CPU/ GPU Lüfter ansteuern
Hallo zusammen,
wie kann ich von meinem Notebook die Lüfter ansteuern?
In Windows konnte ich die Prozentzahl der Lüfter einstellen. Wie geht dieses bei Manjaro? Gibt es ein Tool mit GUI?
  Kernel: 6.6.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=c3924f29-cb60-47b1-adf8-45fc71e8920d rw quiet splash apparmor=1
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
    with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: GIGABYTE product: G5 KC v: N/A
  Mobo: GIGABYTE model: G5 KC serial: <superuser required> part-nu: RC45KC
    uuid: <superuser required> UEFI: INSYDE v: FB08 date: 07/12/2022
  ID-1: BAT0 charge: 36.0 Wh (80.5%) condition: 44.7/47.2 Wh (94.7%)
    volts: 16.1 min: 14.4 model: Notebook BAT type: Li-ion serial: <filter>
    status: not charging
  Info: model: Intel Core i5-10500H bits: 64 type: MT MCP arch: Comet Lake
    gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
    model-id: 0xA5 (165) stepping: 2 microcode: 0xF8
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 2358 high: 2501 min/max: 800/4500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 2501 2: 2500 3: 800
    4: 2500 5: 2500 6: 2500 7: 2500 8: 2500 9: 2501 10: 2501 11: 2500 12: 2500
    bogomips: 60014
  Type: retbleed mitigation: Enhanced IBRS
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
    RSB filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: CLEVO/KAPOK
    ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:9bc4 class-ID: 0300
  Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
    vendor: CLEVO/KAPOK driver: nvidia v: 545.29.06 alternate: nouveau,nvidia_drm
    non-free: 545.xx+ status: current (as of 2024-01; EOL~2026-12-xx)
    arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
    gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
    active: none empty: DP-2,HDMI-A-2 bus-ID: 01:00.0 chip-ID: 10de:2520
    class-ID: 0300
  Device-3: Bison BisonCam NB Pro driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:3 chip-ID: 5986:9102
    class-ID: 0e02
  Display: x11 server: X.org v: 1.21.1.10 compositor: xfwm4 v: 4.18.0 driver:
    X: loaded: modesetting,nvidia dri: iris gpu: i915 display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 model: BOE Display 0x08b3 built: 2019 res: 1920x1080
    dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 398mm (15.7")
    ratio: 16:9 modes: 1920x1080
    drv: nvidia device: 1 drv: iris device: 3 drv: swrast surfaceless:
    drv: nvidia x11: drv: iris inactive: gbm,wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 23.3.3-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
    device-ID: 8086:9bc4 memory: 14.97 GiB unified: yes
  Device-1: Intel Comet Lake PCH cAVS vendor: CLEVO/KAPOK driver: snd_hda_intel
    chip-ID: 8086:06c8 class-ID: 0403
  Device-2: NVIDIA GA106 High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
  API: ALSA v: k6.6.10-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp7s0 state: up mac: <filter>
    vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 3000 bus-ID: 08:00.1 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp8s0f1 state: down mac: <filter>
  IF-ID-1: surfshark_ipv6 state: unknown speed: N/A duplex: N/A mac: <filter>
  IF-ID-2: surfshark_wg state: unknown speed: N/A duplex: N/A mac: N/A
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0029
    class-ID: e001
  Local Storage: total: 700.51 GiB used: 226.85 GiB (32.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Phison model: ESR512GTLCG-EAC-4
    lanes: 4 tech: SSD serial: <filter> fw-rev: ECFM13.3 temp: 25.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: A-Data model: SP550 size: 223.57 GiB
    block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: SSD
    serial: <filter> fw-rev: 5AB scheme: GPT
  ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
    used: 171.67 GiB (36.7%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 42.0 C pch: 62.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Memory: total: 16 GiB note: est. available: 15.32 GiB used: 4.25 GiB (27.8%)
  Processes: 360 Power: uptime: 7m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 0 hibernate: platform
    avail: shutdown,reboot,suspend,test_resume image: 6.12 GiB
    daemons: upowerd,xfce4-power-manager Init: systemd v: 255
  Packages: pm: pacman pkgs: 1131 libs: 347 tools: pamac pm: flatpak pkgs: 0
    Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Bash v: 5.2.21
    running-in: xfce4-terminal inxi: 3.3.32
https://wiki.archlinux.org/title/Fan_speed_control
Generell sollte das dein BIOS/UEFI übernehmen. Software-Lüfterregelung unter Linux ist nicht benutzerfreundlich, da es meist keine einheitliche Schnittstelle gibt und der Hersteller Software dafür anbietet, was generell für Windows ist.
