Hi all! I brought my Dell XPS 9710 out of sleep last night and found the speakers were buzzing and crackling and giving just terrible garbage (no updates or anything; had recently restarted before putting the laptop to sleep, and everything was working fine).
Anyways, I tried the fix from t/buzzing-sound-random-crack-from-speakers/112208/22 (can’t insert links sorry =/) and it fixed the buzzing/crackling: but only for the right speaker. The left has remained unchanged. I’m on KDE, and in the audio menu in system settings when I test both speakers solo the right speaker is perfect and the left is garbage.
I also tried upgrading the kernel to 5.18 from 5.15 to no avail.
I also tried the switch to pipewire as described at t/popping-cracking-sound/114409 (still not allowed to insert links) and nothing changed.
I also already have the sof-firmware package installed.
Any ideas on what’s going on? I’d appreciate any help!
Here’s my inxi:
Kernel: 5.18.0-1-rt11-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-rt-x86_64
root=UUID=ec81e203-00a1-443e-99f5-a7b65b29c2f3 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: XPS 17 9710 v: N/A
Mobo: Dell model: 00D5DG v: A01 serial: <superuser required> UEFI: Dell
v: 1.10.0 date: 05/09/2022
ID-1: BAT0 charge: 32.0 Wh (35.8%) condition: 89.4/95.1 Wh (94.0%)
volts: 11.1 min: 11.4 model: BYD DELL F8CPG19 type: Li-poly serial: <filter>
status: discharging
Device-1: hidpp_battery_0
model: Logitech G305 Lightspeed Wireless Gaming Mouse serial: <filter>
charge: 10% (should be ignored) rechargeable: yes status: discharging
Info: model: 11th Gen Intel Core i9-11900H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 built: 2020 process: Intel 10nm family: 6
model-id: 0x8D (141) stepping: 1 microcode: 0x3E
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 10 MiB desc: 8x1.2 MiB
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1020 high: 2095 min/max: 800/4800:4900 scaling:
driver: intel_pstate governor: powersave cores: 1: 893 2: 1008 3: 932 4: 785
5: 801 6: 1224 7: 1012 8: 1041 9: 1222 10: 2095 11: 828 12: 998 13: 801
14: 819 15: 800 16: 1064 bogomips: 79872
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Dell driver: i915
v: kernel arch: Gen12.1 process: Intel 10nm built: 2020-21 ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0
chip-ID: 8086:9a60 class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Dell
driver: nvidia v: 515.48.07 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Ampere process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-11:4 chip-ID: 0c45:672e class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2400 s-dpi: 96 s-size: 1016x635mm (40.00x25.00")
s-diag: 1198mm (47.17")
Monitor-1: eDP-1 model: Sharp 0x1517 built: 2021 res: 3840x2400 hz: 60
dpi: 266 gamma: 1.2 size: 366x229mm (14.41x9.02") diag: 432mm (17")
ratio: 16:10 modes: 3840x2400
OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 22.1.1
direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: Dell
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:43c8 class-ID: 0401
Device-2: NVIDIA vendor: Dell driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
Sound Server-1: ALSA v: k5.18.0-1-rt11-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.0 running: no
Sound Server-4: PipeWire v: 0.3.52 running: yes
Device-1: Intel Tiger Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
bus-ID: 3-14:5 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 953.87 GiB used: 31.47 GiB (3.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA
model: KXG60ZNV1T02 NVMe 1024GB size: 953.87 GiB block-size: physical: 512 B
rev: 10604107 temp: 33.9 C scheme: GPT
ID-1: / raw-size: 341.8 GiB size: 335.36 GiB (98.12%) used: 31.38 GiB (9.4%)
fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
ID-2: /boot/efi raw-size: 200 MiB size: 196 MiB (98.00%)
used: 92 MiB (46.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 49.0 C mobo: N/A
Processes: 449 Uptime: 6m wakeups: 1906 Memory: 31.09 GiB
used: 4.51 GiB (14.5%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1220
lib: 331 flatpak: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.19
