unloaded: modesetting dri: i915 gpu: i915 resolution: 1920x1080~60Hz
API: EGL v: 1.4,1.5 drivers: i915,swrast platforms: x11,surfaceless,device
API: OpenGL v: 4.5 compat-v: 2.1 vendor: mesa v: 23.3.3-manjaro1.1
renderer: i915 (: G33)
Device-1: Intel NM10/ICH7 Family High Definition Audio driver: snd_hda_intel
API: ALSA v: k6.6.10-1-MANJARO status: kernel-api
Server-1: PipeWire v: 1.0.0 status: active
aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
lavrate
Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pipewire
PipeWire Sound Server
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PipeWire Media Server)
sysdefault:CARD=Intel
HDA Intel, ALC662 rev1 Analog
Default Audio Device
front:CARD=Intel,DEV=0
Front output / input
surround21:CARD=Intel,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Intel,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Intel,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Intel,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Intel,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Intel,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Intel,DEV=0
HDA Intel, ALC662 rev1 Digital
IEC958 (S/PDIF) Digital Audio Output
usbstream:CARD=Intel
HDA Intel
USB Stream Output