Schau dir an, was @Mirdarthos verlinkt hat.
Das N/A (not available), würde ich mal tippen, dass der Lüfter von der Firmware gesteuert wird, auf Grund der Temperatur. Also direkte Steuerung ist nicht verfügbar.
Windows Software gibt es auch zum Lüftersteuerung.
Ist es nicht möglich unter Linux auch die Lüfter zu steuern? Ich würde gerne die Drehzahl der Lüfter ein wenig hochstellen .
Hast du schon mal in dein UEFI/BIOS geschaut, was da angeboten wird ?
Temperatursteuerung der Lüfter sollte unbedingt Hardwarenah erfolgen. Die Firmware (UEFI/BIOS) kann das besser als jedes Betriebssystem.
:footprints:
Das dachte ich mir…
Ja es ist möglich, siehe Link von @Mirdarthos . Aber es gibt da keine Patentlösung. Der Hersteller unterstützt nur Windows und unter Linux ist es dann ne Bastel- und Rateaufgabe, wie die Hersteller-Software jetzt den Lüfter kontrolliert.
Ganz generell: Geh in deine UEFI Einstellungen und stell es dort ein, wenn möglich.
Leider im BIOS nicht möglich den Lüfter einzustellen. Also muss ich das Software technisch machen.
Dann wünsche ich viel Erfolg. Sieht für mich danach aus, dass dieses “Control Center” entsprechende Treiber installiert, oder direkt auf die UEFI Einstellungen zugreift.
Hi again. Wie ich schon in Deinem letzten Post gesagt habe ist Dein Gigabyte ein Clevo Laptop. Die von den verschiedenen Marken angebotene ‘Control Center’ Software für Windows, wie z.B. das ‘Gigabyte Control Center’, gibt’s von Tuxedo auch für Linux und tuxedo-control-center ist in Manjaro’s offiziellen Repos.
Scheint für Gigabyte G5 zu funktionieren: Fans are set at the same speed (or the highest of all fan speeds) · Issue #222 · tuxedocomputers/tuxedo-control-center · GitHub
Leider sind die Lüfter bei tuxedo center nicht verfügbar
Verstecken sich die Einstellungsmöglichkeiten vielleicht hinter den “Lüfter Profilen”, wie das hier gewählte ‘Cool and Breezy’: System shuts down abruptly without warning - #25 by mzuniga ?
Also die Profile laufen zwar aber Lüftersteuerung nicht möglich. Lauft gleich wie ohne Tuxedo
hast du denn vorher die sensorsuche mit lm-sensors gemacht und bist nach dem arch-wiki vorgegangen ?
Ja leider wird auch kein Fan bzw Lüfter gefunden
Könnte ein Bug sein, checke mal die ‘Issues’ Seite der github page: 2.1.3: no cpu temperature, no cpu fan, no iGPU frequency · Issue #353 · tuxedocomputers/tuxedo-control-center · GitHub .
I pushed a quick fix regarding fan control. Please try v2.1.4.
Die Version in den offiziellen Repos ist 2.1.2-1 dh wahrscheinlich ein bissl warten…
Pamac hat noch eine tuxedo-control-center-bin 2.1.5-1 AUR Version aber hier bitte die Kommentare lesen! Scheint zwar als ob die Probleme behoben sind da seit dem letzten Update am 25.01.24 keine weiteren Kommentare mehr kamen aber ob Du das probieren willst mußt Du wissen. Ich persöhnlich würde auf den Update in den offiziellen Repos warten.
Du hast recht ich habe die Version 2.1.2 installiert.
Wie kann ich denn die 2.1.5 mal testen??
sudo pacman -Ss tuxedo-control-center-bin
dort finde ich die version aber nicht
pamac search -a tuxedo
shows that the requested version is
install it with
pamac build tuxedo-control-center-bin
remove the existing before
pamac remove tuxedo-control-center
Ich habe jetzt Version 2.1.5 installiert aber dort werden auch keine Lüfter angezeigt :(((
Ich finde auch die Fans nicht bei Sensor :frowning:
Komisch das Linux keine findet
hast du denn
sensors-detect
komplett durchlaufen lassen und ggf. das it87… paket installiert ? wenn das paket installiert ist, hast du den kernel-parameter in grub eingefügt und den grub upgedated ?
sensors-detect
habe ich durchlaufen lassen
it87 finde ich nicht und in grub habe ich nichts aktuallisiert. wie mache ich das?
laut inxi -Fazy
  System Temperatures: cpu: 35.0 C pch: 57.0 C mobo: N/A
