Hello, I’m new to manjaro and to linux in general.
Running csgo from steam, the cpu usage on manjaro is at 9% and temps at ~56°C. On windows it goes to around 30% usage and 80-90°C. And hence the fps is very low. It seems like the cpu is not being pushed. I run csgo using the prime-run command to use the nvidia card. Cpu is i5-9300h. Graphics Driver: video-hybrid-intel-nvidia-455xx-prime
Okay so using gamemode from launch options, “gamemoderun %command%” doesn’t work with prime-run and hence the nvidia card is not used and the fps is further reduced.
Okay so It did work when I launch with “gamemoderun prime-run %command%” and it uses the nvidia card but the fps remained almost the same as before and maybe a little less
Here is what happened-
I launched using lutris. Doesn’t seems there’s any difference in fps if I launch from steam or lutris.
If I launch with “prime-run %command%” The game has like 70% of the fps as compared to windows But it fluctuates so much from 90 to 220.
If I launch with “gamemoderun prime-run %command%” The game has even lower average fps.
One thing I noticed is that after installing gamemode, the average fps went up a little and the cpu usage went to 11-13% and 70-80°C. This is while using only “prime-run %command%”.
I have tried Steam linux runtime, it results in a lower fps. Proton doesnt run for some reason, it asks me to update steam client when it is already updated.
Apparently “echo performance | sudo tee /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor” or “sudo cpupower frequency-set -g performance” does the job. Now the cpu is at 30% usage and goes upto 90°C. The fps is a bit low but better than before and the shuttering stopped.
